How can I send time and date in message text?
Scholler
Domoticz version: latest
Post by Scholler »
I am new in using the Blockly editor for creating actions.
Now I successfully managed to send an email in case of e.g. a door open or close action.
How can I insert the time (and date) of the moment it happened in the message text? See attached picture in the red box.
Is there a way to use a variable, maybe together with a way of formatting the output?
Thank you all for helping :-)
willemd
Domoticz version: 2024.1
Re: How can I send time and date in message text?
Post by willemd »
As far as I know Blockly can only handle static email text.
So not an answer but: I strongly advice you to learn dzVents. Much more powerful than blockly. Easy to include date and time in a message.
A slightly higher lurning curve but then .....
HvdW
Domoticz version: 2023.2
Post by HvdW »
willemd wrote: Tuesday 19 December 2023 10:18 I strongly advice you to learn dzVents. Much more powerful than blockly. Easy to include date and time in a message.
I strongly agree with @willemd
An example of including current time:
                if domoticz.data.value_9 > 1.48 * domoticz.data.value_0 then
                    -- switch off Plug Switch
                    local current_time =  os.date("%c")
                    domoticz.devices(CHARGER_SWITCH).switchOff()
                    local subject = 'Your battery has been charged. '
                    local message =
                    ' ' .. current_time .. '\n'..
                    'Plug Switch value_10: ' .. domoticz.data.value_10 .. '\n'..
                    domoticz.notify(subject, message, domoticz.PRIORITY_NORMAL)
Here are some examples. It helped me a lot to master dzVents.
Bugs bug me.
Domoticz version: 2025.1
HvdW wrote: Tuesday 19 December 2023 13:38
These examples are a little bit more up to date examples from Domoticz github
Also in the dzVents subforum loads of examples viewforum.php?f=59
And of course the dzVents Wiki that also has a lot of examples in it: https://www.domoticz.com/wiki/DzVents:_ ... _scripting
