Reverse On/Off icon
madpatrick
Domoticz version: 2025.2
Reverse On/Off icon
Post by madpatrick »
Is it possible to reverse the status of On / Off?
If the swtich is off then the iconis faded, but i like to have the changed to highlighted for some switches
Domoticz version: 2025.1
Re: Reverse On/Off icon
You could make an inverted custom icon for these switches. https://www.domoticz.com/wiki/Custom_ic ... binterface.
Edit: Now I see it is for Dasticz so you probably can ignore my answer.
Lokonli
Post by Lokonli »
madpatrick wrote: Saturday 16 December 2023 20:21 Hi,
You can do that via styling in custom.css.
If you have defined your block via:
blocks[1324] = {
Then add the following to custom.css:
[data-id="1324"] .off.icon {
    opacity: 1 !important;
[data-id="1324"] .on.icon {
    opacity: 0.2 !important;
or, use the addClass block parameter, and define relevant css classes in custom.js
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Yes, its possible if the device supports icon change.
You have to do the icons by yourself and add them via web interface - Setup -> More options -> Custom Icons.
https://domoticz.com/wiki/Custom_icons_for_webinterface - wki
https://drive.google.com/drive/folders/ ... KXRcuCsJWQ - icons pack
madpatrick
Lokonli wrote: Sunday 17 December 2023 8:29
blocks[1324] = {
This is working fine with an icon.
How cani do it for an img ?
I can change the size for the imange, but on/off is not working
.block_673 img					{max-width: 60px !important;}
.block_673 .off.img				{opacity: 1 !important;}
Lokonli
Post by Lokonli »
For images (images you use on the position of an icon) you can also just use:
.block_673 .off.icon {
Alternative, use addClass, like below:
In your block definition in CONFIG.js, for each block with inverted state styling:
blocks[673] = {
   addClass: 'invertedstatestyle'
And in custom.css, only once:
.invertedstatestyle .on.icon {
   opacity: 0.4 !important
 .invertedstatestyle .off.icon {
madpatrick
Lokonli wrote: Sunday 17 December 2023 21:03 For images (images you use on the position of an icon) you can also just use:
blocks[673] = {
[/quote]
This is working.
Not sure why it didn't work earlier
Thanks for the support !
madpatrick
madpatrick wrote: Sunday 17 December 2023 21:28
This is working.
