Hi I bought this 2 socket outdoor switch. that is Tuya and Zigbee2Mqtt compatible. But I'm using Zigbee for Domoticz.
https://nous.technology/product/a4z.html
It pairs as shortid: 28d1 IEEE: f082c0fffed1b921. However I can only control one of the sockets and power metering etc. is not working at all.
Can it be added to Zigbee4Domoticz?
NOUS 2 port IP44 Outdoor smart socket (TS011F) Topic is solved
kris
- Domoticz version: 2023.1
Domoticz 2023.2: Raspberry Pi 2B: Raspbian 11 Bullseye / Z-Wave JS 12.4.1 (docker): Aeotec Z-stick gen5 / Zigbee for Domoticz 7.1.007 [3.174]: PiZiGate 0321 / RFLink 1.48
HvdW
- Domoticz version: 2023.2
Re: NOUS 2 port IP44 Outdoor smart socket (TS011F)
I'd return it to the shop instead of fiddling around with a more or less incompatible device.
Use something WiFi. That allways fits to domoticz.
Here's another solution.
Bugs bug me.
kris
Attached the debug log.
- export-json.txt
- (70.82 KiB) Downloaded 30 times
- PluginZigbee_12.log.2023-12-02.txt
- (66.12 KiB) Downloaded 29 times
- Domoticz version: 2025.1
Check in the Z4D webui if the device is certified. If not make a GitHub issue with the required data https://zigbeefordomoticz.github.io/wik ... evice.html
kris
Thanks! I've created an issue in Github.
pipiche has helped me a lot in the forums before but I guess that is the correct way
kris
This device is now added and fully compatible with Zigbee for Domoticz.
Big thanks to pipiche!
