TS011F
manjh
TS011F
Post by manjh »
TS011F is mentioned in quite a few threads on this forum, but I cannot find a similar problem.
I purchased a no-name SmartPlug with Zigbee, and turned it on. It came into Zigbee-for-Domotics as a TS011F.
It was also added to Domoticz.
And I can switch it on/off from Domoticz.
So: all is good.... except for one thing : I only see a switch, and I expected more like energymanagement.
Here's a copy from the Domoticz log:
2023-12-02 13:49:12.101 Status: ZigbeeConbee: [None] NEW OBJECT: 044b None
2023-12-02 13:49:13.113 Status: ZigbeeConbee: Device Annoucement: NwkId: 044b Ieee: 70b3d52b60033543 MacCap: 8e
2023-12-02 13:49:13.582 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Active Endpoint Response Ep: 01 LQI: 255
2023-12-02 13:49:13.585 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Request Simple Descriptor for Ep: 01
2023-12-02 13:49:14.828 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Simple Descriptor Response EP: 0x01 LQI: 255
2023-12-02 13:49:14.829 Status: ZigbeeConbee: [-] NEW OBJECT: 044b ProfileID 0104
2023-12-02 13:49:14.829 Status: ZigbeeConbee: [-] NEW OBJECT: 044b ZDeviceID 0051
2023-12-02 13:49:14.830 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Application Version 0001
2023-12-02 13:49:14.831 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster IN Count: 08
2023-12-02 13:49:14.831 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 1: 0000 (Basic)
2023-12-02 13:49:14.832 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 2: 0006 (On/Off)
2023-12-02 13:49:14.833 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 3: 0003 (Identify)
2023-12-02 13:49:14.833 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 4: 0004 (Groups)
2023-12-02 13:49:14.834 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 5: 0005 (Scenes)
2023-12-02 13:49:14.834 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 6: e001
2023-12-02 13:49:14.835 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 7: 0b04 (Electrical Measurement)
2023-12-02 13:49:14.836 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster In 8: 0702
2023-12-02 13:49:14.836 Status: ZigbeeConbee: [-] NEW OBJECT: 044b Cluster OUT Count: 00
2023-12-02 13:49:15.083 Status: ZigbeeConbee: [0] NEW OBJECT: 044b Model Name: TS011F
2023-12-02 13:49:15.089 Status: ZigbeeConbee: [0] NEW OBJECT: 044b Manufacturer Name: _TZ3000_okaz9tjs
Am I expecting too much?
In Domoticz it comes in as type Light/Switch, subtype Switch.
In ZigbeeConbee I see model TS011F.
Hans
Domoticz version: 2025.1
Re: TS011F
Are you on the latest stable Z4D plugin version?
If you look into the plugin webui in the device list, does it show as certified? If not you can send a log in a GitHub issue.
pipiche
Re: TS011F
Post by pipiche »
would also be great to know what device you really bought ?
manjh
Re: TS011F
Post by manjh »
pipiche wrote: Saturday 02 December 2023 16:34 would also be great to know what device you really bought ?
See my first post in this thread.
Hans
manjh
Re: TS011F
Post by manjh »
I'm still confused. In the log lines it clearly mentions "Electrical measurement", so I expected something in Domoticz to show this.
Or is this not yet supported?
Hans
Re: TS011F
Please answer the questions instead of asking more :-)
pipiche
Re: TS011F
Post by pipiche »
Yes it is supported, but every day Tuya is coming with new fancy name? So TS011F does'nt mean that all TS011F report Electric measurement.
So we need to idendify which one it is, and by default we just have On/Off
are you the one whom have created this issue : https://github.com/zigbeefordomoticz/z4 ... /issues/31 ?
In all cases, make sure you are on plugin 7.1.005 with the latest Certified Db [2.158]
manjh
Re: TS011F
Post by manjh »
pipiche wrote: Monday 04 December 2023 9:41 are you the one whom have created this issue : https://github.com/zigbeefordomoticz/z4 ... /issues/31 ?
No, that's not me...
I am currently on version 6.3.015, so I will have to look into upgrading. I remember I tried before, and it gave me a headache...
Will try again.
Hans
pipiche
Re: TS011F
Post by pipiche »
You must have bullseye or above as buster do not support native python3.8 or above.
manjh
Re: TS011F
Post by manjh »
pipiche wrote: Monday 04 December 2023 13:40 You must have bullseye or above as buster do not support native python3.8 or above.
I am still on Buster. Migrating a complex production environment is a big deal.... will take more than just a rainy afternoon!
Hans
pipiche
Re: TS011F
Post by pipiche »
understood
Knight
Domoticz version: 2024.7
Re: TS011F
Post by Knight »
This item works perfect as router switch, reads energy kwh,watt,volt and Ampere
https://www.m.nu/rela-zigbee/smart-plug ... bee-2-pack
Namn TS011F-plug
Screenshot_20240304_162847_Samsung Internet.jpg (389.02 KiB) Viewed 1994 times
pipiche
Re: TS011F
Post by pipiche »
so I guess you finaly move to Buster. Sound good man
