i think i might have found a bug...altough i'm not sure if it's a issue with zwave js ui or domoticz.
I have a scene with multiple lights where they switch off with some delays....
it works ok from the domoticz ui...
i also connected a zwave remotec scene master. If i associate a button to the mentioned scene....all triggers are executed without the delays....so it is suboptimal....i have not found a send with high priority in zwave js ui....so i'm a bit lost.
best regards.
Giulio
Remotec activated scenes bug
gmarchionni
gmarchionni
Re: Remotec activated scenes bug
my bad....i just found i had another scene....between the amount of scene i have that had the same devices.
I'm very sorry for opening this post without reason....so i'll give a suggestion...
In the ui, devices with timers have a different colors. It would be cool if the scene page, for objects that have a activation device associated could also have a different color in the "Edit" button... (and maybe report the amount of devices that the scene is controlling.)
