Will Domoticz run on the new Raspberry PI 5?
DomoticaRob
- Domoticz version: V4.9700
HvdW
- Domoticz version: 2023.2
Re: Will Domoticz run on the new Raspberry PI 5?
Yes it will.
It's not the RPI version it's Bookworm that handles everything.
I have Domoticz running on Bookworm on RPI4.
SBFspot has not had the autoinstall script adapted but one can install it manually.
Bugs bug me.
DomoticaRob
Does this mean that I need a lot of knowledge or is it a straight forward installation?
- Domoticz version: 2025.1
So what is the difference for Domoticz installing it on Bookworm instead of Bullseye? It is a Linux version so the standard Domoticz install script should work I presume?HvdW wrote: Tuesday 31 October 2023 22:45 Yes it will.
- kiddigital
I think if you run domoticz in a Docker container it works fine.
As far as I know, bookworm comes with openSSL3 while domoticz works with OpenSSL1.1.
So running with SSL enabled won’t work probably.
In the (near) future, the Beta versions will switch to OpenSSL3.
You can always compile domoticz yourself if you follow the guide and than it will work natively on a Pi 5.
lost
This may be being built towards libssl1.1 dependency not present anymore in bookworm repos, replaced by libssl3.waltervl wrote: Thursday 02 November 2023 18:14 So what is the difference for Domoticz installing it on Bookworm instead of Bullseye?
There is workarounds, a search will show other post on the subject if needed.
So for a lot of users not using https there is no problem?
- kiddigital
You need to disable SSL (`-sslwww 0`) and then I would expect it works but I haven’t tested it so not sure.waltervl wrote:So for a lot of users not using https there is no problem?
Would be nice if someone installs bookworm and test it out (lacking the time here at the moment).
HvdW
Running smooth. Nothing out of the ordinary encountered. (On RPI4)waltervl wrote: Thursday 02 November 2023 18:14 So what is the difference for Domoticz installing it on Bookworm instead of Bullseye? It is a Linux version so the standard Domoticz install script should work I presume?
Bugs bug me.
lost
IMO this'll not remove the dependency at domoticz startup:waltervl wrote: Thursday 02 November 2023 18:34 So for a lot of users not using https there is no problem?
~/domoticz $ ldd domoticz | grep ssl
libssl.so.1.1 => /lib/aarch64-linux-gnu/libssl.so.1.1 (0x0000007f8c7dc000)
That's quite bad Debian do not provide libsslcompat that was designed to ease transition, like Alpine Linux for instance.
