Blinds Control via dzvents did not work
Posted: Tuesday 24 October 2023 12:31
Hi All,
first: I post here, cause I did not know if the Problem I have is a dzvents or database or something else.
Sine months I have a Blind called "Rolladen Theo" in Domoticz with a zwaver shutter controller.
This Z wave thing make different Problems not within Domoticz, but I like to go from z Wave to Shelly.
I use 3 Shelly 2.5 on diffent blinds with "ShellyMQTTPlugin" and it wok nice.
Now I have changed the Zwave device to to a new shelly plus 2pm, this was not found by ShellyMQTTPlugin
so I installed "mqtt auto discovery client with lan interface" with my Name "ShellyPlusAutodiscover" an I found the Shelly plus 2pm and get them running.
But I was really not happy with this ones so I buy some Shelly 2.5
I replaced the shelly plus 2pm with the new shelly 2.5 wich was now discoverd by the old
"ShellyMQTTPlugin" and the new "mqtt auto discovery client with lan interface" with my Name "ShellyPlusAutodiscover" Plugin.
I use all the Time the Name "Rolladen Theo"
I dont like the new Autodicover Plugin cause the old one is working fine for me.
If I now disable the new "mqtt auto discovery client with lan interface" with my Name "ShellyPlusAutodiscover" Plugin,
dzvents send me an Error in Eventlog: "Switch Command not send. Hardwaredevice disabled or not found."
But, the Device from the old "ShellyMQTTPlugin" Plugin is available and can be used via the the Switch in Domoticz.
The Name of the Switch is all the Time "Rolladen Theo" but from dzvents it can not be controlled.
Not with the Name not with ID, all the same Error Message.
Now it is your turn. Any Idea what the Problem can be or how can I fix this???
may you can help here
