Thermosmart bankrupt Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2023.2
The thermosmart plugin does not work anymore. On the thermosmart webpage you cant connect to the Domoticz Module anymore. Maybe it has something to do with the fact that Thermosmart is bankrupt since may 2023. Is there a workaround? Or do i have to say goodbye to the Thermosmart?
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
- Domoticz version: 2024.7
Re: Thermosmart bankrupt
Perhaps you make a reply in this Thermosmart integration topic viewtopic.php?t=5718
Perhaps something changed in the login. I saw that @kiddigital is still using this thermostat and it worked a couple of weeks ago.
It seems that the thermosmart api server is down https://api.thermosmart.com/login
You can try to contact thermosmart support for more info https://www.thermosmart.com/support/
Porblem is that the portal of Thermosmart isnt working anymore. The service is awful. People complaing for a while that Themosmart never reponses.
I think we dont have to explect anything for Thermosmart anymore:
https://www.faillissementsdossier.nl/nl ... t-b-v.aspx
The app is still working so that is one thing.
Rpi, RFXcom, klikaan klikuit switch,thermosmart, z-wave, espeasy, smartevse
ThermoSmart was taken over by an other Dutch company Plugwise.
I have contacted their helpdesk.
This is their answer.
Since may they support already the ThermoSmart thermostat and will continue this in the future.
They will contact the customers via email and via their web site http://www.plugwise.com/thermosmart/
Domoticz v2024.7, running on RP5/RP3B+, Bookworm/docker.
Applications/Devices/plugins:
RP5: Z-wave-JS, MQTT Broker, Homebridge, Milight hub, LMS, Denon, MQTT client/auto, RFXCOM
RP3B+: SolarEdge, P1 Smart meter UBS, Plugwise Anna, LIBGPIOD (Doorbell)
- Domoticz version: 2022.1
All good and well, but will they also support the API? It has been down for over a week now and it doesn't seem like anything is happening.theo11 wrote: ↑Tuesday 10 October 2023 22:15 ThermoSmart was taken over by an other Dutch company Plugwise.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | Qlima | Solaredge
TP-Link | Plugwise | Thermosmart | Node-Red | Grafana | Master and 5 remote servers
I send Plugwise a email today with the specific question about the API. When i receive an answer, i will post it here.
Here another API user interested to hear if the API will come back
Received a reply today:
"Het klop in der daad dat Plugwise ervoor gekozen heeft ThermoSmart van de curator te kopen. Hiermee hebben wij voorkomen dat alle Thermosmart systemen op zwart zijn gegaan. Plugwise draagt voorlopig de maandelijkse portal kosten hiervoor.
Ons development team is momenteel aan het onderzoeken hoe de architectuur van de ThermoSmart samen hangt en hoe dit het beste te interpreteren.
Pas zodra wij betere kennis hebben van het systeem kunnen bepalen hoe wij het beste service kunnen verlenen op deze systemen.
Wij zijn inmiddels op de hoogte dat de API niet werkt en de app niet meer verkrijgbaar is.
Wij hopen spoedig de zaken onder controle te hebben en met een service, dan wel een voorstel te komen hoe de woningen met een ThermoSmart warmt te houden. "
So they are trying to understand de software architecture . And then make a plan to intergrate it in their own product. Think we have to wait for that.
Nice to know that on Tweakers is a forumpost (in Dutch) about Thermosmart also.
https://gathering.tweakers.net/forum/li ... es/2093612
Solution for setting right (winter)time, they suggest to adjust time zone by replacing your city to one timezone east. (Example you live in timezone Amsterdam, change your city to timezone Berlin).
Since yesterday a broken Thermosmart server is reported...
Amsterdam and Berlin are in the same timezone.
Finland, the Baltic States, Belarus, Ukrain and so on are the next stop.
Bugs bug me.
I switched to another device (Honeywell) already, but got a email from Plugwise that then gonna stop with Themosmart support.
Plugwise has since released new firmware for the thermostat so that you can read and control the thermosmart through a web browser if you are on the same local network. There is no cloud service anymore.
I had a look at it and when you go to http://192.168.0.x/thermostat.xml you can easily extract the temperature and setpoint from the xml file. I set up Node-Red to do this. It should also be possible in this way to POST a new setpoint from a dzvents script or a thermostat button in Domoticz to the Thermosmart. I haven't found out how to do this yet. I'm still having trouble grasping how to POST a single value to an xml file that has multiple parameters of which I only want to change one.
I have a script which allows you to use the Thermosmart in Domoticz again. All you need to do is create two devices and use the attached DZVents script. Create a thermostat device and a temperature device. Adjust the script to reflect the idx values in your situation. You also need to adjust the script to your own local IP on which the Thermosmart is addressed.
I'm very happy with this. You now have a thermostat which isn't dependent on a cloud function, yet fully programmable through Domoticz. If you change the set-point through Domoticz, it is copied to the thermostat on your wall. If you tap the button on the thermostat to adjust the temperature, it is copied back to the Domoticz device. It works both ways.
active = true,
devices = { 1119 }, -- Triggered when the thermostat setpoint device changes
timer = { 'every minute' }, -- Periodically check the server for updates
httpResponses = { 'fetchDataResponse', 'setPauseResponse', 'setSetpointResponse' }
local setpointIdx = 1119
local temperatureIdx = 1120
local url = 'http://10.0.4.174/thermostat.xml'
-- Function to set the setpoint on the server
local function setSetpointOnServer(setpointValue)
domoticz.openURL({
url = url,
method = 'POST',
headers = { ['Content-Type'] = 'text/plain' },
postData = 'svset=' .. setpointValue,
callback = 'setSetpointResponse'
if (item.isTimer) then
-- Periodically fetch data from the server
domoticz.openURL({
url = url,
method = 'GET',
callback = 'fetchDataResponse'
elseif (item.isDevice) then
-- If the device (thermostat) setpoint changes, update the server
local newSetpoint = domoticz.devices(setpointIdx).setPoint
setSetpointOnServer(newSetpoint)
elseif (item.isHTTPResponse) then
if (item.trigger == 'fetchDataResponse') then
if (item.ok) then
local xmlString = item.data
local serverTemperature = tonumber(xmlString:match('<temperature>(.-)</temperature>'))
local serverSetpoint = tonumber(xmlString:match('<setpoint>(.-)</setpoint>'))
-- Update Domoticz temperature device if different
local currentTemperature = domoticz.devices(temperatureIdx).temperature
if currentTemperature ~= serverTemperature then
domoticz.devices(temperatureIdx).updateTemperature(serverTemperature)
domoticz.log('Temperature updated from server to ' .. serverTemperature)
-- Update Domoticz thermostat setpoint if it's different
local currentSetpoint = domoticz.devices(setpointIdx).setPoint
if currentSetpoint ~= serverSetpoint then
domoticz.devices(setpointIdx).updateSetPoint(serverSetpoint)
domoticz.log('Setpoint updated from server to ' .. serverSetpoint)
domoticz.log('Error fetching data: ' .. item.statusCode, domoticz.LOG_ERROR)
elseif (item.trigger == 'setSetpointResponse') then
if item.ok then
domoticz.log('Setpoint successfully updated on the server')
domoticz.log('Error setting setpoint on the server: ' .. item.statusCode, domoticz.LOG_ERROR)
