How to use 'clearlightlog' in lua script
Posted: Wednesday 04 October 2023 0:46
I have some scripts in use that use a textdevice to show some values every 20 seconds on the dashboard.
The problem this gives is that many thousands of entry's in the logs are created to remove these i mannualy have to clear the log every view days.
i have tried to atomate the removal but couldn't get it to work; in the end I got some reply from someone from the board that this could'nt be done and i had to just live with it..
So here i try, try again...
I found that what i want to happen i could do via:
and it works!!
It's a start, but its not automated yet..
Now my question:
I have a LUA script that runs every day at 23:58; I would like add the clearlightlog function too it. (because my Domoticz runs from a Dockercontainer the ip used in the script wil be 127.17.0.2)
Can this be done in just LUA? (without curl)
http://192.168.178.2:7080/json.htm?type=command¶m=clearlightlog&idx=223Code: Select all
"status" : "OK",
"title" : "ClearLightLog"
}Now my question:
