How to use 'clearlightlog' in lua script Topic is solved
RonkA
Domoticz version: 2025.1
Post by RonkA »
I have some scripts in use that use a textdevice to show some values every 20 seconds on the dashboard.
The problem this gives is that many thousands of entry's in the logs are created to remove these i mannualy have to clear the log every view days.
i have tried to atomate the removal but couldn't get it to work; in the end I got some reply from someone from the board that this could'nt be done and i had to just live with it.. :|
So here i try, try again...
I found that what i want to happen i could do via:
http://192.168.178.2:7080/json.htm?type=command&param=clearlightlog&idx=223
and it works!!
	"status" : "OK",
	"title" : "ClearLightLog"
It's a start, but its not automated yet..
Now my question:
I have a LUA script that runs every day at 23:58; I would like add the clearlightlog function too it. (because my Domoticz runs from a Dockercontainer the ip used in the script wil be 127.17.0.2)
Can this be done in just LUA? (without curl)
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
Kedi
Re: How to use 'clearlightlog' in lua script
Post by Kedi »
In Lua it is also possible to open an URL with for example
commandArray['OpenURL']='http://192.168.178.2:7080/json.htm?type=command&param=clearlightlog&idx=223'
See https://www.domoticz.com/wiki/LUA_commands
But for new scripting users perhaps dzvents is easier.
RonkA
Post by RonkA »
Didnt clear the log.. tried the HTTP-request from the wiki:
domoticz.openURL('http://127.17.0.2:80/json.htm?type=command&param=clearlightlog&idx=222')
And it does the trick.. i just couldnt find it myself.
Thanks the both of you.
Then you probably did not use a lua but a DzVents script already? But OK, glad it works with DzVents
