System Alive Checker question
Posted: Monday 25 September 2023 19:19
by ilex
Hi.
I use System Alive Checker (Ping).
Below example from Domoticz Wiki:
Simple question: is there any way with script or better w json url to change "Sauron" device to other value ?
Why I need that ? My Mikrotik router has a backup LTE ISP uplink with dynamic IP address. I wish to send obtained IP address to domoticz every time it is changed.
Any hint ?
Best regards to all
Re: System Alive Checker question
Posted: Tuesday 26 September 2023 0:26
Change the value from the web ui and check with F12, section network the API call to modify. It could be that part of the url is base64 encoded
Posted: Tuesday 26 September 2023 11:29
by Kedi
This is the url:
http://192.168.2.xxx:8080/json.htm?type=command&param=pingerupdatenode&idx=<hardware idx>&nodeid=<node ID>&name=<name>&ip=<ip-address>&timeout=5
Posted: Thursday 28 September 2023 22:31
by ilex
@Kedi: You have made my day - thx !
"status" : "OK",
"title" : "PingerUpdateNode"
Posted: Monday 15 July 2024 12:05
by ilex
After upgrade of domoticz to Version: 2024.6 (build 16150) it seems to me code is not working any longer. Can someone confirm that ?
BR.
Posted: Friday 01 November 2024 2:59
by solarboy
I get lots of false positives with this.
