After updating Domoticz to the latest Beta (15555) en Dashtics to the latest Beta (3.10.8), al the setpoints displays "On":
The data-field in Domoticz shows the actual setpoint number:
Hopefully someone can help.
Thanks.
Setpoints shows 'On' instead of setpoint number Topic is solved
michelscholte
- Domoticz version: 2025.1
Re: Setpoints shows 'On' instead of setpoint number
@Lokonli There has been some changes on Thermostat devices in this beta, see viewtopic.php?p=307044#p307044 and https://github.com/domoticz/domoticz/pull/5817
Lokonli
Thanks, I'll checkwaltervl wrote: Thursday 21 September 2023 12:25 @Lokonli There has been some changes on Thermostat devices in this beta, see viewtopic.php?p=307044#p307044 and https://github.com/domoticz/domoticz/pull/5817
Is the setpoint device api json different now? It seems that the Android app also don't understand the output anymore.
To answer myself:waltervl wrote: Thursday 21 September 2023 17:04 Is the setpoint device api json different now? It seems that the Android app also don't understand the output anymore.
Main difference is "Type" that changed from "Thermostat" to "SetPoint". SubType stayed the same (SetPoint).
Also the new settings are added (min/max/step/vunit)
Stable 2023.2
"SetPoint": "17.0",
"ShowNotifications": true,
"SignalLevel": "-",
"SubType": "SetPoint",
"Timers": "false",
"Type": "Thermostat",
"TypeImg": "override_mini",
"Unit": 1,
"Used": 1,
"XOffset": "0",
"YOffset": "0",
"idx": "144"Code: Select all
"SetPoint" : "24.2",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Setpoint",
"TypeImg" : "override_mini",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "80",
"max" : 200.0,
"min" : -200.0,
"step" : 0.5,
"vunit" : "\u00b0C"Domoticz running on Udoo X86 (on Ubuntu)
Lokonli
Fixed in latest Dashticz beta.
Update with 'git pull'
Can you test?
Can you test?
michelscholte
Great. It shows the correct values now.
Thanks again.
Thanks again.
