Blockly Night / Day temp
billouetaudrey
Post by billouetaudrey »
I need your help :(
I want when it 8h to 20h, if Temp is less than 28°C, its set smart plug to ON, when it more than 28°C, it's set smart plug to OFF
Then
to 20h to 8h, if Temp is less than 23°C, its set smart plug to ON, when it more than 23°C, it's set smart plug to OFF
This is what I do but seem to not work, where I'm wrong please ?
Xenomes
Domoticz version: 2025.2
Re: Blockly Night / Day temp
Post by Xenomes »
You are on the right way... Think this you are looking for.
2023-09-01 21_01_54-Domoticz - Gebeurtenissen – Mozilla Firefox.png (45.96 KiB) Viewed 2917 times
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
billouetaudrey
Ah this seem work :)
Now I have an another issue, need to fix it ( XIaomi sensor isn't always update, need to restart the gateway from domoticz manually or need to restart the docker )
thanks very much :)
