hi
I've lost a lot of hours searching how to set device of type 'kWh' as Computed, not "From device"
So, in this page (Developing_a_Python_plugin) please update the line
|kWh||Electric (Instant+Counter)
to
|kWh||Electric (Instant+Counter)<br>
nValue shold be zero<br>
sValue are two numbers separated by semicolon like "123;123456" The first number is the actual power in Watt, the second number is actual energy in kWh. When the option "EnergyMeterMode" is set to "Calculated", the second value is ignored<br>
Optional argument Options can set the EnergyMeterMode.<br>
Use Options={'EnergyMeterMode': '1' } to set energyMeterMode to "Calculated". Default is "From Device"
Please update Wiki page Developing_a_Python_plugin
- Domoticz version: 2026.3
Re: Please update Wiki page Developing_a_Python_plugin
I modified the wiki. I only think you made a mistake for sValue?
Should it not be:
That is similar to the description of the same device in the API call: https://www.domoticz.com/wiki/Domoticz_ ... counter.29
Should it not be:
So not "actual energy in kWh" but "absolute counter value in Wh"sValue are two numbers separated by semicolon like "123;123456" The first number is the actual power in Watt, the second number is the absolute counter value in Wh.
