KNMI weeralert with dzvents
Hansh
Domoticz version: 2025.1
Post by Hansh »
Inspired by the block script from FireWizard I made a script in dzvents to bring the weather alarm from the KNMI to domoticz
You can request the local weather from KNMI via an API, see https://weerlive.nl/delen.php
All data is very usable and on this forum you can find scripts that process the data.
However, the weather alarm is the general alarm for the Netherlands and is not really useful for the local level.
The RSS feed of the KNMI only provides the weather alarm, but then per province, see https://cdn.knmi.nl/knmi/xml/rss/rss_KN ... wingen.xml
To process this rss in domoticz I made a script which filters out the weather alarm and the alarm text of the desired province
Below is the DzVents script
local url = 'https://cdn.knmi.nl/knmi/xml/rss/rss_KNMIwaarschuwingen.xml' -- rss url
local scriptVar = 'WeerAlert' -- callback name
local WeerAlertDevice  = 'Weerwaarschuwing' -- name of alert device in domotcicz
local codes = {"Groen","Geel","Oranje","Rood"} -- available codes
local PV = 11 -- Province code
--[[ codes for the different provinces
2=Waddeneilanden        3=Groningen         4=Friesland         5=Drente
6=Noord-Holland         7=Flevoland         8=Overijsel         9=Gelderland
10=Utrecht              11=Zuid-Holland     12=Zeeland          13=Noord-Brabant
14=Limburg              15=Waddenzee        16=ijselmeer-gebied
return
    on =
        timer =
            'at *:56',
        httpResponses =
            scriptVar,
         -- ***** No changes required below this line *****
    logging =
        level = domoticz.LOG_INFO,
        marker = scriptVar,
    execute = function(dz, item)
    local Weeralarm = dz.devices(WeerAlertDevice) --reference to the weather alarm device
        --Retrieve desired data from the returned xml file
        local function getData(data)
            rt = dz.utils.fromXML(data).rss.channel.item[PV]
            RelevanteData={["code"]=0,["text"]="Geen data"}
            --dz.log(rt["description"],dz.LOG_DEBUG)
            --rt["description"]="Code Geel.<br>Enkele onweersbuien met kans op hagel.<p><a href='/kennis-en-datacentrum/waarschuwingen/onweersbuien'>Wat kan ik verwachten en wat kan ik doen bij onweersbuien?</a> (van 01/08/2023 10:00 tot 01/08/2023 16:00 uur)<br><br>"
            for key,value in ipairs(codes) do
                if string.match(rt["description"],value) then
                    RelevanteData["code"]=key
                    RelevanteData["text"]=rt["description"]:gsub("<a.-a>","")
            return RelevanteData
        --update the specified device in domoticz
        local function UpdateDevice(data)
            local lastStatus = "0"
            lastStatus= tostring(Weeralarm.color)
            Weeralarm.updateAlertSensor(data["code"],data["text"])
            --un comment the next 3 lines to send a notification when the status has changed(this one is for telegram)
            --if tostring(data["code"]) ~= lastStatus then
            --    dz.notify('Domoticz', 'Weeralarm: \n'.. data["text"]:gsub("<.->",""), dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , dz.NSS_TELEGRAM)
            --end
        if item.isHTTPResponse then
            if item.ok then
                UpdateDevice(getData(item.data))
                dz.log('There was a problem handling the request', dz.LOG_ERROR)
                dz.log(item, dz.LOG_ERROR)
            return
        dz.openURL(
            url = url,
            method = 'GET',
            callback = scriptVar,
In order for the script to work, a device of the type: General Alert must be created in domotcz
Operation of the script:
In the top lines the div variables can be edited
In order for the script to work properly, only two need to be changed
local WeerAlertDevice = must contain the name of the domoticz device Here Weather alert
local PV = must contain the code for the province
Thanks again to FireWizard for the inspiration
regards
Hansh
All my texts are translated from Dutch to English by Google translate>
Sorry for weird sentence structure
