Which recent zwave thermostat works fine with OZW as well as zwave_js ?
Posted: Sunday 23 July 2023 23:14
I’m in the following situation and would gladly have some of your advice:
Current setup: Running Domoticz 2023.1 on Raspberry Pi 2 + ÆON z-stick 5 + RFXCOM. Sensor communication still mainly OZW based.
I am about to install electrical underfloor heating and would like to have that controlled through Domoticz.
In addition my conventional CV heating boiler needs to be replaced soon (for most likely Remeha Tzerra or Intergas Xtreme 36.)
To be able to control both heat sources in the near future, I was thinking to use a zwave thermostat (or do I need two?) that properly integrate(s) with Domoticz. I’ve found that the HeatiT Z-TRM3 for instance does not properly work with Domoticz due to an OZW-issue.
Does it properly work with zwave-js/MQTT ? I know I have to put in the effort to move away from OZW since it’s depricated, but would rather do that on my own pace. So would be nice to have a thermostat that works with Domoticz/OZW for now and keeps working after migration to zwave-js/MQTT.
Which thermostat(s) would you recommend for my situation? Any other advice / recommendations on the total possible solution are much appreciated. Thanks in advance !
