How do I Calculate Seconds ON for a device between 5pm and 7pm daily?
Posted: Thursday 13 July 2023 17:21
by pippya
Hi I would like to know the utilisation of our Squash Courts at peak times - between 5pm and 7pm.
I already calculate and capture the percent usage of the courts over a whole day, but we now need to know the utilisation at peak times.
Background and this is working fine.
1. Tasmota device measure Lux level and updates a virtual lux level sensor every 5mins
2. Dzvents looks at lux level and determines whether light is on or off and updates a virtual light switch (pic examples attached)
3. A couple more Dzvents then update an incremental counter and work out the percent usage for the day
all working ok , but how do I work out utilisation for a specific time period ?
Can you advise on best approach? if a script dzvents is preferred
Do I modify my existing scripts ? if so i can post the incremental counter example
Do I calculate time ON from the already captured data in the light sensor at the end of the day ?
I did try an additional incremental counter but the rollover to next day meant first time it ran, it calculated elapsed time since it finished end of previous day.
Regards Phillip
Re: How do I Calculate Seconds ON for a device between 5pm and 7pm daily?
Posted: Friday 14 July 2023 8:29
by willemd
Create a device which is set to zero at the start of the peak time.
Update the device in the same way as your already existing incremental counter.
Calculate the percentage at the end of the peak time.
Posted: Monday 17 July 2023 11:03
by pippya
Thanks for replying
current incremental counter is below
assume I will need a trigger similar to this ?
timer = {'at 17:00-19:00 every 5 minutes'},
can you provide an example of how I zero everyday at start of peak time and how I then trigger a calculation at the end of the peak time ?
I tried to post the dzvent script this was not allowed, added a pic instead, is this due to me being a newcomer ?
Posted: Monday 17 July 2023 15:18
by willemd
Here are examples of the timer rules you can use:
https://www.domoticz.com/wiki/DzVents:_ ... gger_rules
In you script you can test which of the timers (=item in your script) fired the script and then take action accordingly.
So if the "at 17:00" timer triggered the script, then you do the reset and if the "at 19:00" triggered the script, then you make the calcuation.
Posted: Monday 17 July 2023 15:57
by jvdz
pippya wrote: Monday 17 July 2023 11:03
Did you try posting it in a codebox? (</>)
Posted: Tuesday 18 July 2023 9:39
by pippya
Hi yes I did use the code box button and tried again
I received this message
"You can’t post image, email or url links that are external to this domain. Please remove domoticz., dz., item., dz., data., dz., data., os., dz., data., os., item., lastUpdate., os., dz., data., dz., data. and iCounter."
Posted: Tuesday 18 July 2023 9:50
by pippya
will try and work with subsets of the code, apologies not being able to use code box
at the moment I have this as a trigger
on =
devices =
43, -- court 3 light idx43 device for which you want to record the On time.
will change to this
on =
timer = {'at 17:05-18:55 every 5 minutes',
'at 17:00',
'at 19:00',
identify which timer triggered the event with this: ?
if timer.trigger == 'at 17:00' then
-- setup for initial use
elseif timer.trigger == 'at 19:00' then
-- finalise and calculate
is somebody able to explain the 3 code steps here please ?
if item.active then
if dz.data.lastOn == 0 then dz.data.lastOn = os.time() end
return
secondsActive = os.time() - item.lastUpdate.dDate
secondsActive = os.time() - dz.data.lastOn
dz.data.lastOn = 0
regards phillip
Posted: Tuesday 18 July 2023 11:53
by willemd
You will have to write the code yourself , here is the logic.
I think you could also use domoticz.devices(yourIDXnr).lastUpdate.secondsAgo
So:
1) reset a counter device to zero at 17:00.
If the light is already on at 17:00, make sure to record the number of seconds since it was switched on (in a persistent variable for example) so you can subtract that later.
2) Every time the light changes from on to off, determine secondsago and add to counter device.
If the light was already on at 17:00 make sure to subtract the number of seconds of the persistent variable, otherwise the seconds before 17:00 are also counted. But only do this during the first update (if you set the persistent variable to 0 after first use, then this is solved automatically)
3) at 19:00, if the light is still on, add the seconds to the counter device otherwise don't update the counter
and then divide the total of the counter device (=seconds on during the two hours) by 7200, multiply by 100, and then you have the percentage.
Posted: Tuesday 18 July 2023 13:12
by jvdz
pippya wrote: Tuesday 18 July 2023 9:39
It is correct that in the first couple of posts you can't have URL's pointing to other sites than the forum website as an anti spamming measure. Just change the url in the code so it isn't recognized as outside url.
