Help needed Husqvara/Gardena Smart Water
zicht
Domoticz version: 2023.1+
Post by zicht »
I am trying to control a Gardena Smartwater valve via SmartWater API, but I am stuck at some Python code and i do not understand my mistake.
Currently i am able via a webhook to get reallife status :
import websocket
import datetime
from threading import Thread
import time
import sys
import requests
import json
# account specific values
CLIENT_ID = 'f48eae05-3d76-4x3b-ay90-<FICTIEF>'
CLIENT_SECRET = '4d4ce773-cx5b-4yeb-9781-<FICTIEF>'
API_KEY = 'f48eae05-3d76-4x3b-ay90-<FICTIEF>'
# other constants
AUTHENTICATION_HOST = 'https://api.authentication.husqvarnagroup.dev'
SMART_HOST = 'https://api.smart.gardena.dev'
class Client:
    def restart():
        import sys
        print("argv was",sys.argv)
        print("sys.executable was", sys.executable)
        print("restart now")
        import os
        os.execv(sys.executable, ['python'] + sys.argv)
    def on_message(self, ws, message):
        x = datetime.datetime.now()
        response = requests.get(
            'http://192.168.0.200:8080/json.htm?type=command&param=udevice&idx=6204&nvalue=0&svalue=' + message,
        ws.messages_count+=1
        print("--")
        print("msg ", x.strftime("%H:%M:%S") + " " + str(ws.messages_count))
        print(message)
        sys.stdout.flush()
        thisdict = dict(json.loads(message))
        if thisdict["type"]=="COMMON" :
           message = "bat:" + str(thisdict["attributes"]["batteryLevel"]["value"])
           message = message + " lev:" + str(thisdict["attributes"]["rfLinkLevel"]["value"])
           message = message + " stat:" + str(thisdict["attributes"]["rfLinkState"]["value"])
           if thisdict["id"]=="fe59933d-9864-4711-90a8-ad3ef78a1af0":
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_sensor_achter_2&vtype=2&vvalue=' + message,
           if thisdict["id"]=="d25221cc-bca6-401c-8143-75c67a2efdba":
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_valve_achter_1&vtype=2&vvalue=' + message,
           if thisdict["id"]=="5d84502e-7d3c-4f6b-bb9d-<FICTIEF>'":
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_valve_voor_1&vtype=2&vvalue=' + message,
           if thisdict["id"]=="97d5a2fa-9de3-404a-85ba-<FICTIEF>'":
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_sensor_voor_2&vtype=2&vvalue=' + message,
        if thisdict["type"]=="SENSOR" :
           message = "soilHum: " + str(thisdict["attributes"]["soilHumidity"]["value"])
           message = message + " soilTemp:" + str(thisdict["attributes"]["soilTemperature"]["value"])
           if thisdict["id"]=="fe59933d-9864-4711-<FICTIEF>':
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_sensor_achter_1&vtype=2&vvalue=' + message,
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_sensor_voor_1&vtype=2&vvalue=' + message,
        if thisdict["type"]=="VALVE" :
           #print("naam " + str(thisdict["attributes"]["name"]["value"]))
           message=str(thisdict["attributes"]["activity"]["value"])
           if thisdict["id"]=="d25221cc-bca6-401c-8143-<FICTIEF>'":
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_valve_achter_2&vtype=2&vvalue=' + message,
                       'http://192.168.0.200:8080/json.htm?type=command&param=updateuservariable&vname=Gardena_valve_voor_2&vtype=2&vvalue=' + message,
    def on_error(self, ws, error):
        print("error ", x.strftime("%H:%M:%S"))
        print(error)
    def on_close(self, ws, close_status_code, close_msg):
        self.live = False
        print("closed ", x.strftime("%H:%M:%S,%f"))
        print("### closed ###")
        if close_status_code:
            print("status code: "+str(close_status_code))
        if close_msg:
            print("status message: "+str(close_msg))
        client.restart
    def on_open(self, ws):
        print("connected ", x.strftime("%H:%M:%S,%f"))
        print("### connected ###")
        self.live = True
        def run(*args):
            while self.live:
                time.sleep(1)
        Thread(target=run).start()
def format(response):
    formatted = [response.url, "%s %s" % (response.status_code, response.reason)]
    for k,v in response.headers.items():
        formatted.append("%s: %s" % (k, v))
    formatted.append("")
    formatted.append(r.text)
    return "\n".join(formatted)
if __name__ == "__main__":
    while True:
        try:
            payload = {'grant_type': 'client_credentials', 'client_id': CLIENT_ID, 'client_secret': CLIENT_SECRET}
            print("Logging into authentication system...")
            r = requests.post(f'{AUTHENTICATION_HOST}/v1/oauth2/token', data=payload)
            assert r.status_code == 200, format(r)
            auth_token = r.json()["access_token"]
            #print("\nLogged in auth_token=(%s)" % auth_token)
            headers = {
                "Content-Type": "application/vnd.api+json",
                "x-api-key": API_KEY,
                "Authorization": "Bearer " + auth_token
            print("\n### get locations ###")
            r = requests.get(f'{SMART_HOST}/v1/locations', headers=headers)
            assert len(r.json()["data"]) > 0, 'location missing - user has not setup system'
            location_id = r.json()["data"][0]["id"]
            #print("\nLocationId=(%s)" % location_id)
            payload = {
                "data": {
                    "type": "WEBSOCKET",
                    "attributes": {
                        "locationId": location_id
                    "id": "does-not-matter"
            print("\ngetting websocket ID...")
            r = requests.post(f'{SMART_HOST}/v1/websocket', json=payload, headers=headers)
            assert r.status_code == 201, format(r)
            print("\nWebsocket ID obtained, connecting...")
            response = r.json()
            websocket_url = response["data"]["attributes"]["url"]
            websocket.enableTrace(False)  #True om raw output in display te hebben
            client = Client()
            ws = websocket.WebSocketApp(
                websocket_url,
                on_message=client.on_message,
                on_error=client.on_error,
                on_close=client.on_close)
            ws.messages_count = 0         # Create a counter and an empty list to store messages
            ws.on_open = client.on_open
            ws.run_forever(ping_interval=120, ping_timeout=3)
        except Exception as e:
            gc.collect()
            print("Websocket connection Error  : {0}".format(e))
        print("Reconnecting websocket  after 60 sec")
        time.sleep(60)
The above code works and i get status for my sensors and valves in domoticz uservars. Part1 : get status of devices is finished, but needs cleanup to make it interact nicely with domoticz. So all works on this part for now.
Problem is on controlling the water valves :
import websocket
import datetime
import time
import sys
import requests
import json
# other constants
    headers = {
    r = requests.get('{}/v1/locations/{}'.format(SMART_HOST, location_id), headers=headers)
    assert r.status_code == 200, r
    assert len(r.json()["included"][0]['relationships']['services']['data']) > 0, 'no devices setup'
    devices = r.json()["included"][0]['relationships']['services']['data']
    for device in devices:
        print(device['type'])
        if(device['type'] == "VALVE"):
            payload = {
                "data": {
                    "type": "VALVE_CONTROL",
                    "attributes": {
                      "command": "START_SECONDS_TO_OVERRIDE",
                      "seconds": "60"
            r = requests.put('{}/v1/command/{}'.format(SMART_HOST, device['id']), data=payload, headers=headers)
            format(r)
            print(r)
    print("Done")
Again i get logged in but no control happens, expected behavior is activate all valves for 60 seconds. But all i get is 400, incorrect request .
I cannot find where my mistake is made....
What am i missing ?
<EDIT> My domoticz is not conncted to internet, so this code is running on another machine Using python 3.7.9 32bit, the plan is when all works to combine it to a plugin, but i am not a coder at all, so thats another project, let first make it work this way.
(Many thanks for reading so far...)
