Domoticz crash everyday at midnight
redfirebrooks
since a week my domoticz crash every day at midnight for an unknown reason.
Ii is running on a raspberry pi 3b+ on rasping bullseye.
I have no automation running at this specific hour in domoticz.
The last crash log can be find here : https://pastebin.com/BaxiMz4z
Can someone help me so solve this issue ?
Version: 2024.1
Build Hash: 5279c8261
Compile Date: 2024-01-01 12:59:22
dzVents Version: 3.1.8
Python Version: 3.9.2
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
- gizmocuz
Re: Domoticz crash everyday at midnight
First Disable dzVents/Python in the settings, and if you have enabled also disable the automatic backup option
Also disable all hardware
Now check if it continues to work after midnight, sure you have a non-useful system, but this most be the first step
Next enable hardware one by one (check if it continues to work after midnight each time)
Next enable dzVents/Python, if it is crashing, it is one of your scripts that is causing this
Disable all scripts, check again, enable one, check again, enable another etc..
redfirebrooks
So I did what you recommended, everything was disabled, very hardware, events... blank system and at midnight
2023-06-17 00:00:00.987 Sunrise: 05:47:00 SunSet: 21:57:00
2023-06-17 00:00:00.987 Day length: 16:11:00 Sun at south: 13:52:00
2023-06-17 00:00:00.987 Civil twilight start: 05:04:00 Civil twilight end: 22:40:00
2023-06-17 00:00:00.987 Nautical twilight start: 04:03:00 Nautical twilight end: 23:41:00
2023-06-17 00:00:00.987 There is no astronomical twilight in the space of 24 hours
2023-06-17 00:00:00.987 Status: EventSystem: reset all events...
2023-06-17 00:00:01.280 Error: Domoticz(pid:24663, tid:24674('MainWorker')) received fatal signal 6 (Aborted)
2023-06-17 00:00:01.280 Error: siginfo address=0x6057, address=(nil)
did i lost disabling the rflink plugin all my historic ? because all my 433 devices are gone now. Not cool.
time for to move to something else I guess.
Version: 2024.1
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
- Domoticz version: 2026.3
In your crashlog it seems to be an issue with the nightly database update and specific one of the percentage devices.
You can check your database for incorrect values. See the troubleshooting wiki for more info. https://www.domoticz.com/wiki/Troubleshooting
Also check your disk space to be sure there is enough free space as a copy of the database is made around midnight.
Thread 12 (Thread 0x6fcff200 (LWP 894) "MainWorker"):
#0 0x76894034 in __GI___wait4 (pid=24452, stat_loc=0x6fcfdb10, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
#1 0x002868cc in dumpstack_gdb(bool) ()
#2 0x00286e98 in signal_handler(int, siginfo_t*, void*) ()
#3 <signal handler called>
#4 raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#5 <signal handler called>
#6 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#7 0x76808364 in __GI_abort () at abort.c:79
#8 0x009054c8 in __gnu_cxx::__verbose_terminate_handler() ()
#9 0x00868908 in __cxxabiv1::__terminate(void (*)()) ()
#10 0x0086897c in std::terminate() ()
#11 0x0087342c in __cxa_throw ()
#12 0x008a0c30 in std::__throw_invalid_argument(char const*) ()
#13 0x00287350 in unsigned long long __gnu_cxx::__stoa<unsigned long long, unsigned long long, char, int>(unsigned long long (*)(char const*, char**, int), char const*, char const*, unsigned int*, int) [clone .constprop.1126] ()
#14 0x00291bb4 in CSQLHelper::AddCalendarUpdatePercentage() ()
#15 0x0029ff60 in CSQLHelper::ScheduleDay() ()
#16 0x00258e8c in MainWorker::Do_Work() ()
#17 0x008db9cc in execute_native_thread_routine ()
#18 0x76a0b310 in start_thread (arg=0x6fcff200) at pthread_create.c:477
#19 0x768ccda8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)Domoticz running on Udoo X86 (on Ubuntu)
- gizmocuz
@redfirebrooks, by disabling a hardware device (not delete it) you will of course not lose any devices, that would be kind of odd wouldn't it?
You might have enabled 'hide disabled devices' under settings.
You also did not mention which version of Domoticz you are running
As Walter pointed out, it indeed seems like an illegal value in one of your percentage devices.
But I would not expect a crash with this (at least in the recent beta versions)
redfirebrooks
Hello
my domoticz version is Version: 2023.1
Build Hash: f9b9ac774
Compile Date: 2023-02-14 15:06:40
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
I have followed the troubleshooting procedure to check and repair the database but I am still getting the crash at midnight.
I post below the full debug log of the crash :
2023-06-19 23:59:47.915 Debug: SQLH UpdateValueInt Visibility HwID:25 DevID:1 Type:243 sType:1 nValue:0 sValue:10.0
2023-06-19 23:59:47.915 Météo: General/Visibility (Visibility)
2023-06-19 23:59:47.916 Debug: SQLH UpdateValueInt Clouds % HwID:25 DevID:00000007 Type:243 sType:6 nValue:0 sValue:0.00
2023-06-19 23:59:47.916 Météo: General/Percentage (Clouds %)
2023-06-19 23:59:47.926 Debug: SQLH UpdateValueInt Precipitation HwID:25 DevID:8 Type:85 sType:113 nValue:0 sValue:0;2.9
2023-06-19 23:59:47.926 Météo: Rain (Precipitation)
2023-06-20 00:00:00.310 Status: dzVents: Info: Synology Monitor v1.35 : ------ Start internal script: MyNAS:, trigger: "every minute"
2023-06-20 00:00:00.424 Debug: SQLH UpdateValueInt Température Salle de bain HwID:9 DevID:11638 Type:82 sType:5 nValue:0 sValue:27.5;54;1
2023-06-20 00:00:00.431 RFLINK: Temp + Humidity (Température Salle de bain)
2023-06-20 00:00:00.558 Status: dzVents: Debug: Synology Monitor v1.35 : NASTemp : 47
2023-06-20 00:00:00.591 Status: dzVents: Debug: Synology Monitor v1.35 : Processing device-adapter for TS-451 Temp: Temperature device adapter
2023-06-20 00:00:00.591 Status: dzVents: Debug: Synology Monitor v1.35 : HDTemp1 : 43
2023-06-20 00:00:00.594 Status: dzVents: Debug: Synology Monitor v1.35 : Processing device-adapter for TS-451 HDD1 Temp: Temperature device adapter
2023-06-20 00:00:00.594 Status: dzVents: Debug: Synology Monitor v1.35 : HDTemp2 : 40
2023-06-20 00:00:00.596 Status: dzVents: Debug: Synology Monitor v1.35 : Processing device-adapter for TS-451 HDD2 Temp: Temperature device adapter
2023-06-20 00:00:00.596 Status: dzVents: Debug: Synology Monitor v1.35 : HDTemp4 : 45
2023-06-20 00:00:00.598 Status: dzVents: Debug: Synology Monitor v1.35 : Processing device-adapter for TS-451 HDD4 Temp: Temperature device adapter
2023-06-20 00:00:00.598 Status: dzVents: Debug: Synology Monitor v1.35 : Uptime : 7:16:09:24.65
2023-06-20 00:00:00.600 Status: dzVents: Debug: Synology Monitor v1.35 : Processing device-adapter for NAS Uptime: Text device
2023-06-20 00:00:00.600 Status: dzVents: Debug: Synology Monitor v1.35 : Requete SNMP correcte
2023-06-20 00:00:00.602 Status: dzVents: Debug: Synology Monitor v1.35 : Processing device-adapter for QNAP TS-451: Switch device adapter
2023-06-20 00:00:00.602 Status: dzVents: Debug: Synology Monitor v1.35 : Constructed timed-command: On
2023-06-20 00:00:00.602 Status: dzVents: Info: Synology Monitor v1.35 : ------ Finished MyNAS
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Request to add task: idx=1067, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Request to add task: idx=1074, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Comparing with item in queue: idx=1067, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Request to add task: idx=1075, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Comparing with item in queue: idx=1074, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Request to add task: idx=4978, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Comparing with item in queue: idx=1075, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.604 Debug: SQLH AddTask: Request to add task: idx=1077, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.605 Debug: SQLH AddTask: Comparing with item in queue: idx=1074, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.605 Debug: SQLH AddTask: Comparing with item in queue: idx=1075, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.605 Debug: SQLH AddTask: Comparing with item in queue: idx=4978, DelayTime=0.000000, Command='', Level=0, Color='{INVALID}', RelatedEvent=''
2023-06-20 00:00:00.632 Debug: SQLH: Do Task ItemType:14 Cmd: Value:47
2023-06-20 00:00:00.635 Debug: SQLH UpdateValueInt TS-451 Temp HwID:19 DevID:83067 Type:80 sType:5 nValue:0 sValue:47.00
2023-06-20 00:00:00.645 Debug: SQLH: Do Task ItemType:14 Cmd: Value:43
2023-06-20 00:00:00.648 Debug: SQLH UpdateValueInt TS-451 HDD1 Temp HwID:19 DevID:83074 Type:80 sType:5 nValue:0 sValue:43.00
2023-06-20 00:00:00.658 Debug: SQLH: Do Task ItemType:14 Cmd: Value:40
2023-06-20 00:00:00.660 Debug: SQLH UpdateValueInt TS-451 HDD2 Temp HwID:19 DevID:83075 Type:80 sType:5 nValue:0 sValue:40.00
2023-06-20 00:00:00.665 Debug: SQLH: Do Task ItemType:14 Cmd: Value:45
2023-06-20 00:00:00.667 Debug: SQLH UpdateValueInt TS-451 HDD4 Temp HwID:19 DevID:86978 Type:80 sType:5 nValue:0 sValue:45.00
2023-06-20 00:00:00.672 Debug: SQLH: Do Task ItemType:14 Cmd: Value:7:16:09:24.65
2023-06-20 00:00:00.675 Debug: SQLH UpdateValueInt NAS Uptime HwID:19 DevID:00083077 Type:243 sType:19 nValue:0 sValue:7:16:09:24.65
2023-06-20 00:00:01.324 Sunrise: 05:47:00 SunSet: 21:58:00
2023-06-20 00:00:01.325 Day length: 16:11:00 Sun at south: 13:53:00
2023-06-20 00:00:01.325 Civil twilight start: 05:04:00 Civil twilight end: 22:41:00
2023-06-20 00:00:01.325 Nautical twilight start: 04:03:00 Nautical twilight end: 23:42:00
2023-06-20 00:00:01.325 There is no astronomical twilight in the space of 24 hours
2023-06-20 00:00:01.395 Status: LUA: Heatzy Retour Etat Chambre : stop
2023-06-20 00:00:01.789 Status: LUA: Heatzy Retour Etat Salon : stop
2023-06-20 00:00:02.129 Status: LUA: Heatzy Retour Etat Salle de Bain : fro
2023-06-20 00:00:02.130 Status: EventSystem: reset all events...
2023-06-20 00:00:02.133 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/MyNAS.lua
2023-06-20 00:00:02.133 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Google nest hub script.lua
2023-06-20 00:00:02.392 Status: LUA: Mode actuel : Hors Gel
2023-06-20 00:00:02.394 Status: LUA: SDB Temperature 27.5
2023-06-20 00:00:02.394 Status: LUA: SDB Humidite 54
2023-06-20 00:00:02.394 Status: LUA: Temperature consigne du Thermostat 16.0
2023-06-20 00:00:02.394 Status: LUA: Temperature actuelle supérieure à la température de consigne
2023-06-20 00:00:02.394 Status: LUA: Le radiateur est en mode Hors Gel
2023-06-20 00:00:02.394 Status: LUA: Je ne fais rien
2023-06-20 00:00:02.401 Status: EventSystem: Script event triggered: ThermostatSdBFinal
2023-06-20 00:00:02.529 Error: Domoticz(pid:23981, tid:23992('MainWorker')) received fatal signal 6 (Aborted)
2023-06-20 00:00:02.529 Error: siginfo address=0x5dad, address=(nil)
2023-06-20 00:00:07.221 Error: Did not find stack frame for thread (LWP 23992)), printing full gdb output:
2023-06-20 00:00:07.221 Error: > gdb: warning: Couldn't determine a path for the index cache directory.
2023-06-20 00:00:07.221 Error: > [New LWP 23982]
2023-06-20 00:00:07.221 Error: > [New LWP 23983]
2023-06-20 00:00:07.221 Error: > [New LWP 23984]
2023-06-20 00:00:07.221 Error: > [New LWP 23985]
2023-06-20 00:00:07.221 Error: > [New LWP 23986]
2023-06-20 00:00:07.221 Error: > [New LWP 23987]
2023-06-20 00:00:07.221 Error: > [New LWP 23988]
2023-06-20 00:00:07.221 Error: > [New LWP 23989]
2023-06-20 00:00:07.221 Error: > [New LWP 23990]
2023-06-20 00:00:07.221 Error: > [New LWP 23991]
2023-06-20 00:00:07.221 Error: > [New LWP 23992]
2023-06-20 00:00:07.221 Error: > [New LWP 23993]
2023-06-20 00:00:07.221 Error: > [New LWP 23994]
2023-06-20 00:00:07.221 Error: > [New LWP 24000]
2023-06-20 00:00:07.221 Error: > [New LWP 24001]
2023-06-20 00:00:07.221 Error: > [New LWP 24002]
2023-06-20 00:00:07.222 Error: > [New LWP 24003]
2023-06-20 00:00:07.222 Error: > [New LWP 24004]
2023-06-20 00:00:07.222 Error: > [New LWP 24006]
2023-06-20 00:00:07.222 Error: > [New LWP 24007]
2023-06-20 00:00:07.222 Error: > [New LWP 24008]
2023-06-20 00:00:07.222 Error: > [New LWP 24009]
2023-06-20 00:00:07.222 Error: > [New LWP 24013]
2023-06-20 00:00:07.222 Error: > [New LWP 24014]
2023-06-20 00:00:07.222 Error: > [New LWP 24015]
2023-06-20 00:00:07.222 Error: > [New LWP 24016]
2023-06-20 00:00:07.222 Error: > [New LWP 24017]
2023-06-20 00:00:07.222 Error: > [New LWP 24018]
2023-06-20 00:00:07.222 Error: > [New LWP 24019]
2023-06-20 00:00:07.222 Error: > [New LWP 24020]
2023-06-20 00:00:07.222 Error: > [New LWP 24021]
2023-06-20 00:00:07.222 Error: > [New LWP 6028]
2023-06-20 00:00:07.222 Error: > [Thread debugging using libthread_db enabled]
2023-06-20 00:00:07.222 Error: > Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
2023-06-20 00:00:07.222 Error: > 0x768bbaec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ebd7938, req@entry=0x7ebd7930, rem=0x7ebd7948, rem@entry=0x7ebd7940) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2023-06-20 00:00:07.222 Error: > 52 ../sysdeps/unix/sysv/linux/clock_nanosleep.c: Aucun fichier ou dossier de ce type.
2023-06-20 00:00:07.222 Error: > Id Target Id Frame
2023-06-20 00:00:07.222 Error: > * 1 Thread 0x75dc0340 (LWP 23981) "domoticz" 0x768bbaec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ebd7938, req@entry=0x7ebd7930, rem=0x7ebd7948, rem@entry=0x7ebd7940) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2023-06-20 00:00:07.222 Error: > 2 Thread 0x758b2200 (LWP 23982) "Watchdog" 0x768bbaec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x758b1b70, req@entry=0x758b1b68, rem=0x758b1b80, rem@entry=0x758b1b78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2023-06-20 00:00:07.222 Error: > 3 Thread 0x750b1200 (LWP 23983) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.222 Error: > 4 Thread 0x748b0200 (LWP 23984) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.222 Error: > 5 Thread 0x73b0a200 (LWP 23985) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.222 Error: > 6 Thread 0x73309200 (LWP 23986) "Webem_ssncleane" 0x768fb1dc in epoll_wait (epfd=17, events=0x73308250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.222 Error: > 7 Thread 0x72b08200 (LWP 23987) "WebServer_8080" 0x768fb1dc in epoll_wait (epfd=13, events=0x72b07300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.222 Error: > 8 Thread 0x721ff200 (LWP 23988) "Webem_ssncleane" 0x768fb1dc in epoll_wait (epfd=24, events=0x721fe250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.222 Error: > 9 Thread 0x719fe200 (LWP 23989) "WebServer_443" 0x768fb1dc in epoll_wait (epfd=20, events=0x719fd300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.222 Error: > 10 Thread 0x70fff200 (LWP 23990) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.222 Error: > 11 Thread 0x707fe200 (LWP 23991) "TCPServer" 0x768fb1dc in epoll_wait (epfd=27, events=0x707fd330, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.222 Error: > 12 Thread 0x6fdff200 (LWP 23992) "MainWorker" 0x768c2034 in __GI___wait4 (pid=12611, stat_loc=0x6fdfdb10, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2023-06-20 00:00:07.223 Error: > 13 Thread 0x6f5fe200 (LWP 23993) "MainWorkerRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f5fdb80, clockid=<optimized out>, expected=0, futex_word=0xa6d034 <m_mainworker+4108>) at ../sysdeps/nptl/futex-internal.h:323
2023-06-20 00:00:07.223 Error: > 14 Thread 0x6e9ff200 (LWP 23994) "MiLight" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 15 Thread 0x6e1fe200 (LWP 24000) "RaspberryPi" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 16 Thread 0x6d9fd200 (LWP 24001) "RFLINK" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 17 Thread 0x6d1fc200 (LWP 24002) "Linky" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 18 Thread 0x6c7ff200 (LWP 24003) "Disk Usage" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 19 Thread 0x6bffe200 (LWP 24004) "IKEA Tradfri" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 20 Thread 0x6b7fd200 (LWP 24006) "RFLINK" 0x768fb1dc in epoll_wait (epfd=10, events=0x6b7fc2f8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.223 Error: > 21 Thread 0x6a9ff200 (LWP 24007) "Météo" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 22 Thread 0x6a1fe200 (LWP 24008) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a1fdbb0, clockid=<optimized out>, expected=0, futex_word=0xa6ca80 <m_mainworker+2648>) at ../sysdeps/nptl/futex-internal.h:323
2023-06-20 00:00:07.223 Error: > 23 Thread 0x699fd200 (LWP 24009) "Plugin_ASIO" futex_wait_cancelable (private=0, expected=0, futex_word=0x16e7b78) at ../sysdeps/nptl/futex-internal.h:186
2023-06-20 00:00:07.223 Error: > 24 Thread 0x68a9b200 (LWP 24013) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 25 Thread 0x37fff200 (LWP 24014) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 26 Thread 0x377fe200 (LWP 24015) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 27 Thread 0x36ffd200 (LWP 24016) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 28 Thread 0x367fc200 (LWP 24017) "IKEA Tradfri" 0x68b364f8 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 29 Thread 0x35ffb200 (LWP 24018) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 30 Thread 0x357fa200 (LWP 24019) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > 31 Thread 0x34fb9200 (LWP 24020) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.223 Error: > 32 Thread 0x347b8200 (LWP 24021) "EventSystemQueu" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x347b7ac0, clockid=<optimized out>, expected=0, futex_word=0xa6c184 <m_mainworker+348>) at ../sysdeps/nptl/futex-internal.h:323
2023-06-20 00:00:07.223 Error: > 33 Thread 0x325ff200 (LWP 6028) "IKEA Tradfri" 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > Thread 33 (Thread 0x325ff200 (LWP 6028) "IKEA Tradfri"):
2023-06-20 00:00:07.223 Error: > #0 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > #1 0x68afe0ac in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.223 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.223 Error: > Thread 32 (Thread 0x347b8200 (LWP 24021) "EventSystemQueu"):
2023-06-20 00:00:07.223 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x347b7ac0, clockid=<optimized out>, expected=0, futex_word=0xa6c184 <m_mainworker+348>) at ../sysdeps/nptl/futex-internal.h:323
2023-06-20 00:00:07.223 Error: > #1 __pthread_cond_wait_common (abstime=0x347b7ac0, clockid=<optimized out>, mutex=0x347b7a60, cond=0xa6c158 <m_mainworker+304>) at pthread_cond_wait.c:520
2023-06-20 00:00:07.224 Error: > #2 __pthread_cond_timedwait (cond=0xa6c158 <m_mainworker+304>, mutex=0x347b7a60, abstime=0x347b7ac0) at pthread_cond_wait.c:656
2023-06-20 00:00:07.224 Error: > #3 0x0020ac2c in CEventSystem::EventQueueThread() ()
2023-06-20 00:00:07.224 Error: > #4 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.224 Error: > #5 0x76a39310 in start_thread (arg=0x347b8200) at pthread_create.c:477
2023-06-20 00:00:07.224 Error: > #6 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.224 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.224 Error: > Thread 31 (Thread 0x34fb9200 (LWP 24020) "EventSystem"):
2023-06-20 00:00:07.224 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.224 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.224 Error: > #2 0x00201ba0 in CEventSystem::Do_Work() ()
2023-06-20 00:00:07.224 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.224 Error: > #4 0x76a39310 in start_thread (arg=0x34fb9200) at pthread_create.c:477
2023-06-20 00:00:07.224 Error: > #5 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.224 Error: > Thread 30 (Thread 0x357fa200 (LWP 24019) "IKEA Tradfri"):
2023-06-20 00:00:07.224 Error: > #0 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.224 Error: > #1 0x68afe0ac in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.224 Error: > Thread 29 (Thread 0x35ffb200 (LWP 24018) "IKEA Tradfri"):
2023-06-20 00:00:07.224 Error: > Thread 28 (Thread 0x367fc200 (LWP 24017) "IKEA Tradfri"):
2023-06-20 00:00:07.224 Error: > #0 0x68b364f8 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.224 Error: > #1 0x68afdc70 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.224 Error: > Thread 27 (Thread 0x36ffd200 (LWP 24016) "IKEA Tradfri"):
2023-06-20 00:00:07.225 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.225 Error: > Thread 26 (Thread 0x377fe200 (LWP 24015) "IKEA Tradfri"):
2023-06-20 00:00:07.225 Error: > #0 0x68b36230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.225 Error: > #1 0x68afe0ac in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.225 Error: > Thread 25 (Thread 0x37fff200 (LWP 24014) "IKEA Tradfri"):
2023-06-20 00:00:07.225 Error: > #1 0x68afe118 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
2023-06-20 00:00:07.225 Error: > Thread 24 (Thread 0x68a9b200 (LWP 24013) "IKEA Tradfri"):
2023-06-20 00:00:07.225 Error: > Thread 23 (Thread 0x699fd200 (LWP 24009) "Plugin_ASIO"):
2023-06-20 00:00:07.225 Error: > #0 futex_wait_cancelable (private=0, expected=0, futex_word=0x16e7b78) at ../sysdeps/nptl/futex-internal.h:186
2023-06-20 00:00:07.225 Error: > #1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x0, cond=0x16e7b50) at pthread_cond_wait.c:508
2023-06-20 00:00:07.225 Error: > #2 __pthread_cond_wait (cond=0x16e7b50, mutex=0x0) at pthread_cond_wait.c:638
2023-06-20 00:00:07.225 Error: > #3 0x003ce52c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2023-06-20 00:00:07.225 Error: > #4 0x0066f904 in Plugins::BoostWorkers() ()
2023-06-20 00:00:07.225 Error: > #5 0x00754c38 in thread_proxy ()
2023-06-20 00:00:07.225 Error: > #6 0x76a39310 in start_thread (arg=0x699fd200) at pthread_create.c:477
2023-06-20 00:00:07.225 Error: > #7 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.225 Error: > Thread 22 (Thread 0x6a1fe200 (LWP 24008) "NotificationSys"):
2023-06-20 00:00:07.225 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a1fdbb0, clockid=<optimized out>, expected=0, futex_word=0xa6ca80 <m_mainworker+2648>) at ../sysdeps/nptl/futex-internal.h:323
2023-06-20 00:00:07.225 Error: > #1 __pthread_cond_wait_common (abstime=0x6a1fdbb0, clockid=<optimized out>, mutex=0x6a1fdb58, cond=0xa6ca58 <m_mainworker+2608>) at pthread_cond_wait.c:520
2023-06-20 00:00:07.225 Error: > #2 __pthread_cond_timedwait (cond=0xa6ca58 <m_mainworker+2608>, mutex=0x6a1fdb58, abstime=0x6a1fdbb0) at pthread_cond_wait.c:656
2023-06-20 00:00:07.225 Error: > #3 0x0026e198 in CNotificationSystem::QueueThread() ()
2023-06-20 00:00:07.225 Error: > #4 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.226 Error: > #5 0x76a39310 in start_thread (arg=0x6a1fe200) at pthread_create.c:477
2023-06-20 00:00:07.226 Error: > #6 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.226 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.226 Error: > Thread 21 (Thread 0x6a9ff200 (LWP 24007) "Météo"):
2023-06-20 00:00:07.226 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.226 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.226 Error: > #2 0x00541568 in COpenWeatherMap::Do_Work() ()
2023-06-20 00:00:07.226 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.226 Error: > #4 0x76a39310 in start_thread (arg=0x6a9ff200) at pthread_create.c:477
2023-06-20 00:00:07.226 Error: > #5 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.226 Error: > Thread 20 (Thread 0x6b7fd200 (LWP 24006) "RFLINK"):
2023-06-20 00:00:07.226 Error: > #0 0x768fb1dc in epoll_wait (epfd=10, events=0x6b7fc2f8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.226 Error: > #1 0x003cc8c8 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2023-06-20 00:00:07.226 Error: > #2 0x003ce444 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2023-06-20 00:00:07.226 Error: > #3 0x003d04dc in boost::detail::thread_data<AsyncSerial::open(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int, boost::asio::serial_port_base::parity, boost::asio::serial_port_base::character_size, boost::asio::serial_port_base::flow_control, boost::asio::serial_port_base::stop_bits)::{lambda()#2}>::run() ()
2023-06-20 00:00:07.226 Error: > #4 0x00754c38 in thread_proxy ()
2023-06-20 00:00:07.226 Error: > #5 0x76a39310 in start_thread (arg=0x6b7fd200) at pthread_create.c:477
2023-06-20 00:00:07.226 Error: > Thread 19 (Thread 0x6bffe200 (LWP 24004) "IKEA Tradfri"):
2023-06-20 00:00:07.226 Error: > #2 0x0066c68c in Plugins::CPlugin::Do_Work() ()
2023-06-20 00:00:07.226 Error: > #4 0x76a39310 in start_thread (arg=0x6bffe200) at pthread_create.c:477
2023-06-20 00:00:07.226 Error: > Thread 18 (Thread 0x6c7ff200 (LWP 24003) "Disk Usage"):
2023-06-20 00:00:07.227 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.227 Error: > #2 0x0066c68c in Plugins::CPlugin::Do_Work() ()
2023-06-20 00:00:07.227 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.227 Error: > #4 0x76a39310 in start_thread (arg=0x6c7ff200) at pthread_create.c:477
2023-06-20 00:00:07.227 Error: > #5 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.227 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.227 Error: > Thread 17 (Thread 0x6d1fc200 (LWP 24002) "Linky"):
2023-06-20 00:00:07.227 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.227 Error: > #4 0x76a39310 in start_thread (arg=0x6d1fc200) at pthread_create.c:477
2023-06-20 00:00:07.227 Error: > Thread 16 (Thread 0x6d9fd200 (LWP 24001) "RFLINK"):
2023-06-20 00:00:07.227 Error: > #2 0x005c6e14 in CRFLinkSerial::Do_Work() ()
2023-06-20 00:00:07.227 Error: > #4 0x76a39310 in start_thread (arg=0x6d9fd200) at pthread_create.c:477
2023-06-20 00:00:07.227 Error: > Thread 15 (Thread 0x6e1fe200 (LWP 24000) "RaspberryPi"):
2023-06-20 00:00:07.227 Error: > #2 0x004a5ae8 in CHardwareMonitor::Do_Work() ()
2023-06-20 00:00:07.227 Error: > #4 0x76a39310 in start_thread (arg=0x6e1fe200) at pthread_create.c:477
2023-06-20 00:00:07.227 Error: > Thread 14 (Thread 0x6e9ff200 (LWP 23994) "MiLight"):
2023-06-20 00:00:07.228 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.228 Error: > #2 0x004d7ca0 in CLimitLess::Do_Work() ()
2023-06-20 00:00:07.228 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.228 Error: > #4 0x76a39310 in start_thread (arg=0x6e9ff200) at pthread_create.c:477
2023-06-20 00:00:07.228 Error: > #5 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.228 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.228 Error: > Thread 13 (Thread 0x6f5fe200 (LWP 23993) "MainWorkerRxMsg"):
2023-06-20 00:00:07.228 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f5fdb80, clockid=<optimized out>, expected=0, futex_word=0xa6d034 <m_mainworker+4108>) at ../sysdeps/nptl/futex-internal.h:323
2023-06-20 00:00:07.228 Error: > #1 __pthread_cond_wait_common (abstime=0x6f5fdb80, clockid=<optimized out>, mutex=0x6f5fdb28, cond=0xa6d008 <m_mainworker+4064>) at pthread_cond_wait.c:520
2023-06-20 00:00:07.228 Error: > #2 __pthread_cond_timedwait (cond=0xa6d008 <m_mainworker+4064>, mutex=0x6f5fdb28, abstime=0x6f5fdb80) at pthread_cond_wait.c:656
2023-06-20 00:00:07.228 Error: > #3 0x0025c758 in MainWorker::Do_Work_On_Rx_Messages() ()
2023-06-20 00:00:07.228 Error: > #4 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.228 Error: > #5 0x76a39310 in start_thread (arg=0x6f5fe200) at pthread_create.c:477
2023-06-20 00:00:07.228 Error: > #6 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.228 Error: > Thread 12 (Thread 0x6fdff200 (LWP 23992) "MainWorker"):
2023-06-20 00:00:07.228 Error: > #0 0x768c2034 in __GI___wait4 (pid=12611, stat_loc=0x6fdfdb10, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2023-06-20 00:00:07.228 Error: > #1 0x002868cc in dumpstack_gdb(bool) ()
2023-06-20 00:00:07.228 Error: > #2 0x00286e98 in signal_handler(int, siginfo_t*, void*) ()
2023-06-20 00:00:07.228 Error: > #3 <signal handler called>
2023-06-20 00:00:07.228 Error: > #4 raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2023-06-20 00:00:07.228 Error: > #5 <signal handler called>
2023-06-20 00:00:07.228 Error: > #6 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2023-06-20 00:00:07.228 Error: > #7 0x76836364 in __GI_abort () at abort.c:79
2023-06-20 00:00:07.228 Error: > #8 0x009054c8 in __gnu_cxx::__verbose_terminate_handler() ()
2023-06-20 00:00:07.228 Error: > #9 0x00868908 in __cxxabiv1::__terminate(void (*)()) ()
2023-06-20 00:00:07.228 Error: > #10 0x0086897c in std::terminate() ()
2023-06-20 00:00:07.228 Error: > #11 0x0087342c in __cxa_throw ()
2023-06-20 00:00:07.228 Error: > #12 0x008a0c30 in std::__throw_invalid_argument(char const*) ()
2023-06-20 00:00:07.228 Error: > #13 0x00287350 in unsigned long long __gnu_cxx::__stoa<unsigned long long, unsigned long long, char, int>(unsigned long long (*)(char const*, char**, int), char const*, char const*, unsigned int*, int) [clone .constprop.1126] ()
2023-06-20 00:00:07.228 Error: > #14 0x00291bb4 in CSQLHelper::AddCalendarUpdatePercentage() ()
2023-06-20 00:00:07.228 Error: > #15 0x0029ff60 in CSQLHelper::ScheduleDay() ()
2023-06-20 00:00:07.228 Error: > #16 0x00258e8c in MainWorker::Do_Work() ()
2023-06-20 00:00:07.229 Error: > #17 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.229 Error: > #18 0x76a39310 in start_thread (arg=0x6fdff200) at pthread_create.c:477
2023-06-20 00:00:07.229 Error: > #19 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.229 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.229 Error: > Thread 11 (Thread 0x707fe200 (LWP 23991) "TCPServer"):
2023-06-20 00:00:07.229 Error: > #0 0x768fb1dc in epoll_wait (epfd=27, events=0x707fd330, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.229 Error: > #1 0x003cc8c8 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2023-06-20 00:00:07.229 Error: > #2 0x003ce444 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2023-06-20 00:00:07.229 Error: > #3 0x006c1768 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
2023-06-20 00:00:07.229 Error: > #4 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.229 Error: > #5 0x76a39310 in start_thread (arg=0x707fe200) at pthread_create.c:477
2023-06-20 00:00:07.229 Error: > #6 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.229 Error: > Thread 10 (Thread 0x70fff200 (LWP 23990) "Scheduler"):
2023-06-20 00:00:07.229 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.229 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.229 Error: > #2 0x0027e5b0 in CScheduler::Do_Work() ()
2023-06-20 00:00:07.229 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.229 Error: > #4 0x76a39310 in start_thread (arg=0x70fff200) at pthread_create.c:477
2023-06-20 00:00:07.229 Error: > #5 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.229 Error: > Thread 9 (Thread 0x719fe200 (LWP 23989) "WebServer_443"):
2023-06-20 00:00:07.229 Error: > #0 0x768fb1dc in epoll_wait (epfd=20, events=0x719fd300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.229 Error: > #3 0x00705e50 in http::server::server_base::run() ()
2023-06-20 00:00:07.229 Error: > #4 0x002cf3a8 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#294}> > >::_M_run() ()
2023-06-20 00:00:07.229 Error: > #5 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.229 Error: > #6 0x76a39310 in start_thread (arg=0x719fe200) at pthread_create.c:477
2023-06-20 00:00:07.229 Error: > #7 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.229 Error: > Thread 8 (Thread 0x721ff200 (LWP 23988) "Webem_ssncleane"):
2023-06-20 00:00:07.230 Error: > #0 0x768fb1dc in epoll_wait (epfd=24, events=0x721fe250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.230 Error: > #1 0x003cc8c8 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2023-06-20 00:00:07.230 Error: > #2 0x003ce444 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2023-06-20 00:00:07.230 Error: > #3 0x006dc290 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2023-06-20 00:00:07.230 Error: > #4 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.230 Error: > #5 0x76a39310 in start_thread (arg=0x721ff200) at pthread_create.c:477
2023-06-20 00:00:07.230 Error: > #6 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.230 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.230 Error: > Thread 7 (Thread 0x72b08200 (LWP 23987) "WebServer_8080"):
2023-06-20 00:00:07.230 Error: > #0 0x768fb1dc in epoll_wait (epfd=13, events=0x72b07300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.230 Error: > #3 0x00705e50 in http::server::server_base::run() ()
2023-06-20 00:00:07.230 Error: > #4 0x002cf3a8 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#294}> > >::_M_run() ()
2023-06-20 00:00:07.230 Error: > #5 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.230 Error: > #6 0x76a39310 in start_thread (arg=0x72b08200) at pthread_create.c:477
2023-06-20 00:00:07.230 Error: > #7 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.230 Error: > Thread 6 (Thread 0x73309200 (LWP 23986) "Webem_ssncleane"):
2023-06-20 00:00:07.230 Error: > #0 0x768fb1dc in epoll_wait (epfd=17, events=0x73308250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2023-06-20 00:00:07.230 Error: > #5 0x76a39310 in start_thread (arg=0x73309200) at pthread_create.c:477
2023-06-20 00:00:07.230 Error: > Thread 5 (Thread 0x73b0a200 (LWP 23985) "InfluxPush"):
2023-06-20 00:00:07.230 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.230 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.230 Error: > #2 0x0038ab9c in CInfluxPush::Do_Work() ()
2023-06-20 00:00:07.230 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.231 Error: > #4 0x76a39310 in start_thread (arg=0x73b0a200) at pthread_create.c:477
2023-06-20 00:00:07.231 Error: > #5 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.231 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2023-06-20 00:00:07.231 Error: > Thread 4 (Thread 0x748b0200 (LWP 23984) "PluginMgr"):
2023-06-20 00:00:07.231 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2023-06-20 00:00:07.231 Error: > #1 0x008b943c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2023-06-20 00:00:07.231 Error: > #2 0x00670014 in Plugins::CPluginSystem::Do_Work() ()
2023-06-20 00:00:07.231 Error: > #3 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.231 Error: > #4 0x76a39310 in start_thread (arg=0x748b0200) at pthread_create.c:477
2023-06-20 00:00:07.231 Error: > Thread 3 (Thread 0x750b1200 (LWP 23983) "SQLHelper"):
2023-06-20 00:00:07.231 Error: > #2 0x0029c820 in CSQLHelper::Do_Work() ()
2023-06-20 00:00:07.231 Error: > #4 0x76a39310 in start_thread (arg=0x750b1200) at pthread_create.c:477
2023-06-20 00:00:07.231 Error: > Thread 2 (Thread 0x758b2200 (LWP 23982) "Watchdog"):
2023-06-20 00:00:07.231 Error: > #0 0x768bbaec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x758b1b70, req@entry=0x758b1b68, rem=0x758b1b80, rem@entry=0x758b1b78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2023-06-20 00:00:07.231 Error: > #1 0x768bbbe0 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x758b1bb0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2023-06-20 00:00:07.231 Error: > #2 0x768c2390 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2023-06-20 00:00:07.231 Error: > #3 0x0021cf5c in sleep_milliseconds(long) ()
2023-06-20 00:00:07.231 Error: > #4 0x00287034 in Do_Watchdog_Work() ()
2023-06-20 00:00:07.231 Error: > #5 0x008db9cc in execute_native_thread_routine ()
2023-06-20 00:00:07.231 Error: > #6 0x76a39310 in start_thread (arg=0x758b2200) at pthread_create.c:477
2023-06-20 00:00:07.231 Error: > #7 0x768fada8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2023-06-20 00:00:07.231 Error: > Thread 1 (Thread 0x75dc0340 (LWP 23981) "domoticz"):
2023-06-20 00:00:07.231 Error: > #0 0x768bbaec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ebd7938, req@entry=0x7ebd7930, rem=0x7ebd7948, rem@entry=0x7ebd7940) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2023-06-20 00:00:07.231 Error: > #1 0x768bbbe0 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7ebd7978) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2023-06-20 00:00:07.232 Error: > #2 0x768c2390 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2023-06-20 00:00:07.232 Error: > #3 0x0021cec8 in sleep_seconds(long) ()
2023-06-20 00:00:07.232 Error: > #4 0x001ae8c4 in main ()
2023-06-20 00:00:07.232 Error: > Main thread:
2023-06-20 00:00:07.232 Error: > #0 0x768bbaec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ebd7938, req@entry=0x7ebd7930, rem=0x7ebd7948, rem@entry=0x7ebd7940) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2023-06-20 00:00:07.232 Error: > #1 0x768bbbe0 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7ebd7978) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2023-06-20 00:00:07.232 Error: > [Inferior 1 (process 23981) detached]
Version: 2024.1
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Kedi
- Domoticz version: latest
Look for a strange value in the table(s) Percentage and/or Percentage_Calendar.
redfirebrooks
indeed in percentage table I have strange values
DeviceRowId
ef9c53ced687a9e4ca66bfb2c5fb6ae0
e9025063d116445316bf8829679972f0
b3fc368791a4cc7cd39c1e299912009f
8e070a66619dae7db5da46f8b4daa70c
DeviceRowId
Version: 2024.1
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Kedi
Just make a copy of the database and delete those rows.
redfirebrooks
Hello, I have deleted the rows but new crash occurred at midnight. The crash log is different :
[New LWP 862]
[New LWP 863]
[New LWP 864]
[New LWP 886]
[New LWP 887]
[New LWP 889]
[New LWP 890]
[New LWP 891]
[New LWP 892]
[New LWP 893]
[New LWP 894]
[New LWP 895]
[New LWP 931]
[New LWP 937]
[New LWP 938]
[New LWP 939]
[New LWP 940]
[New LWP 941]
[New LWP 943]
[New LWP 978]
[New LWP 979]
[New LWP 980]
[New LWP 981]
[New LWP 982]
[New LWP 983]
[New LWP 1017]
[New LWP 1029]
[New LWP 1030]
[New LWP 1031]
[New LWP 1044]
[New LWP 1045]
0x76962aec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7eaf2988, req@entry=0x7eaf2980, rem=0x7eaf2998, rem@entry=0x7eaf2990) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
Id Target Id Frame
* 1 Thread 0x75e67340 (LWP 861) "domoticz" 0x76962aec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7eaf2988, req@entry=0x7eaf2980, rem=0x7eaf2998, rem@entry=0x7eaf2990) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2 Thread 0x75959200 (LWP 862) "Watchdog" 0x76969034 in __GI___wait4 (pid=993, stat_loc=0x75958368, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
3 Thread 0x75158200 (LWP 863) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
4 Thread 0x74957200 (LWP 864) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
5 Thread 0x73bb1200 (LWP 886) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
6 Thread 0x733b0200 (LWP 887) "Webem_ssncleane" 0x769a21dc in epoll_wait (epfd=16, events=0x733af250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
7 Thread 0x72b8e200 (LWP 889) "WebServer_8080" 0x769a21dc in epoll_wait (epfd=12, events=0x72b8d300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
8 Thread 0x721ff200 (LWP 890) "Webem_ssncleane" 0x769a21dc in epoll_wait (epfd=23, events=0x721fe250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
9 Thread 0x719fe200 (LWP 891) "WebServer_443" 0x769a21dc in epoll_wait (epfd=19, events=0x719fd300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
10 Thread 0x70fff200 (LWP 892) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
11 Thread 0x707fe200 (LWP 893) "TCPServer" 0x769a21dc in epoll_wait (epfd=26, events=0x707fd330, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
12 Thread 0x6fdff200 (LWP 894) "MainWorker" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
13 Thread 0x6f5fe200 (LWP 895) "MainWorkerRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f5fdb80, clockid=<optimized out>, expected=0, futex_word=0xa6d030 <m_mainworker+4104>) at ../sysdeps/nptl/futex-internal.h:323
14 Thread 0x6e9ff200 (LWP 931) "MiLight" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
15 Thread 0x6e1fe200 (LWP 937) "RaspberryPi" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
16 Thread 0x6d9fd200 (LWP 938) "RFLINK" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
17 Thread 0x6d1fc200 (LWP 939) "Linky" 0x75a62e30 in PyDict_SetItem () from /usr/lib/arm-linux-gnueabihf/libpython3.9.so
18 Thread 0x6c7ff200 (LWP 940) "Disk Usage" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
19 Thread 0x6bffe200 (LWP 941) "IKEA Tradfri" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
20 Thread 0x6b7fd200 (LWP 943) "RFLINK" 0x769a21dc in epoll_wait (epfd=9, events=0x6b7fc2f8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
21 Thread 0x6a64a200 (LWP 978) "IKEA Tradfri" 0x6a6e54f8 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
22 Thread 0x397ff200 (LWP 979) "IKEA Tradfri" 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
23 Thread 0x38ffe200 (LWP 980) "IKEA Tradfri" 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
24 Thread 0x387fd200 (LWP 981) "IKEA Tradfri" 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
25 Thread 0x37ffc200 (LWP 982) "IKEA Tradfri" 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
26 Thread 0x377fb200 (LWP 983) "IKEA Tradfri" 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
27 Thread 0x36ffa200 (LWP 1017) "IKEA Tradfri" 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
28 Thread 0x367f9200 (LWP 1029) "Météo" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
29 Thread 0x35ff8200 (LWP 1030) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x35ff7bb0, clockid=<optimized out>, expected=0, futex_word=0xa6ca84 <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
30 Thread 0x357f7200 (LWP 1031) "Plugin_ASIO" futex_wait_cancelable (private=0, expected=0, futex_word=0xee5b78) at ../sysdeps/nptl/futex-internal.h:186
31 Thread 0x34ff6200 (LWP 1044) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
32 Thread 0x341ff200 (LWP 1045) "EventSystemQueu" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x341fe6f8, clockid=<optimized out>, expected=0, futex_word=0x6ec1e7a0) at ../sysdeps/nptl/futex-internal.h:323
Thread 32 (Thread 0x341ff200 (LWP 1045) "EventSystemQueu"):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x341fe6f8, clockid=<optimized out>, expected=0, futex_word=0x6ec1e7a0) at ../sysdeps/nptl/futex-internal.h:323
#1 __pthread_cond_wait_common (abstime=0x341fe6f8, clockid=<optimized out>, mutex=0x8562a0 <l_alloc+32>, cond=0x6ec1e778) at pthread_cond_wait.c:520
#2 __pthread_cond_timedwait (cond=0x6ec1e778, mutex=0x8562a0 <l_alloc+32>, abstime=0x341fe6f8) at pthread_cond_wait.c:656
#3 0x00754f1c in boost::thread::do_try_join_until_noexcept(boost::detail::mono_platform_timepoint const&, bool&) ()
#4 0x00208898 in CEventSystem::EvaluateLua(std::vector<CEventSystem::_tEventQueue, std::allocator<CEventSystem::_tEventQueue> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#5 0x00208e6c in CEventSystem::EvaluateLua(CEventSystem::_tEventQueue const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#6 0x002095c8 in CEventSystem::EvaluateDatabaseEvents(CEventSystem::_tEventQueue const&) ()
#7 0x00209ad0 in CEventSystem::EvaluateEvent(std::vector<CEventSystem::_tEventQueue, std::allocator<CEventSystem::_tEventQueue> > const&) ()
#8 0x0020afe8 in CEventSystem::EventQueueThread() ()
#9 0x008db9cc in execute_native_thread_routine ()
#10 0x76ae0310 in start_thread (arg=0x341ff200) at pthread_create.c:477
#11 0x769a1da8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 31 (Thread 0x34ff6200 (LWP 1044) "EventSystem"):
#4 0x76ae0310 in start_thread (arg=0x34ff6200) at pthread_create.c:477
#5 0x769a1da8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 30 (Thread 0x357f7200 (LWP 1031) "Plugin_ASIO"):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0xee5b78) at ../sysdeps/nptl/futex-internal.h:186
#1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x0, cond=0xee5b50) at pthread_cond_wait.c:508
#2 __pthread_cond_wait (cond=0xee5b50, mutex=0x0) at pthread_cond_wait.c:638
#6 0x76ae0310 in start_thread (arg=0x357f7200) at pthread_create.c:477
#7 0x769a1da8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 29 (Thread 0x35ff8200 (LWP 1030) "NotificationSys"):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x35ff7bb0, clockid=<optimized out>, expected=0, futex_word=0xa6ca84 <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
#1 __pthread_cond_wait_common (abstime=0x35ff7bb0, clockid=<optimized out>, mutex=0x35ff7b58, cond=0xa6ca58 <m_mainworker+2608>) at pthread_cond_wait.c:520
#2 __pthread_cond_timedwait (cond=0xa6ca58 <m_mainworker+2608>, mutex=0x35ff7b58, abstime=0x35ff7bb0) at pthread_cond_wait.c:656
#5 0x76ae0310 in start_thread (arg=0x35ff8200) at pthread_create.c:477
#6 0x769a1da8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 28 (Thread 0x367f9200 (LWP 1029) "Météo"):
#4 0x76ae0310 in start_thread (arg=0x367f9200) at pthread_create.c:477
Thread 27 (Thread 0x36ffa200 (LWP 1017) "IKEA Tradfri"):
#0 0x6a6e5230 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
#1 0x6a6ad0ac in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
Thread 26 (Thread 0x377fb200 (LWP 983) "IKEA Tradfri"):
Thread 25 (Thread 0x37ffc200 (LWP 982) "IKEA Tradfri"):
Thread 24 (Thread 0x387fd200 (LWP 981) "IKEA Tradfri"):
Thread 23 (Thread 0x38ffe200 (LWP 980) "IKEA Tradfri"):
Thread 22 (Thread 0x397ff200 (LWP 979) "IKEA Tradfri"):
#1 0x6a6ad118 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
Thread 21 (Thread 0x6a64a200 (LWP 978) "IKEA Tradfri"):
#0 0x6a6e54f8 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
#1 0x6a6acc70 in ?? () from /usr/local/lib/python3.9/dist-packages/_py3coap.cpython-39-arm-linux-gnueabihf.so
Thread 20 (Thread 0x6b7fd200 (LWP 943) "RFLINK"):
#0 0x769a21dc in epoll_wait (epfd=9, events=0x6b7fc2f8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76ae0310 in start_thread (arg=0x6b7fd200) at pthread_create.c:477
Thread 19 (Thread 0x6bffe200 (LWP 941) "IKEA Tradfri"):
#4 0x76ae0310 in start_thread (arg=0x6bffe200) at pthread_create.c:477
Thread 18 (Thread 0x6c7ff200 (LWP 940) "Disk Usage"):
#4 0x76ae0310 in start_thread (arg=0x6c7ff200) at pthread_create.c:477
Thread 17 (Thread 0x6d1fc200 (LWP 939) "Linky"):
#0 0x75a62e30 in PyDict_SetItem () from /usr/lib/arm-linux-gnueabihf/libpython3.9.so
#1 0x759d7ea8 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.9.so
#2 0x00000000 in ?? ()
Thread 16 (Thread 0x6d9fd200 (LWP 938) "RFLINK"):
#4 0x76ae0310 in start_thread (arg=0x6d9fd200) at pthread_create.c:477
Thread 15 (Thread 0x6e1fe200 (LWP 937) "RaspberryPi"):
#4 0x76ae0310 in start_thread (arg=0x6e1fe200) at pthread_create.c:477
Thread 14 (Thread 0x6e9ff200 (LWP 931) "MiLight"):
#4 0x76ae0310 in start_thread (arg=0x6e9ff200) at pthread_create.c:477
Thread 13 (Thread 0x6f5fe200 (LWP 895) "MainWorkerRxMsg"):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f5fdb80, clockid=<optimized out>, expected=0, futex_word=0xa6d030 <m_mainworker+4104>) at ../sysdeps/nptl/futex-internal.h:323
#5 0x76ae0310 in start_thread (arg=0x6f5fe200) at pthread_create.c:477
Thread 12 (Thread 0x6fdff200 (LWP 894) "MainWorker"):
#2 0x00258754 in MainWorker::Do_Work() ()
#4 0x76ae0310 in start_thread (arg=0x6fdff200) at pthread_create.c:477
Thread 11 (Thread 0x707fe200 (LWP 893) "TCPServer"):
#0 0x769a21dc in epoll_wait (epfd=26, events=0x707fd330, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76ae0310 in start_thread (arg=0x707fe200) at pthread_create.c:477
Thread 10 (Thread 0x70fff200 (LWP 892) "Scheduler"):
#4 0x76ae0310 in start_thread (arg=0x70fff200) at pthread_create.c:477
Thread 9 (Thread 0x719fe200 (LWP 891) "WebServer_443"):
#0 0x769a21dc in epoll_wait (epfd=19, events=0x719fd300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#6 0x76ae0310 in start_thread (arg=0x719fe200) at pthread_create.c:477
Thread 8 (Thread 0x721ff200 (LWP 890) "Webem_ssncleane"):
#0 0x769a21dc in epoll_wait (epfd=23, events=0x721fe250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76ae0310 in start_thread (arg=0x721ff200) at pthread_create.c:477
Thread 7 (Thread 0x72b8e200 (LWP 889) "WebServer_8080"):
#0 0x769a21dc in epoll_wait (epfd=12, events=0x72b8d300, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#6 0x76ae0310 in start_thread (arg=0x72b8e200) at pthread_create.c:477
Thread 6 (Thread 0x733b0200 (LWP 887) "Webem_ssncleane"):
#0 0x769a21dc in epoll_wait (epfd=16, events=0x733af250, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76ae0310 in start_thread (arg=0x733b0200) at pthread_create.c:477
Thread 5 (Thread 0x73bb1200 (LWP 886) "InfluxPush"):
#4 0x76ae0310 in start_thread (arg=0x73bb1200) at pthread_create.c:477
Thread 4 (Thread 0x74957200 (LWP 864) "PluginMgr"):
#4 0x76ae0310 in start_thread (arg=0x74957200) at pthread_create.c:477
Thread 3 (Thread 0x75158200 (LWP 863) "SQLHelper"):
#4 0x76ae0310 in start_thread (arg=0x75158200) at pthread_create.c:477
Thread 2 (Thread 0x75959200 (LWP 862) "Watchdog"):
#0 0x76969034 in __GI___wait4 (pid=993, stat_loc=0x75958368, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
#2 0x00286dd0 in signal_handler(int, siginfo_t*, void*) ()
#4 raise (sig=10) at ../sysdeps/unix/sysv/linux/raise.c:50
#5 0x0028709c in Do_Watchdog_Work() ()
#6 0x008db9cc in execute_native_thread_routine ()
#7 0x76ae0310 in start_thread (arg=0x75959200) at pthread_create.c:477
#8 0x769a1da8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 1 (Thread 0x75e67340 (LWP 861) "domoticz"):
#0 0x76962aec in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7eaf2988, req@entry=0x7eaf2980, rem=0x7eaf2998, rem@entry=0x7eaf2990) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
#1 0x76962be0 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7eaf29c8) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
#2 0x76969390 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
Main thread:
[Inferior 1 (process 861) detached]
Version: 2024.1
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Kedi
This might be a tough one.
It might be that, due the daily 'cleanup' of the database was not running for some time, those tables are 'over' filled and it takes too long to process.
Could you check if in tables like Percentage, Meter, Multimeter is more data present than is 'allowed' by the Setup -> Settings -> Log History settings?
Also look in Domoticz at several devices logs to see if there is any abnormally visible.
redfirebrooks
So in my setting I have
Light/Switch 30 days
Short log sensors 7 days
I have quickly checked the percentage table and the oldest values are from june the 19th
But it didn't crash since the last time I have reported... so strange
Version: 2024.1
Build Hash: 5279c8261
Compile Date: 2024-01-01 12:59:22
dzVents Version: 3.1.8
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
