mqtt switch (light)
HarryHase
Domoticz version: stable
mqtt switch (light)
Post by HarryHase »
I have a problem with switches over mqtt.
Version: 2023.1
switch (light) idx: 85
Switch-tasmota
When i click on this switch the light switches on and off, this is working fine.
Problem:
mosquitto_pub -h localhost -t "domoticz/in" -m '{ "idx" : 85, "nvalue" : 1}'
change the status in domoticz to on, but the switch doesn't switches ON
(same with 0 and off)
The status in domoticz ist correct, but it is not the same as clicking with the mouse.
I want to send a command over mqtt wich has the same effect as clicking on the UI?!
FireWizard
Re: mqtt switch (light)
Post by FireWizard »
Hi, @HarryHase,
May I guess? Your light is controlled by a Tasmota switch, using MQTT.
In this case an incoming MQTT message is not republished to domoticz/out and the light will not be turned On or Off.
In order to change that, configure the "Prevent loop" setting of the MQTT hardware to "false".
Last edited by FireWizard on Wednesday 18 September 2024 11:54, edited 1 time in total.
HarryHase
Post by HarryHase »
thx, that is a partitial solution for the direct connected tasmota switches; Partitial, because:
i also have a virtual switch which starts a bash-script (sending a couple of commands to ir-tasmota-device) on the domoticz server, this is also not working, so it is not the same as clicking on the UI.
Screenshot 2023-06-14 084206.jpg (59.22 KiB) Viewed 8750 times
Perhaps if you send a message like
{"command": "switchlight", "idx": 71, "switchcmd": "On" }
FireWizard
Hello @HarryHase,
I conclude, that you have 2 issues, which you describe in one post.
These issues have no relationship and are quite different.
1. Did the change of the setting of "Prevent Loop" to "False" solved the issue with the Tasmota device?
Can you confirm?
2. The issue with the bash script is another issue.
I do not know the contents of drei_ein.sh or drei_aus. sh. Obviously the two scripts are on an USB stick.
These scripts should be in the script directory. Then it could point to another location.
See: https://www.domoticz.com/wiki/Scripting_in_Domoticz
There could be several causes.
1. Perhaps a stupid question to start with: Is the USB stick mounted?
2. Do the access rights match with the Domoticz user?
3. Are the scripts executable?
4. Have you tried to run the scripts from the command line in the script directory. and do they work?
If not what are the error messages?
Please ignore the post of @waltervl.
This represents the MQTT command (payload) from an external source into Domoticz and this is not what you are looking for.
What i think @HarryHase means is that when he switches the switch from the user interface the actions scripts are triggered and working but when he sends a mqtt message to domoticz/in to switch the switch the action scripts are not triggered...
But ignore me if I am incorrect ... ;)
HarryHase
Post by HarryHase »
correct;
curious, the switch state (on/off) is working in domoticz
HarryHase wrote: Wednesday 14 June 2023 20:11 correct;
And my suggestion about different mqtt payload to switch also did not work/trigger the scripts?
HarryHase
Post by HarryHase »
summary (which don't understand, why)
1)
 mosquitto_pub -h 192.168.64.7 -t "domoticz/in" -m '{ "idx" : 171, "nvalue" : 1}'
is changing the state in the UI, but not triggering the script
2)
mosquitto_pub -h 192.168.64.7 -t "domoticz/in" -m '{"command": "switchlight", "idx": 171, "switchcmd": "On" }'
is changing the state in the UI AND is triggering the script
prevent loop: false (that was for the first issue to get the tasmota switches working)
The second command is the documented way to switch a switch with MQTT Domoticz. See the wiki https://www.domoticz.com/wiki/MQTT#Send ... ch_Command
FireWizard
Hi @HarryHase and @waltervl,
In the first command the "command" is missing, so it defaults to "udevice", which will only update the device.
