Dashticz v3.10.5 beta
Posted: Tuesday 06 June 2023 20:58
by Lokonli
In the latest Domoticz versions (build 15327, beginning of June) some changes have been implemented in the API that is used by Dashticz.
This new Dashticz beta release supports the new Domoticz API while maintaining backwards compatibility for older Domoticz versions.
So if you have updated Domoticz, and encounter some issues using Dashticz (graphs not working, warnings in the Domoticz log) please update to this Dashticz version v3.10.5
Please leave a remark here if you have tested this Dashticz version. If everything is working I'll release a new master version.
Re: Dashticz v3.10.5 beta
Posted: Saturday 19 August 2023 23:22
by solarboy
I'm using the new Beta now, I was on a very old version, about 3 years old. I have a dual filled line graph of solar power and consumed power, overlaid. The graphs were filled red below the line for consumed power, and green for solar with solar on top. It used to work great with a visual red zone of "paid for" energy use and a green area that covered the red of solar power.
Since I updated due to the "deprecated" Domoticz log spam issue my graphs seem to have failed and the red area is inconsistently rendered, sometimes showing red and sometimes a shadow type effect.
Also, the latest Beta would not load on my ancient RpiStretch/kiosk/Chromium browser (failed with a generic "error" or stuck at "Dashticz V3 is loading") but this error could have happened many versions ago as I haven't updated in ages (if it 'aint broke don't try to fix it). I've updated to Bullseye on the Kiosk now and it does load but with the glitchy graph. Perhaps there were some changes to graphing I am unaware of.
I'm not sure if it's possible to post images to the forum...
Posted: Sunday 20 August 2023 2:02
by HansieNL
You can use Full Editor & Preview - Select the Attachments tab - Add files. You can then select the added files in your message.
Hope this will help you to be be able to post your image(s)
Posted: Sunday 20 August 2023 17:23
by solarboy
HansieNL wrote: Sunday 20 August 2023 2:02 You can use Full Editor & Preview - Select the Attachments tab - Add files. You can then select the added files in your message.
Brilliant, thanks for that tip !
So the 2 graphs:
Old Dashticz gave me this result...
graph OLD.jpg (42.44 KiB) Viewed 2436 times
And since I upgraded the same data gives me this...
My Block is:
blocks['powergraph'] = {
devices: [595,719],
title: 'x',
custom:{
graph: ['line','line'],
lineFill: true,
height: '150px',
legend: false,
ylabels: ['W'],
range: 'today',
filter: '24 hours',
datasetColors: ['forestgreen','red'],
lineTension: 0.1,
maxTicksLimit: 9,
decimals: 0,
Which is in config.js
(originally "range" was set to 'daily' and not 'today')
I'm not sure what changed but in the new image you can see the peaks seem to be greyed out.
The data in Domoticz looks like this:
Solar (KWh), Power Use (W)
Posted: Sunday 20 August 2023 20:06
by Lokonli
Since a few releases, a Domoticz energy device receives both the actual power and the hourly energy usage graph data.
That means you receive 3 or 4 datasets for your graph, since you are combining two devices.
I think you have to add a third 'dataSetColors'-element, and a third 'graph'-element.
If you set legend:true, you can see the different datasets that have been collected.
Posted: Monday 21 August 2023 16:52
by solarboy
Lokonli wrote: Sunday 20 August 2023 20:06 Since a few releases, a Domoticz energy device receives both the actual power and the hourly energy usage graph data.
Thank you soo much for this, I am definitely heading in the right direction. You were right ; turns out device 595 is now 2 sub-devices, "v_595" and "eu_595" so I changed the draw order and added a "grey" for the 3rd device/subdevice. However this block now covers the green area.
devices: [719,'595'],
title: 'x',
custom:{
lineFill: true,
height: '150px',
legend: true,
ylabels: ['W'],
range: 'today',
filter: '24 hours',
datasetColors: ['red','forestgreen','grey'],
lineTension: 0.4,
maxTicksLimit: 9,
decimals: 0,
I tried changing '595' to '595_1' but the graph would then not display with an error underneath saying "For graph powergraph device 595_1 does not exist" despite '595_1' working fine for another block where I just show the actual current value.
So I am a bit stumped on how to refer to the sub-device for the graph. Otherwise, definitely some progress !
Posted: Monday 21 August 2023 22:30
by Lokonli
What would you like to achieve?
With the graphTypes block parameter you can select which datasets to show.
For instance, add the following:
   graphTypes: ['u', 'v'],
You have selected to fill the line graphs. You can also play with the colors and use transparant colors instead of solid colors.
Or change the draw order.
Most info can be found in the documentation:
https://dashticz.readthedocs.io/en/mast ... raphs.html
edit: Originally there was a typo in the code block above. Accidentally I typed blockTypes instead of graphTypes
Posted: Tuesday 22 August 2023 13:22
by solarboy
Once again, thanks for your help.
My intention is to end up with something like my original graph which gives a clear visual warning of lots of imported power while also showing the amount of solar generated. At a glance it gives me and the rest of the family plenty of data to make decisions regarding power use and/or problems in the home.
I tried "blockTypes" and also "graphTypes" but to no avail. I also tried transparency but applying it only to the "eu_595" dataset also applied the style to the "v_595" dataset. I have almost got it going by colouring the unwanted "eu_595" data set the same red as "v-595" with my final Block definition being...
devices: [595,719],
title: false,
custom:{
graph: ['line','line','line'],
lineFill: [false,true,true],
displayFormats: false,
height: '150px',
legend: false,
blockTypes: ['u','v'],
ylabels: ['W'],
range: 'day',
drawOrderDay: ['v_595','u_719','eu_595'],
filter: '24 hours',
datasetColors: ['forestgreen','forestgreen','red'],
lineTension: 0.4,
maxTicksLimit: 9,
decimals: 0,
Giving this result..
Which is close enough to what I wanted. You can still see the blocking of the KWh dataset rather than the smooth curve of the W dataset but it's close enough. Thanks for your pointer,s you definitely helped my find a solution. Now onwards to getting my calender working again....
Posted: Tuesday 22 August 2023 18:44
by Lokonli
It should work ...
Start with a basic graph combining a 'usage electric' and a 'general - kWh' device:
blocks['gr'] = {
    devices: [1396, 6],
    type: 'graph',
    legend: true,
This gives:
As you can see, device 1396 provides dataset 'u', device 6 provides datasets 'v' and 'eu'.
Now remove the 'eu' dataset by defining graphTypes parameter (case sensitive):
blocks['gr'] = {
    devices: [1396, 6],
    type: 'graph',
    legend: true,
    graphTypes: ['v','u']
This gives:
Now we can start coloring the chart area.
blocks['gr'] = {
    devices: [1396, 6],
    type: 'graph',
    legend: true,
    graphTypes: ['v','u'],
    datasetColors: ['rgba(44,130,201,0.5)', 'rgba(201,130,44,0.5)'],
    lineFill: [true, true],
    drawOrderLast: ['v_6','u_1396']
I think this is what you would like to have. Enjoy :)
Posted: Tuesday 22 August 2023 23:05
by solarboy
Amazing !
I adapted your block definition to the colours and transparency I wanted and added a "scales" definition so they both share the same scale which I set at my maximum utility supply of 7000W. Now it's exactly how I wanted it and I couldn't have done it without your help.
    devices: [595, 719],
    type: 'graph',
    legend: false,
    datasetColors: ['rgba(0,255,0,1)', 'rgba(255,0,0,1)'],
    options: {scales:
		{yAxes:
			[{ticks: {min: 0,max: 7000}}, {ticks: {min: 0,max: 7000}}]
    range: 'day',
    drawOrderDay: ['v_595','u_719']
Pretty happy now :mrgreen:
Posted: Friday 25 August 2023 11:42
by Maikel76
Hi Edwin/Lokonli/everyone,
I added my first dial as a selector switch and dimer on the outside ring.
blocks[22] = {
         //idx: 22,
         //title: 'Music',
         type: 'dial',
         values: [
           idx: 177,
           value: 'level',
           last_update: true,
           isSetpoint: true
         width: 6,
         showring: true,
         shownumbers: true,
         min:0,
         max: 100
 } //, icon: 'fas fa-music'}
With the isSetpoint my setting is changing device 177 (switch-dimmer) like it should
However if I change the device 177 in Domoticz, the dial ring does'nt change. Can I make that happen with some extra code in custom.js? and could you/anyone help me?
download/file.php?mode=view&id=30611
I just installed the latest and greatest Dashticz version, however I'm still on Domoticz 2022.1
Also I tried to use a RGBWW and RGBW switch but without change
Ofcourse i can use isNeedle but then I cannot change the value with the dial which is the main reason it's there
For insight, I'm changing the volume level with dzVents script according to different events
Posted: Sunday 27 August 2023 22:28
by Lokonli
Maikel76 wrote: Friday 25 August 2023 11:42 Hi Edwin/Lokonli/everyone,
blocks[22] = {
         //idx: 22,
         //title: 'Music',
         type: 'dial',
         values: [
           idx: 177,
           value: 'level',
           last_update: true,
           isSetpoint: true
         width: 6,
         showring: true,
         shownumbers: true,
         min:0,
         max: 100
That seems to be bug.
I'll fix it.
Posted: Monday 28 August 2023 9:18
by Maikel76
Lokonli wrote: Sunday 27 August 2023 22:28 That seems to be bug.
I'll fix it.
Awesome, thanks a lot
Posted: Wednesday 30 August 2023 12:12
by Maikel76
blocks[22] = {
         //idx: 22,
         //title: 'Music',
         type: 'dial',
         values: [
           idx: 177,
           value: 'level',
           last_update: true,
           isSetpoint: true
         width: 6,
         showring: true,
         shownumbers: true,
         min:0,
         max: 100
I'll fix it.
If you need any extra info please let me know Sander
Posted: Wednesday 30 August 2023 14:12
by Lokonli
Thanks, not needed, I've fixed it already.
I've to do some additional testing to check there are no side effects. I'll publish a new version later this week.
Posted: Wednesday 30 August 2023 15:59
by Maikel76
Lokonli wrote: Wednesday 30 August 2023 14:12 Thanks, not needed, I've fixed it already.
Thanks for your effort!!
Posted: Tuesday 05 September 2023 21:17
by Lokonli
Maikel76 wrote: Wednesday 30 August 2023 15:59
Should be fixed in latest Dashticz version (3.10.8 beta)
Posted: Wednesday 06 September 2023 7:10
by Maikel76
Lokonli wrote: Tuesday 05 September 2023 21:17
Hi Sander,
I updated to 3.10.8. Unfortunately it's not working. This is the result of;
http://192.168.88.50:8099/json.htm?username=bla==&password=bla=&type=devices&rid=177
ActTime	1693976510
AstrTwilightEnd	"19:38"
AstrTwilightStart	"04:55"
CivTwilightEnd	"18:48"
CivTwilightStart	"05:45"
DayLength	"12:20"
NautTwilightEnd	"19:13"
NautTwilightStart	"05:20"
ServerTime	"2023-09-06 12:01:50"
SunAtSouth	"12:16"
Sunrise	"06:06"
Sunset	"18:26"
app_version	"2022.1"
result
0
AddjMulti	1
AddjMulti2	1
AddjValue	0
AddjValue2	0
BatteryLevel	255
CustomImage	0
Data	"Set Level: 100 %"
Description	""
DimmerType	"abs"
Favorite	0
HardwareDisabled	false
HardwareID	4
HardwareName	"VirtualSwitches"
HardwareType	"Dummy (Does nothing, use for virtual switches only)"
HardwareTypeVal	15
HaveDimmer	true
HaveGroupCmd	true
HaveTimeout	false
ID	"00014101"
Image	"Light"
IsSubDevice	false
LastUpdate	"2023-09-06 11:55:51"
Level	100
LevelInt	100
MaxDimLevel	100
Name	"Volume"
Notifications	"false"
PlanID	"0"
PlanIDs
0	0
Protected	false
ShowNotifications	true
SignalLevel	"-"
Status	"Set Level: 100 %"
StrParam1	""
StrParam2	""
SubType	"Switch"
SwitchType	"Dimmer"
SwitchTypeVal	7
Timers	"false"
Type	"Light/Switch"
TypeImg	"dimmer"
Unit	1
Used	1
UsedByCamera	false
XOffset	"0"
YOffset	"0"
idx	"177"
status	"OK"
title	"Devices"
If you need any more info please let me know
Posted: Wednesday 06 September 2023 17:46
by Lokonli
Can you try with Level instead of level in your block definition?
Posted: Wednesday 06 September 2023 18:46
by Maikel76
Lokonli wrote: Wednesday 06 September 2023 17:46 Can you try with Level instead of level in your block definition?
That was the solution, once again you're the best. Thanks so much Sander!
