S0 Pulse Meter via USB hangs every 25-30 days?
- Domoticz version: 2023.2
Just wondering of anyone have seen similar pattern when using S0 Pulse Meter via USB that it seems to fail and stop working every 25-30 days? I have two RpiZ which each have a S0 Pulse Meter via USB connected and both of them more or less stop within the same interval of 24-48 hours. Initially I thought i was issues with the IBest USB-nav top-hat card which provides the RpiZ with additional 4 USB-ports but it's not. Based on that one of the units also have a P1-cable connected to the IBest USB-nav card which works just fine. Only way to get the S0 Pulse Meter to work again is to perform a cold boot as a warm boot would 'wake' up the S0 Pulse Meter.
- psubiaco
Re: S0 Pulse Meter via USB hangs every 25-30 days?
If you have a meter with S0 output, you can interface it using a DomBus module: they are designed for Domoticz and are very reliable.
https://www.domoticz.com/wiki/Creasol_Dombus
Paolo
Replacing the S0 Pulse Meters that I have is the last option for now; but if I can't get them to work proper and relaible then the have to go.
Re-opening this request again since my S0 Pulse readers from SOS Solution just isn't stable enough as they keep stopping to work every 30-40 days and I have at least one other user having the same issue here. So we're at leat two indiviuals who looking to replace the SOS S0 Pulse readers.psubiaco wrote: ↑Tuesday 06 June 2023 12:10 If you have a meter with S0 output, you can interface it using a DomBus module: they are designed for Domoticz and are very reliable.
The scope is to would be both option for 1) S0 pulse to be feed, to for example the above DomBus module, which then is connected directly to a Rpi and 2) an option were the S0 Pulse reader would feed to via wireless directly to Rpi in remote building. What would be possible here?
