Today i noticed that most of my zwave devices were gone. reboot and removal of cachefile did not help
i hooked the zwave5 stick to my pc and discovered that the devices were indeed gone from the stick(weird)
lucky for me i had a backup so restoring the backup solved everything.
did anybody else has had this
please note that moving to zwavejs-ui will not avoid these problems since zwavejs-ui reads directly from the stick
this is the first time since the beginning (2012) that this happened.
lost most of my zwave devices without reason
mgugu
Re: lost most of my zwave devices without reason
Possibly a hardware failure, personally I would replace the stick
Gravityz
- Domoticz version: 2026.3
it seems fine,
i did a reset, restored the backup, did a full test and then connected it back to domoticz
if i need to replace it i probalbe replace everythi ng with zigbee.
already have the hue hub
