Zigbee4domoticz - pairing cheap smoke sensor
pfloryann
Domoticz version: 4.1
Post by pfloryann »
I bought an cheap smoke sensor, i can see it in the plugin dashboard but i have a message "The object is not optimized with the plugin". Haven't widget in domoticz for him.
Plugin: 6.3.012 Domoticz: 2023.1 (build 15182) Zigate v1 usb
Thank You!
export(1).zip
(30.7 KiB) Downloaded 58 times
Domoticz on Raspberry Pi 4 with Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy
pipiche
Re: Zigbee4domoticz - pairing cheap smoke sensor
Post by pipiche »
If you are on Bullseye, please switch to develop branch
git checkout develop
git pull
sudo python3 -m pip install -r requirements.txt --upgrade
Then restart the plugin
enable tuya debug parameter via the WebUI > Debug
and then redo the pairing
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
pfloryann
Post by pfloryann »
Hi, i tried but now the plugin not starting and dashboard doesn t working
Collecting zigpy==0.54.1 (from -r requirements.txt (line 5))
Could not find a version that satisfies the requirement zigpy==0.54.1 (from -r requirements.txt (line 5)) (from versions: 0.0.1, 0.0.2, 0.0.3, 0.1.0, 0.2.0, 0.20.0a1, 0.20a2, 0.20.0, 0.20.1a1, 0.20.1a2, 0.20.1a3, 0.20.1, 0.20.2, 0.20.3, 0.20.4, 0.21.0, 0.22.0, 0.22.1, 0.22.2, 0.23.0, 0.23.1, 0.23.2, 0.24.0, 0.24.1, 0.24.2, 0.24.3, 0.25.0, 0.26.0, 0.27.0, 0.27.1, 0.28.0, 0.28.1, 0.28.2, 0.29.0, 0.30.0, 0.30.1, 0.31.0, 0.32.0, 0.33.0, 0.34.0, 0.35.0, 0.35.1, 0.35.2, 0.36.0, 0.36.1, 0.36.2, 0.37.0, 0.37.1, 0.37.2, 0.38.0, 0.39.0, 0.40.0, 0.41.0, 0.42.0, 0.43.0, 0.44.1, 0.44.2, 0.45.0.dev0, 0.45.0, 0.45.1, 0.46.0, 0.47.0, 0.47.1, 0.47.2, 0.50.1, 0.50.2, 0.50.3, 0.51.0, 0.51.1, 0.51.2, 0.51.3, 0.51.4, 0.51.5, 0.51.6)
No matching distribution found for zigpy==0.54.1 (from -r requirements.txt (line 5))
I'm back to stable branch
pipiche
Post by pipiche »
Are you on Bullseye ?
pfloryann
Post by pfloryann »
I dont know...i have stable version 6.3
pipiche
Post by pipiche »
THis is not about the plugin it is about the OS release that you are running. I suspect that you don't have the right version of Python3 and so you cannot upgrade to the develop branch.
In order to switch to develop branch you need on a RPI to be on Bullseye and consequently with at least Python3.9
If you are on buster, you then need to upgrade your OS to bullseye as you cannot have python3.9 working with Domoticz on buster
pfloryann
Post by pfloryann »
yeah i using buster with python 3.8. I will try this Os upgrade and come back. Thank you very much for your support!
pfloryann
Post by pfloryann »
Hi, same error with bullseye and python 3.9.9.
pipiche
Post by pipiche »
please share the command that you are doing ?
pfloryann
Post by pfloryann »
git pull
here i have error -> sudo python3 -m pip install -r requirements.txt --upgrade
pipiche
Post by pipiche »
Can you try
sudo python3 -m pip install pip —upgrade
python3 -m pip install --upgrade pip setuptools wheel
And then the other commands
Can you please share the results of each command
pfloryann
Post by pfloryann »
Finally works. Thanks! I paired the smoke sensor but i have the same message "The object is not optimized with the plugin" in Plugin dashboard. Haven't widget in domoticz for him.
from domoticz logs:
2023-04-26 19:22:51.122 Status: Zigate: [6] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:51.129 Status: Zigate: [6] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
pipiche
Post by pipiche »
Can you share the plugin log file ?
pfloryann
Post by pfloryann »
This device is the last from export file.
export(2).txt
(271.25 KiB) Downloaded 91 times
pfloryann
Post by pfloryann »
2023-04-26 19:21:21,152 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 648 _mainPowered: True doReadAttr: True
2023-04-26 19:21:21,179 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18804 _mainPowered: True doReadAttr: True
2023-04-26 19:21:21,192 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36536 _mainPowered: True doReadAttr: True
2023-04-26 19:21:21,207 ERROR : [ MainThread] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=3 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:21:21,302 ERROR : [ MainThread] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=30 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:21:23,044 INFO : [ MainThread 0] Request Accepting new Hardware for 240 seconds
2023-04-26 19:21:23,231 INFO : [ZiGateForwarder_2 0] Accepting new Hardware: Enable (On)
2023-04-26 19:21:26,098 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14480 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,150 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36850 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,156 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14532 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,180 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14494 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,200 INFO : [ MainThread 0] processKnownDevices - a9f1 intHB: 9412 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,211 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4442 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,230 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31428 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,249 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11298 _mainPowered: True doReadAttr: True
2023-04-26 19:21:26,256 ERROR : [ MainThread] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=3 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:21:26,359 ERROR : [ MainThread] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=30 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:21:31,072 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31648 _mainPowered: True doReadAttr: True
2023-04-26 19:21:31,125 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11032 _mainPowered: True doReadAttr: True
2023-04-26 19:21:31,141 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39582 _mainPowered: True doReadAttr: True
2023-04-26 19:21:31,161 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 650 _mainPowered: True doReadAttr: True
2023-04-26 19:21:31,181 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18806 _mainPowered: True doReadAttr: True
2023-04-26 19:21:31,217 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36538 _mainPowered: True doReadAttr: True
2023-04-26 19:21:32,792 ERROR : [ ZiGateSerial_2] NXP_Extended_Error_Code - Extended Error Code: [87] No free entries in the extended address table (resource error) - this table is configured in the ZPS Configuration Editor
2023-04-26 19:21:36,061 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14482 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,109 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36852 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,145 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14534 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,159 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14496 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,187 INFO : [ MainThread 0] processKnownDevices - a9f1 intHB: 9414 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,199 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4444 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,220 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31430 _mainPowered: True doReadAttr: True
2023-04-26 19:21:36,295 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11300 _mainPowered: True doReadAttr: True
2023-04-26 19:21:41,082 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31650 _mainPowered: True doReadAttr: True
2023-04-26 19:21:41,123 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11034 _mainPowered: True doReadAttr: True
2023-04-26 19:21:41,157 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39584 _mainPowered: True doReadAttr: True
2023-04-26 19:21:41,167 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 652 _mainPowered: True doReadAttr: True
2023-04-26 19:21:41,182 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18808 _mainPowered: True doReadAttr: True
2023-04-26 19:21:41,224 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36540 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,103 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14484 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,145 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36854 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,154 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14536 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,159 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14498 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,207 INFO : [ MainThread 0] processKnownDevices - a9f1 intHB: 9416 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,222 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4446 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,289 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31432 _mainPowered: True doReadAttr: True
2023-04-26 19:21:46,302 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11302 _mainPowered: True doReadAttr: True
2023-04-26 19:21:51,128 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31652 _mainPowered: True doReadAttr: True
2023-04-26 19:21:51,152 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11036 _mainPowered: True doReadAttr: True
2023-04-26 19:21:51,186 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39586 _mainPowered: True doReadAttr: True
2023-04-26 19:21:51,197 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 654 _mainPowered: True doReadAttr: True
2023-04-26 19:21:51,228 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18810 _mainPowered: True doReadAttr: True
2023-04-26 19:21:51,258 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36542 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,095 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14486 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,133 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36856 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,154 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14538 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,163 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14500 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,186 INFO : [ MainThread 0] processKnownDevices - a9f1 intHB: 9418 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,197 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4448 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,216 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31434 _mainPowered: True doReadAttr: True
2023-04-26 19:21:56,284 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11304 _mainPowered: True doReadAttr: True
2023-04-26 19:22:01,107 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31654 _mainPowered: True doReadAttr: True
2023-04-26 19:22:01,129 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11038 _mainPowered: True doReadAttr: True
2023-04-26 19:22:01,146 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39588 _mainPowered: True doReadAttr: True
2023-04-26 19:22:01,201 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 656 _mainPowered: True doReadAttr: True
2023-04-26 19:22:01,250 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18812 _mainPowered: True doReadAttr: True
2023-04-26 19:22:01,278 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36544 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,063 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14488 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,083 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36858 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,114 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14540 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,124 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14502 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,178 INFO : [ MainThread 0] processKnownDevices - a9f1 intHB: 9420 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,188 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4450 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,219 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31436 _mainPowered: True doReadAttr: True
2023-04-26 19:22:06,259 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11306 _mainPowered: True doReadAttr: True
2023-04-26 19:22:08,043 INFO : [ MainThread 0] Request Accepting new Hardware for 240 seconds
2023-04-26 19:22:11,085 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31656 _mainPowered: True doReadAttr: True
2023-04-26 19:22:11,139 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11040 _mainPowered: True doReadAttr: True
2023-04-26 19:22:11,164 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39590 _mainPowered: True doReadAttr: True
2023-04-26 19:22:11,202 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 658 _mainPowered: True doReadAttr: True
2023-04-26 19:22:11,337 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18814 _mainPowered: True doReadAttr: True
2023-04-26 19:22:11,351 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36546 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,106 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14490 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,157 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36860 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,179 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14542 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,189 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14504 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,227 INFO : [ MainThread 0] processKnownDevices - a9f1 intHB: 9422 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,237 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4452 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,257 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31438 _mainPowered: True doReadAttr: True
2023-04-26 19:22:16,299 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11308 _mainPowered: True doReadAttr: True
2023-04-26 19:22:18,831 INFO : [ZiGateForwarder_2 0] --> Adding device c622 in self.DevicesInPairingMode
2023-04-26 19:22:18,833 INFO : [ZiGateForwarder_2 0] --> ['c622']
2023-04-26 19:22:18,834 INFO : [ZiGateForwarder_2 0] [None] NEW OBJECT: c622 None
2023-04-26 19:22:18,835 INFO : [ZiGateForwarder_2 0] ReadAttributeRequest_0000_for_tuya c622
2023-04-26 19:22:19,362 INFO : [ZiGateForwarder_2 0] check_found_plugin_model - TS0601 _TZE200_uebojraa None
2023-04-26 19:22:19,482 INFO : [ZiGateForwarder_2 0] Decode8046 - Match Descriptor response: SQN: 00 Status: 00 Nwkid: c622 Lenght: 00 List:
2023-04-26 19:22:19,787 INFO : [ZiGateForwarder_2 0] [-] NEW OBJECT: c622 Active Endpoint Response Ep: 01 LQI: 60
2023-04-26 19:22:21,123 INFO : [ MainThread 0] [0] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:21,130 INFO : [ MainThread 0] [0] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:21,240 INFO : [ZiGateForwarder_2 0] [-] NEW OBJECT: c622 Active Endpoint Response Ep: 01 LQI: 60
2023-04-26 19:22:26,121 INFO : [ MainThread 0] [1] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:26,127 INFO : [ MainThread 0] [1] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:31,091 INFO : [ MainThread 0] [2] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:31,098 INFO : [ MainThread 0] [2] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:36,118 INFO : [ MainThread 0] [3] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:36,135 INFO : [ MainThread 0] [3] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:41,085 INFO : [ MainThread 0] [4] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:41,086 INFO : [ MainThread 0] [4] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:41,087 INFO : [ MainThread 0] . Checking 0000 on ep 01
2023-04-26 19:22:44,220 INFO : [ MainThread 0] Request Disabling Accepting new Hardware
2023-04-26 19:22:44,229 INFO : [ MainThread 0] Request router: 0000 to close the network
2023-04-26 19:22:44,236 INFO : [ MainThread 0] Request router: dc50 to close the network
2023-04-26 19:22:44,237 INFO : [ MainThread 0] Request router: 66c6 to close the network
2023-04-26 19:22:44,238 INFO : [ MainThread 0] Request router: 46f0 to close the network
2023-04-26 19:22:44,239 INFO : [ MainThread 0] Request router: 4822 to close the network
2023-04-26 19:22:44,240 INFO : [ MainThread 0] Request router: cba5 to close the network
2023-04-26 19:22:44,241 INFO : [ MainThread 0] Request router: d4d8 to close the network
2023-04-26 19:22:44,242 INFO : [ MainThread 0] Request router: 4b62 to close the network
2023-04-26 19:22:44,243 INFO : [ MainThread 0] Request router: d291 to close the network
2023-04-26 19:22:44,249 INFO : [ MainThread 0] Request router: b159 to close the network
2023-04-26 19:22:44,251 INFO : [ MainThread 0] Request router: a9f1 to close the network
2023-04-26 19:22:44,252 INFO : [ MainThread 0] Request router: 5759 to close the network
2023-04-26 19:22:44,253 INFO : [ MainThread 0] Request router: 66b5 to close the network
2023-04-26 19:22:44,254 INFO : [ MainThread 0] Request router: 450f to close the network
2023-04-26 19:22:44,255 INFO : [ MainThread 0] Request router: 49c3 to close the network
2023-04-26 19:22:44,256 INFO : [ MainThread 0] Request router: f76e to close the network
2023-04-26 19:22:44,257 INFO : [ MainThread 0] Request router: 68b8 to close the network
2023-04-26 19:22:44,258 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1034] 0049 68b80000 None ZigateQueue: 16
2023-04-26 19:22:44,258 INFO : [ MainThread 0] Request router: 74f4 to close the network
2023-04-26 19:22:44,259 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1035] 0049 74f40000 None ZigateQueue: 17
2023-04-26 19:22:44,260 INFO : [ MainThread 0] Request router: b37d to close the network
2023-04-26 19:22:44,260 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1036] 0049 b37d0000 None ZigateQueue: 18
2023-04-26 19:22:44,261 INFO : [ MainThread 0] Request router: d925 to close the network
2023-04-26 19:22:44,262 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1037] 0049 d9250000 None ZigateQueue: 19
2023-04-26 19:22:44,263 INFO : [ MainThread 0] Request router: 1c6a to close the network
2023-04-26 19:22:44,264 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1038] 0049 1c6a0000 None ZigateQueue: 20
2023-04-26 19:22:44,265 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1039] 0014 None ZigateQueue: 21
2023-04-26 19:22:46,095 INFO : [ MainThread 0] [5] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:46,118 INFO : [ MainThread 0] [5] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:51,116 INFO : [ MainThread 0] [6] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:51,123 INFO : [ MainThread 0] [6] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:52,556 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:52,666 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:52,835 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:52,943 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:53,051 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:53,280 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:53,729 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:54,121 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:54,243 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:54,337 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:22:54,549 ERROR : [ ZiGateSerial_2] NXP_Extended_Error_Code - Extended Error Code: [83] No free APS acknowledgement handles (resource error) - the number of handles is set in the Maximum Number of Simultaneous Data Requests with Acks field of the APS layer configuration section of the ZPS Configuration Editor
2023-04-26 19:22:54,574 ERROR : [ZiGateForwarder_2] Decode8000 - PacketType: 0049 TypeSqn: 02 sqn_app: 00 sqn_aps: df Status: [ZigBee Error Code Unknown code : 80]
2023-04-26 19:22:54,657 INFO : [ZiGateForwarder_2 0] Accepting new Hardware: Disable (Off)
2023-04-26 19:22:56,132 INFO : [ MainThread 0] [7] NEW OBJECT: c622 Model Name: TS0601
2023-04-26 19:22:56,134 INFO : [ MainThread 0] [7] NEW OBJECT: c622 Manufacturer Name: _TZE200_uebojraa
2023-04-26 19:22:58,850 INFO : [ZiGateForwarder_2 0] Receive NACK from dc50 clusterId: 0036 Status: a7
2023-04-26 19:22:59,836 INFO : [ZiGateForwarder_2 0] timeout_widget unit Gardenpole Mini RGBW OSRAM -> True from 0:Off
2023-04-26 19:22:59,855 INFO : [ZiGateForwarder_2 0] Receive NACK from a9f1 clusterId: 0036 Status: a7
2023-04-26 19:22:59,946 INFO : [ZiGateForwarder_2 0] Receive NACK from 5759 clusterId: 0036 Status: a7
2023-04-26 19:23:00,162 INFO : [ZiGateForwarder_2 0] Receive NACK from 450f clusterId: 0036 Status: a7
2023-04-26 19:23:00,265 INFO : [ZiGateForwarder_2 0] Receive NACK from 49c3 clusterId: 0036 Status: a7
2023-04-26 19:23:00,388 INFO : [ZiGateForwarder_2 0] Receive NACK from f76e clusterId: 0036 Status: a7
2023-04-26 19:23:00,849 INFO : [ZiGateForwarder_2 0] Receive NACK from d925 clusterId: 0036 Status: a7
2023-04-26 19:23:01,099 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31666 _mainPowered: True doReadAttr: True
2023-04-26 19:23:01,130 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11050 _mainPowered: True doReadAttr: True
2023-04-26 19:23:01,161 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39600 _mainPowered: True doReadAttr: True
2023-04-26 19:23:01,206 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 668 _mainPowered: True doReadAttr: True
2023-04-26 19:23:01,229 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18824 _mainPowered: True doReadAttr: True
2023-04-26 19:23:01,267 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36556 _mainPowered: True doReadAttr: True
2023-04-26 19:23:01,294 INFO : [ZiGateForwarder_2 0] ReadCluster 0b04 - d4d8/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2023-04-26 19:23:06,126 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14500 _mainPowered: True doReadAttr: True
2023-04-26 19:23:06,164 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36870 _mainPowered: True doReadAttr: True
2023-04-26 19:23:06,174 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14552 _mainPowered: True doReadAttr: True
2023-04-26 19:23:06,184 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14514 _mainPowered: True doReadAttr: True
2023-04-26 19:23:06,226 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4462 _mainPowered: True doReadAttr: True
2023-04-26 19:23:06,256 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31448 _mainPowered: True doReadAttr: True
2023-04-26 19:23:06,296 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11318 _mainPowered: True doReadAttr: True
2023-04-26 19:23:11,111 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31668 _mainPowered: True doReadAttr: True
2023-04-26 19:23:11,131 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11052 _mainPowered: True doReadAttr: True
2023-04-26 19:23:11,151 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39602 _mainPowered: True doReadAttr: True
2023-04-26 19:23:11,168 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 670 _mainPowered: True doReadAttr: True
2023-04-26 19:23:11,206 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18826 _mainPowered: True doReadAttr: True
2023-04-26 19:23:11,220 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36558 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,131 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14502 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,173 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36872 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,194 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14554 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,209 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14516 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,241 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4464 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,263 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31450 _mainPowered: True doReadAttr: True
2023-04-26 19:23:16,288 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11320 _mainPowered: True doReadAttr: True
2023-04-26 19:23:21,062 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31670 _mainPowered: True doReadAttr: True
2023-04-26 19:23:21,082 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11054 _mainPowered: True doReadAttr: True
2023-04-26 19:23:21,092 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39604 _mainPowered: True doReadAttr: True
2023-04-26 19:23:21,127 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 672 _mainPowered: True doReadAttr: True
2023-04-26 19:23:21,138 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18828 _mainPowered: True doReadAttr: True
2023-04-26 19:23:21,192 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36560 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,079 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14504 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,100 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36874 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,144 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14556 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,163 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14518 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,186 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4466 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,205 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31452 _mainPowered: True doReadAttr: True
2023-04-26 19:23:26,274 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11322 _mainPowered: True doReadAttr: True
2023-04-26 19:23:31,112 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31672 _mainPowered: True doReadAttr: True
2023-04-26 19:23:31,134 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11056 _mainPowered: True doReadAttr: True
2023-04-26 19:23:31,144 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39606 _mainPowered: True doReadAttr: True
2023-04-26 19:23:31,159 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 674 _mainPowered: True doReadAttr: True
2023-04-26 19:23:31,183 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18830 _mainPowered: True doReadAttr: True
2023-04-26 19:23:31,202 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36562 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,074 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14506 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,140 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36876 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,174 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14558 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,184 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14520 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,240 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4468 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,276 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31454 _mainPowered: True doReadAttr: True
2023-04-26 19:23:36,287 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11324 _mainPowered: True doReadAttr: True
2023-04-26 19:23:41,071 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31674 _mainPowered: True doReadAttr: True
2023-04-26 19:23:41,101 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11058 _mainPowered: True doReadAttr: True
2023-04-26 19:23:41,115 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39608 _mainPowered: True doReadAttr: True
2023-04-26 19:23:41,144 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 676 _mainPowered: True doReadAttr: True
2023-04-26 19:23:41,176 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18832 _mainPowered: True doReadAttr: True
2023-04-26 19:23:41,199 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36564 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,069 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14508 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,098 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36878 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,129 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14560 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,141 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14522 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,184 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4470 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,234 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31456 _mainPowered: True doReadAttr: True
2023-04-26 19:23:46,261 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11326 _mainPowered: True doReadAttr: True
2023-04-26 19:23:51,107 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31676 _mainPowered: True doReadAttr: True
2023-04-26 19:23:51,150 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11060 _mainPowered: True doReadAttr: True
2023-04-26 19:23:51,182 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39610 _mainPowered: True doReadAttr: True
2023-04-26 19:23:51,204 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 678 _mainPowered: True doReadAttr: True
2023-04-26 19:23:51,226 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18834 _mainPowered: True doReadAttr: True
2023-04-26 19:23:51,240 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36566 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,076 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14510 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,117 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36880 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,128 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14562 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,160 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14524 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,190 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4472 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,219 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31458 _mainPowered: True doReadAttr: True
2023-04-26 19:23:56,279 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11328 _mainPowered: True doReadAttr: True
2023-04-26 19:24:01,092 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31678 _mainPowered: True doReadAttr: True
2023-04-26 19:24:01,125 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11062 _mainPowered: True doReadAttr: True
2023-04-26 19:24:01,136 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39612 _mainPowered: True doReadAttr: True
2023-04-26 19:24:01,174 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 680 _mainPowered: True doReadAttr: True
2023-04-26 19:24:01,200 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18836 _mainPowered: True doReadAttr: True
2023-04-26 19:24:01,238 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36568 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,059 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14512 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,088 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36882 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,116 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14564 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,158 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14526 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,211 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4474 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,235 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31460 _mainPowered: True doReadAttr: True
2023-04-26 19:24:06,246 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11330 _mainPowered: True doReadAttr: True
2023-04-26 19:24:10,918 ERROR : [ ZiGateSerial_2] NXP_Extended_Error_Code - Extended Error Code: [87] No free entries in the extended address table (resource error) - this table is configured in the ZPS Configuration Editor
2023-04-26 19:24:11,081 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31680 _mainPowered: True doReadAttr: True
2023-04-26 19:24:11,117 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11064 _mainPowered: True doReadAttr: True
2023-04-26 19:24:11,136 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39614 _mainPowered: True doReadAttr: True
2023-04-26 19:24:11,145 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 682 _mainPowered: True doReadAttr: True
2023-04-26 19:24:11,164 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18838 _mainPowered: True doReadAttr: True
2023-04-26 19:24:11,196 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36570 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,120 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14514 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,174 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36884 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,184 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14566 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,205 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14528 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,246 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4476 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,262 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31462 _mainPowered: True doReadAttr: True
2023-04-26 19:24:16,302 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11332 _mainPowered: True doReadAttr: True
2023-04-26 19:24:21,085 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31682 _mainPowered: True doReadAttr: True
2023-04-26 19:24:21,114 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11066 _mainPowered: True doReadAttr: True
2023-04-26 19:24:21,119 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39616 _mainPowered: True doReadAttr: True
2023-04-26 19:24:21,129 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 684 _mainPowered: True doReadAttr: True
2023-04-26 19:24:21,203 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18840 _mainPowered: True doReadAttr: True
2023-04-26 19:24:21,304 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36572 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,117 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14516 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,158 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36886 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,172 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14568 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,192 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14530 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,230 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4478 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,258 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31464 _mainPowered: True doReadAttr: True
2023-04-26 19:24:26,279 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11334 _mainPowered: True doReadAttr: True
2023-04-26 19:24:31,109 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31684 _mainPowered: True doReadAttr: True
2023-04-26 19:24:31,148 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11068 _mainPowered: True doReadAttr: True
2023-04-26 19:24:31,154 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39618 _mainPowered: True doReadAttr: True
2023-04-26 19:24:31,170 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 686 _mainPowered: True doReadAttr: True
2023-04-26 19:24:31,239 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18842 _mainPowered: True doReadAttr: True
2023-04-26 19:24:31,260 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36574 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,066 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14518 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,092 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36888 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,104 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14570 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,124 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14532 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,180 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4480 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,227 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31466 _mainPowered: True doReadAttr: True
2023-04-26 19:24:36,250 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11336 _mainPowered: True doReadAttr: True
2023-04-26 19:24:41,077 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31686 _mainPowered: True doReadAttr: True
2023-04-26 19:24:41,110 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11070 _mainPowered: True doReadAttr: True
2023-04-26 19:24:41,152 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39620 _mainPowered: True doReadAttr: True
2023-04-26 19:24:41,159 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 688 _mainPowered: True doReadAttr: True
2023-04-26 19:24:41,176 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18844 _mainPowered: True doReadAttr: True
2023-04-26 19:24:41,210 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36576 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,100 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14520 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,131 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36890 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,151 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14572 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,191 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14534 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,218 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4482 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,228 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31468 _mainPowered: True doReadAttr: True
2023-04-26 19:24:46,255 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11338 _mainPowered: True doReadAttr: True
2023-04-26 19:24:51,102 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31688 _mainPowered: True doReadAttr: True
2023-04-26 19:24:51,147 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11072 _mainPowered: True doReadAttr: True
2023-04-26 19:24:51,173 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39622 _mainPowered: True doReadAttr: True
2023-04-26 19:24:51,184 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 690 _mainPowered: True doReadAttr: True
2023-04-26 19:24:51,208 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18846 _mainPowered: True doReadAttr: True
2023-04-26 19:24:51,227 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36578 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,104 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14522 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,145 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36892 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,156 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14574 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,187 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14536 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,231 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4484 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,261 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31470 _mainPowered: True doReadAttr: True
2023-04-26 19:24:56,302 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11340 _mainPowered: True doReadAttr: True
2023-04-26 19:25:01,477 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31690 _mainPowered: True doReadAttr: True
2023-04-26 19:25:01,500 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11074 _mainPowered: True doReadAttr: True
2023-04-26 19:25:01,510 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39624 _mainPowered: True doReadAttr: True
2023-04-26 19:25:01,523 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 692 _mainPowered: True doReadAttr: True
2023-04-26 19:25:01,599 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18848 _mainPowered: True doReadAttr: True
2023-04-26 19:25:01,665 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36580 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,099 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14524 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,141 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36894 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,151 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14576 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,165 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14538 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,199 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4486 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,217 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31472 _mainPowered: True doReadAttr: True
2023-04-26 19:25:06,264 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11342 _mainPowered: True doReadAttr: True
2023-04-26 19:25:11,088 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31692 _mainPowered: True doReadAttr: True
2023-04-26 19:25:11,133 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11076 _mainPowered: True doReadAttr: True
2023-04-26 19:25:11,152 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39626 _mainPowered: True doReadAttr: True
2023-04-26 19:25:11,161 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 694 _mainPowered: True doReadAttr: True
2023-04-26 19:25:11,180 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18850 _mainPowered: True doReadAttr: True
2023-04-26 19:25:11,200 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36582 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,095 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14526 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,118 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36896 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,153 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14578 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,159 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14540 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,242 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4488 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,269 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31474 _mainPowered: True doReadAttr: True
2023-04-26 19:25:16,330 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11344 _mainPowered: True doReadAttr: True
2023-04-26 19:25:21,084 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31694 _mainPowered: True doReadAttr: True
2023-04-26 19:25:21,124 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11078 _mainPowered: True doReadAttr: True
2023-04-26 19:25:21,135 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39628 _mainPowered: True doReadAttr: True
2023-04-26 19:25:21,166 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 696 _mainPowered: True doReadAttr: True
2023-04-26 19:25:21,191 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18852 _mainPowered: True doReadAttr: True
2023-04-26 19:25:21,225 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36584 _mainPowered: True doReadAttr: True
2023-04-26 19:25:23,095 INFO : [ MainThread 0] Request Disabling Accepting new Hardware
2023-04-26 19:25:23,107 INFO : [ MainThread 0] Request router: 0000 to close the network
2023-04-26 19:25:23,109 INFO : [ MainThread 0] Request router: dc50 to close the network
2023-04-26 19:25:23,110 INFO : [ MainThread 0] Request router: 66c6 to close the network
2023-04-26 19:25:23,111 INFO : [ MainThread 0] Request router: 46f0 to close the network
2023-04-26 19:25:23,112 INFO : [ MainThread 0] Request router: 4822 to close the network
2023-04-26 19:25:23,131 INFO : [ MainThread 0] Request router: cba5 to close the network
2023-04-26 19:25:23,134 INFO : [ MainThread 0] Request router: d4d8 to close the network
2023-04-26 19:25:23,135 INFO : [ MainThread 0] Request router: 4b62 to close the network
2023-04-26 19:25:23,136 INFO : [ MainThread 0] Request router: d291 to close the network
2023-04-26 19:25:23,137 INFO : [ MainThread 0] Request router: b159 to close the network
2023-04-26 19:25:23,138 INFO : [ MainThread 0] Request router: a9f1 to close the network
2023-04-26 19:25:23,139 INFO : [ MainThread 0] Request router: 5759 to close the network
2023-04-26 19:25:23,140 INFO : [ MainThread 0] Request router: 66b5 to close the network
2023-04-26 19:25:23,141 INFO : [ MainThread 0] Request router: 450f to close the network
2023-04-26 19:25:23,142 INFO : [ MainThread 0] Request router: 49c3 to close the network
2023-04-26 19:25:23,143 INFO : [ MainThread 0] Request router: f76e to close the network
2023-04-26 19:25:23,144 INFO : [ MainThread 0] Request router: 68b8 to close the network
2023-04-26 19:25:23,145 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1062] 0049 68b80000 None ZigateQueue: 16
2023-04-26 19:25:23,145 INFO : [ MainThread 0] Request router: 74f4 to close the network
2023-04-26 19:25:23,146 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1063] 0049 74f40000 None ZigateQueue: 17
2023-04-26 19:25:23,147 INFO : [ MainThread 0] Request router: b37d to close the network
2023-04-26 19:25:23,148 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1064] 0049 b37d0000 None ZigateQueue: 18
2023-04-26 19:25:23,152 INFO : [ MainThread 0] Request router: d925 to close the network
2023-04-26 19:25:23,153 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1065] 0049 d9250000 None ZigateQueue: 19
2023-04-26 19:25:23,154 INFO : [ MainThread 0] Request router: 1c6a to close the network
2023-04-26 19:25:23,155 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1066] 0049 1c6a0000 None ZigateQueue: 20
2023-04-26 19:25:23,169 INFO : [ MainThread 0] WARNING - send_zigatecmd : [1067] 0014 None ZigateQueue: 21
2023-04-26 19:25:26,085 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14528 _mainPowered: True doReadAttr: True
2023-04-26 19:25:26,095 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36898 _mainPowered: True doReadAttr: True
2023-04-26 19:25:26,102 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14580 _mainPowered: True doReadAttr: True
2023-04-26 19:25:26,123 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14542 _mainPowered: True doReadAttr: True
2023-04-26 19:25:26,155 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4490 _mainPowered: True doReadAttr: True
2023-04-26 19:25:26,180 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31476 _mainPowered: True doReadAttr: True
2023-04-26 19:25:26,190 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11346 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,070 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14528 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,078 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36898 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,086 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14580 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,093 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14542 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,185 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4490 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,200 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31476 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,221 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11346 _mainPowered: True doReadAttr: True
2023-04-26 19:25:31,407 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:31,516 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:31,668 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:31,849 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:31,914 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:32,175 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:32,620 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:33,013 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:33,123 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:33,234 INFO : [ZiGateForwarder_2 0] Pairing Command correctly exectued
2023-04-26 19:25:33,438 ERROR : [ ZiGateSerial_2] NXP_Extended_Error_Code - Extended Error Code: [83] No free APS acknowledgement handles (resource error) - the number of handles is set in the Maximum Number of Simultaneous Data Requests with Acks field of the APS layer configuration section of the ZPS Configuration Editor
2023-04-26 19:25:33,465 ERROR : [ZiGateForwarder_2] Decode8000 - PacketType: 0049 TypeSqn: 02 sqn_app: 00 sqn_aps: 11 Status: [ZigBee Error Code Unknown code : 80]
2023-04-26 19:25:36,099 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14528 _mainPowered: True doReadAttr: True
2023-04-26 19:25:36,122 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36898 _mainPowered: True doReadAttr: True
2023-04-26 19:25:36,132 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14580 _mainPowered: True doReadAttr: True
2023-04-26 19:25:36,162 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14542 _mainPowered: True doReadAttr: True
2023-04-26 19:25:36,217 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4490 _mainPowered: True doReadAttr: True
2023-04-26 19:25:36,234 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31476 _mainPowered: True doReadAttr: True
2023-04-26 19:25:36,266 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11346 _mainPowered: True doReadAttr: True
2023-04-26 19:25:37,675 INFO : [ZiGateForwarder_2 0] Receive NACK from dc50 clusterId: 0036 Status: a7
2023-04-26 19:25:38,715 INFO : [ZiGateForwarder_2 0] Receive NACK from a9f1 clusterId: 0036 Status: a7
2023-04-26 19:25:38,868 INFO : [ZiGateForwarder_2 0] Receive NACK from 5759 clusterId: 0036 Status: a7
2023-04-26 19:25:39,072 INFO : [ZiGateForwarder_2 0] Receive NACK from 450f clusterId: 0036 Status: a7
2023-04-26 19:25:39,193 INFO : [ZiGateForwarder_2 0] Receive NACK from 49c3 clusterId: 0036 Status: a7
2023-04-26 19:25:39,293 INFO : [ZiGateForwarder_2 0] Receive NACK from f76e clusterId: 0036 Status: a7
2023-04-26 19:25:39,700 INFO : [ZiGateForwarder_2 0] Receive NACK from d925 clusterId: 0036 Status: a7
2023-04-26 19:25:41,115 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31696 _mainPowered: True doReadAttr: True
2023-04-26 19:25:41,160 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11080 _mainPowered: True doReadAttr: True
2023-04-26 19:25:41,172 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39630 _mainPowered: True doReadAttr: True
2023-04-26 19:25:41,182 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 698 _mainPowered: True doReadAttr: True
2023-04-26 19:25:41,207 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18854 _mainPowered: True doReadAttr: True
2023-04-26 19:25:41,221 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36586 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,082 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14530 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,107 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36900 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,148 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14582 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,169 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14544 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,235 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4492 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,262 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31478 _mainPowered: True doReadAttr: True
2023-04-26 19:25:46,310 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11348 _mainPowered: True doReadAttr: True
2023-04-26 19:25:51,091 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31698 _mainPowered: True doReadAttr: True
2023-04-26 19:25:51,108 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11082 _mainPowered: True doReadAttr: True
2023-04-26 19:25:51,118 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39632 _mainPowered: True doReadAttr: True
2023-04-26 19:25:51,136 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 700 _mainPowered: True doReadAttr: True
2023-04-26 19:25:51,155 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18856 _mainPowered: True doReadAttr: True
2023-04-26 19:25:51,200 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36588 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,100 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14532 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,131 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36902 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,141 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14584 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,168 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14546 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,220 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4494 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,244 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31480 _mainPowered: True doReadAttr: True
2023-04-26 19:25:56,280 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11350 _mainPowered: True doReadAttr: True
2023-04-26 19:26:01,122 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31700 _mainPowered: True doReadAttr: True
2023-04-26 19:26:01,140 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11084 _mainPowered: True doReadAttr: True
2023-04-26 19:26:01,151 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39634 _mainPowered: True doReadAttr: True
2023-04-26 19:26:01,161 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 702 _mainPowered: True doReadAttr: True
2023-04-26 19:26:01,182 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18858 _mainPowered: True doReadAttr: True
2023-04-26 19:26:01,201 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36590 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,083 INFO : [ MainThread 0] processKnownDevices - 66c6 intHB: 14534 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,118 INFO : [ MainThread 0] processKnownDevices - 4822 intHB: 36904 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,142 INFO : [ MainThread 0] processKnownDevices - cba5 intHB: 14586 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,148 INFO : [ MainThread 0] processKnownDevices - 4b62 intHB: 14548 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,194 INFO : [ MainThread 0] processKnownDevices - 68b8 intHB: 4496 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,217 INFO : [ MainThread 0] processKnownDevices - 74f4 intHB: 31482 _mainPowered: True doReadAttr: True
2023-04-26 19:26:06,256 INFO : [ MainThread 0] processKnownDevices - 1c6a intHB: 11352 _mainPowered: True doReadAttr: True
2023-04-26 19:26:10,067 ERROR : [ ZiGateSerial_2] NXP_Extended_Error_Code - Extended Error Code: [87] No free entries in the extended address table (resource error) - this table is configured in the ZPS Configuration Editor
2023-04-26 19:26:11,095 INFO : [ MainThread 0] processKnownDevices - 46f0 intHB: 31702 _mainPowered: True doReadAttr: True
2023-04-26 19:26:11,122 INFO : [ MainThread 0] processKnownDevices - d4d8 intHB: 11086 _mainPowered: True doReadAttr: True
2023-04-26 19:26:11,155 INFO : [ MainThread 0] processKnownDevices - d291 intHB: 39636 _mainPowered: True doReadAttr: True
2023-04-26 19:26:11,196 INFO : [ MainThread 0] processKnownDevices - b159 intHB: 704 _mainPowered: True doReadAttr: True
2023-04-26 19:26:11,221 INFO : [ MainThread 0] processKnownDevices - 66b5 intHB: 18860 _mainPowered: True doReadAttr: True
2023-04-26 19:26:11,254 INFO : [ MainThread 0] processKnownDevices - b37d intHB: 36592 _mainPowered: True doReadAttr: True
2023-04-26 19:26:14,500 ERROR : [ZiGateForwarder_2] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=7 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:26:14,537 ERROR : [ZiGateForwarder_2] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=8 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:26:14,640 ERROR : [ZiGateForwarder_2] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=7 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:26:14,699 ERROR : [ZiGateForwarder_2] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=11 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:26:14,792 ERROR : [ZiGateForwarder_2] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=7 rejected. Error: HTTP Error 401: Unauthorized
2023-04-26 19:26:14,827 ERROR : [ZiGateForwarder_2] Urlopen to http://127.0.0.1:8888/json.htm?type=devices&rid=11 rejected. Error: HTTP Error 401: Unauthorized
pfloryann
Post by pfloryann »
After all if i change from develop to stable plugin doesn't work. I have to use a backup to restore
pipiche
Post by pipiche »
pfloryann wrote: Wednesday 26 April 2023 18:57 After all if i change from develop to stable plugin doesn't work. I have to use a backup to restore
Why do you want to fall back to stable ?
pipiche
Post by pipiche »
So please let me know what you want to do. S
tay on stable, or go on develop and the make the Smoke working.
But for sure if you are on develop do not fall back to stable.
And then depending on you wish I'll do my best to help you and make the Smoke working
pfloryann
Domoticz version: 4.1
Post by pfloryann »
I wanted to see if there is any difference in domoticz. I did not know that it cannot be changed.
ok, i will keep develop version.
Domoticz on Raspberry Pi 4 with Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy
pfloryann
Re: Zigbee4domoticz - pairing cheap smoke sensor
Post by pfloryann »
this is the model i have:
https://www.zigbee2mqtt.io/devices/TS0601_smoke.html
Please let me know if you need any more information. Thank you!
