I am using the plugin Evohome via LAN. Sometimes when I change a setpoint from for example 17 degrees to 18 degrees, the setting is changed in the WebUI of Domoticz, but not in Evohome gateway (and also not in the Evohome cloud). When I try it again it often does work. Anyone also is having this problem? Any idea?
Evohome via LAN; sometimes setpoint change is not working
