Raspberry Pi B+ RaZberry and Danfoss LC-13
Posted: Monday 17 November 2014 0:03
by Crom
since a week i try to get this constellation running.
First attemp with the open Z-Wave Programm and the Razberry access via LAN.
In this constallation Open Z-Wave found my Danfoss LC-13 and it was shown in domoticz as utility.
Second try using this tipp : http://www.vesternet.com/resources/appl ... es/apnt-85
I got a little different hardware setup page. I get also the "Data Timeout" field.
Witch timeout should I take? I took 1 hour.
After selection the RaZberry i get this:
NodeId name Description enable polling status
001 (0x01) Controller Unknown: id=0147 Unknown: type=0002, id=0003 false green checkmark + heal node
Is this normal?
after several tries without any response I got this messages:
Sun Nov 16 23:51:27 2014 OpenZWave: Node Include command initiated...
Sun Nov 16 23:51:27 2014 OpenZWave: Device Response: Controller is waiting for a user action
Sun Nov 16 23:51:30 2014 Hardware Monitor: Fetching data (System sensors)
Sun Nov 16 23:51:30 2014 (System) Temp (Raspberry Pi Themperatur)
Sun Nov 16 23:51:47 2014 Error: ZWave: Stopping Controller command (Timeout!)
Sun Nov 16 23:51:47 2014 OpenZWave: Device Response: The command has completed successfully
Sun Nov 16 23:52:00 2014 Hardware Monitor: Fetching data (System sensors)
Sun Nov 16 23:52:00 2014 (System) Temp (Raspberry Pi Themperatur)
Sun Nov 16 23:52:02 2014 OpenZWave: Node Include command initiated...
Sun Nov 16 23:52:02 2014 OpenZWave: Device Response: Controller is waiting for a user action
Sun Nov 16 23:52:21 2014 OpenZWave: Node Removed. HomeID: xxxxxxxxxxxxxx, NodeID: 2
Sun Nov 16 23:52:21 2014 OpenZWave: Device Response: The command has completed successfully
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: BATTERY, Label: Battery Level, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Monday, Instance: 1
Sun Nov 16 23:52:21 2014 Error: OpenZWave: Unhandled class: 0x46 (CLIMATE CONTROL SCHEDULE)
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Tuesday, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Wednesday, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Thursday, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Friday, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Saturday, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Sunday, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Override State, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLIMATE CONTROL SCHEDULE, Label: Override Setback, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLOCK, Label: Day, Instance: 1
Sun Nov 16 23:52:21 2014 Error: OpenZWave: Unhandled class: 0x81 (CLOCK)
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLOCK, Label: Hour, Instance: 1
Sun Nov 16 23:52:21 2014 OpenZWave: Value_Added: Node: 2, CommandClass: CLOCK, Label: Minute, Instance: 1
Sun Nov 16 23:52:23 2014 OpenZWave: Value_Added: Node: 2, CommandClass: THERMOSTAT SETPOINT, Label: Cooling 1, Instance: 2
Sun Nov 16 23:52:30 2014 Hardware Monitor: Fetching data (System sensors)
Sun Nov 16 23:52:30 2014 (System) Temp (Raspberry Pi Themperatur)
Sun Nov 16 23:53:00 2014 Hardware Monitor: Fetching data (System sensors)
Sun Nov 16 23:53:00 2014 (System) Temp (Raspberry Pi Themperatur)
Is it normal?
I'm irritated because of the Errors.
The second issue is, that the Node I see under the Device Razberry
002 (0x02) Danfoss LC-13 Danfoss Living Connect Radiator Thermostat false
isn't shown under Devices.
Where is my mistake?
Thanks for your help.
regards
Re: Raspberry Pi B+ RaZberry and Danfoss LC-13
Posted: Monday 17 November 2014 0:13
by Crom
here are the specifications:
Posted: Tuesday 05 January 2016 22:36
by pepeEL
Hello
I today buy Danfoss Living COnnect 014G0013 and on box is write SW 1.01 I have connected it with my Aeotec Z-Stick S2 on my latest beta domoticz. I add to Utilitty SET POINT device and second Thermostat Clock. I set temp by Domoticz but i can not set Date and Time. When i try it i have info:
Setting The Closck is not finished yet.
And Date and Time is not change.
Please help me.
Posted: Tuesday 05 January 2016 22:49
by Egregius
Why would you need a clock in a valve if you have endless possibilities to schedule in domoticz?
Posted: Tuesday 05 January 2016 23:02
by pepeEL
Because in devices found me this device as Thermostat Clock and when i add this to Utility time and date is wrong. Is no way to set the clock ? Ofcourse i have version LC-13
Posted: Saturday 09 January 2016 18:17
by Olifant1990
Quote from the manual from Danfoss:
"To keep the radiator valve functional and at its best, living connect® automatically exercises the
valve every Thursday at approx. 11:00 hrs by opening it fully and then return to normal setting."
It is usefull to know when it happens sometimes.
Besides, it is just a "normal" Command class which would be fine if it works :)
There are more devices which use this class I guess.
Also when you go to hardware->setup (of controller)->control panel (OpenZWave Control Panel and select the thermostat, you can set the clock hour and minutes. But when you click on submit, nothing happens...
When you select the controller and go back to the thermostat, the time is as it was before...
Posted: Wednesday 13 January 2016 23:16
by trollmar
also ordered and installed the Danfoss.
+1 if its possible to set setpoint.
Maybe its also possible to add Battery Status of the danfoss in future updates of Domoticz ;-)
greetz
trollmar
Posted: Thursday 14 January 2016 7:28
by Egregius
You can set the setpoint and you see the battery level.
Posted: Friday 15 January 2016 17:00
by Olifant1990
Indeed, in the "Devices" view you see the battery state.
And I am able to change the setpoint temperature.
Only the clock is not working...
