Wind direction string in Dial
onkelgeorg
Domoticz version: 2023.1
Post by onkelgeorg »
after creating my dashboard without asking here, but reading carefully, I came around a problem which may have not been addressed before:
I want to show the wind direction string in my wind dial, but it doesn't work no matter what I try.
The string is present in the json output:
sorry, I tried to post the json output here, but phpBB denied to do so
And it appears with the 'normal' data display but not shown in the dial after I switch to 'values'
For the screenshot I added the numbers instead of the string, but if I change it to "DirectionStr" or "Data1" it remains empty.
Any help is highly appreciated
Cheers,
Joerg
willemd
Re: Wind direction string in Dial
Post by willemd »
Found it.
If you add the following to the dial definition, it will show the direction as text (short):
    values: [
            value: 'DirectionStr',
            label: 'From',
            type: 'text',
specifically the line "type: 'text'" solves the issue
onkelgeorg
Yes, you are the greatest! It works perfectly.
Thanks a lot for sharing 👍
