Domoticz starting failed (Raspberry Pi 400 Bullseye)
elythomaslumber
Domoticz version: 2023.1
Post by elythomaslumber »
I have setup a Pi400 with Bullseye and installed Domoticz latest version.
After power connect the Pi is booting and I have access via WINSCP / Putty. System is up.
But Domoticz will not start 100%. I do not have access via browser.
When I do a reboot (sudo reboot) the Pi reboots and Domotich comes up, is working perfectly from browser.
Second variant is, I boot with powering up, open Putty and start Domoticz manually by
- sudo service domoticz stop
- sudo service domotich start
Now running perfectly. I think can install the above commands in etc/rc. local but this is only a workaround.
So there is the question what happens that Domoticz will not start after first power up?
Cheers,
Hardy
Re: Domoticz starting failed (Raspberry Pi 400 Bullseye)
Known issue for cold boot (no power):
https://www.domoticz.com/wiki/Troublesh ... _cold_boot
