In zwave-js-ui i See mij usb device and qubino modules.
How can we connect to Domoticz
I tried so much but MQTT gives:
2023-03-22 10:13:15.177 INFO MQTT: MQTT client reconnecting
2023-03-22 10:13:15.181 ERROR MQTT: Mqtt client error connect ECONNREFUSED 127.0.0.1:1883
Error: connect ECONNREFUSED 127.0.0.1:1883
at TCPConnectWrap.afterConnect [as oncomplete] (node:net16)
2023-03-22 10:13:15.183 INFO MQTT: MQTT client closed
We have made a setup in zwave-js-ui for MQTT
localhost port:1883 prefix zwave
We also made a setup for home assistant. Prefix domoticz
Do We need that for Domoticz?
MQTT auto discover in hardware from Domoticz
Discover domoticz
How can we solve the problem?
Zwave MQTT problem.
- gizmocuz
Re: Zwave MQTT problem.
Well the error is:
Can you connect to it with MQTT Explorer?
So it is a connection issueERROR MQTT: Mqtt client error connect ECONNREFUSED 127.0.0.1:1883
Dave47
- Target OS: -
- Domoticz version: 2023.1
No. We use MQTT with lan interface in Domoticz
There we have localhost port 1883. We need that for Node-Red. That works well.
We can not connect to it with MQTT Explorer. Not with 127.0.0.1
and not with raspberry_ip_adres.
We have also tried with MQTT discover in Domoticz., need for zwave-js-ui on the same port.
