Zigbee4Domoticz groups
Posted: Tuesday 21 March 2023 23:13
@pipiche
I am not able to add devices to a group. I can make a new group but not able to add devices to the group. The device disappears after I press on validate.
I did a group scan on devices etc. The groupslist-xx.json file is writable, I see that the group (test) is added to the json.
It worked before but it seems that it is failing after updating to Plugin: 6.3.011
The extra group I had disappeared after the update.
- Z4DGroup-validat.png (34.38 KiB) Viewed 502 times
After click on Validate the device dissapears
- Z4DGroup-validat-error.png (33.51 KiB) Viewed 502 times
Re: Zigbee4Domoticz groups
Posted: Tuesday 21 March 2023 23:21
Addition: After some further testing it seems that I cannot add the devices that were earlier in that disappeared old group.
I can add other devices that were not part of the old group.
Can I reset group settings on a device?
Posted: Tuesday 21 March 2023 23:28
by pipiche
The group is a kind of virtual concept, and in reality each device knows which group it belongs too.
So if you want to reset the group membership of a device you should reset it , if the manufacturer has not make it persistent.
If you want to add a device to a group, and it doesn't happen, in general the device reject to be added. Do you have any logs in the PluginZigbee-xx.log file ?
Posted: Tuesday 21 March 2023 23:36
See attached log file (with group debug already enabled)
Posted: Wednesday 22 March 2023 19:51
by pipiche
@waltervl is the device you wanted to add is that one ['9d5d' / 'd0cf5efffe291ddf']
Could you kindly give me the export.json of the Plugin Raw Devices ?
Posted: Wednesday 22 March 2023 23:41
Tomorrow evening, not close to my system now.
Posted: Thursday 23 March 2023 19:17
The devices I want to add in the group are
76c7 90fd9ffffee58799
9d5d d0cf5efffe291ddf
68ac 000d6ffffe268b00
See also attached export
Posted: Friday 24 March 2023 16:50
by pipiche
@waltervl I don't see much explaining why it is not successful integrating the group.
Did you try to just Powered Off and the On those Bulb and then create the group ?
Posted: Friday 24 March 2023 17:47
Yes, perhaps I have to reset the zigbee devices and re-pair them again.
