Domoticz start with the Zigbee2MQTT dashboard
Posted: Sunday 12 March 2023 16:37
by Bospieper
Normally my Domoticz start with the Aurora theme but now it shows the Zigbee2MQTT Dashboard.
How can I change that to where I can use both.
Grz. Piet
Re: Domoticz start with the Zigbee2MQTT dashboard
Posted: Sunday 12 March 2023 23:06
Then it seems you use the same port for zigbee2mqtt dashboard as the Domoticz dashboard. You have to change one of them.
Posted: Monday 13 March 2023 10:10
by Bospieper
Hi Waltervl,
That thougt came across my mind but changing port on the Zigbee2mqtt side didn't solved the problem.
Grz. Piet
Posted: Monday 13 March 2023 11:54
by thomasbaetge
did you clear the browser cache after changing the port?
Posted: Monday 13 March 2023 23:20
by Bospieper
Hi thomasbaetge,
With every change I make, I alsways clear the brower cache. It becomes a kind of automatic action
Posted: Tuesday 14 March 2023 8:41
Bospieper wrote: Monday 13 March 2023 10:10
Hi Waltervl,
Grz. Piet
It should. Did you restart Zigbee2MQTT? Default port of Zigbee2MQTT Frontend is 8080. So you have to change that in the docker startup or docker compose (if you use that):
https://www.zigbee2mqtt.io/guide/instal ... er-compose
