Domoticz start with the Zigbee2MQTT dashboard
Bospieper
Post by Bospieper »
Normally my Domoticz start with the Aurora theme but now it shows the Zigbee2MQTT Dashboard.
How can I change that to where I can use both.
Grz. Piet
Re: Domoticz start with the Zigbee2MQTT dashboard
Then it seems you use the same port for zigbee2mqtt dashboard as the Domoticz dashboard. You have to change one of them.
Bospieper
Post by Bospieper »
Hi Waltervl,
That thougt came across my mind but changing port on the Zigbee2mqtt side didn't solved the problem.
Grz. Piet
thomasbaetge
Domoticz version: 2023.1
Post by thomasbaetge »
did you clear the browser cache after changing the port?
Bospieper
Post by Bospieper »
Hi thomasbaetge,
With every change I make, I alsways clear the brower cache. It becomes a kind of automatic action :)
Bospieper wrote: Monday 13 March 2023 10:10 Hi Waltervl,
Grz. Piet
It should. Did you restart Zigbee2MQTT? Default port of Zigbee2MQTT Frontend is 8080. So you have to change that in the docker startup or docker compose (if you use that):
https://www.zigbee2mqtt.io/guide/instal ... er-compose
