All
I have a Domoticz Version: 2023-1 running on Raspberry4 and i try to monitor my Solar installation based on SOFAR inverter with LSW3 wifi Dongle.
I found and install from "Sofar_LSW3" API found in Gitub
This API use MQTT , I install it on the raspberry including MQTT client
Everything installed and configured properly (i guess)
Using MQTT explorer I can see that API is reading the data from the Inverter
On Domoticz I created the "MQTT client gateway with LAN interface" called SOLAR
Starting this point i am lost and did not succeed to get any Device updated.
Note: The hardware "MQTT..." did not allow virtual sensor creation
I get in Domoticz log the following error "Error: SOLAR: disconnected, restarting (rc=14/Protocol error)"
I googled the error and did not found any relavant answer.
Did not see what I am doing wrong.
Getting data from SOFAR-LSW3 via MQTT
- FireWizard
Re: Getting data from SOFAR-LSW3 via MQTT
Hello @jool91,
It is clear to me, why this will never work.
The MQTT interface into Domoticz requires a specific syntax. Like http.
You can find this at https://www.domoticz.com/wiki/MQTT
The MQTT output of your API, which you see in MQTT Explorer, does not match the requirements of Domoticz. You will need a conversion. Node-RED is the tool to use.
See: https://nodered.org/
jool91
Thanks FireWizard
This was not clear in the installation / configuration a read.
I will have a try installing NodeRed and let you know
Brs
Brs
- Domoticz version: 2026.3
There is now an alternative Python plugin that can map unsupported MQTT messages to Domoticz devices through a configuration file:
viewtopic.php?f=65&t=39279
