problem changing linux file-permissions
BartSr
Domoticz version: V2024.7
Post by BartSr »
I am struggling to hav a file "pi" permission i.s.o. root.
The aim is to create a textfile holding values of gasmeter. At regular times I want to inspect the content of the file (gas.txt).
But although I used the command : 'sudo chmod 777 ' .. 'gas.txt' it still only has root permissions.
The script is OK but not for changing permissions. What to do?
		devices = {
		    913, --switch to force the script to run for testpurpose
		timer = {
			'at 07:00',
			'at 19:00',
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'BSOtest',
	execute = function(dz, timer)
	    local gasstand = dz.devices(762).counter -- 762 is IDX gasmeter
	    local datetimestamp = tostring(os.date('%Y-%m-%d %H:%M:%S'))
	    file = io.open("/home/pi/gas.txt", "a+")
	    dz.utils.osCommand('sudo chmod 777 '  .. 'gas.txt')
	    file:write(datetimestamp.." gasstand "..gasstand.."\n")
        file:close()
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
BartSr
Re: problem changing linux file-permissions
Post by BartSr »
in addition using command on RaspberryPi commandline ( sudo chmod 777 ' .. 'gas.txt') enables all permissions.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
willemd
Post by willemd »
When you run it on the command line, it is the user pi that requests and receives root permission, so it works.
When you run it from domoticz, it is probably the user domoticz and if that user is not configured to receive sudo permission, it will not work.
It needs to be maintained in /etc/sudoers. Do a google search for more detail.
BartSr
Post by BartSr »
Thanks willwmd.
Will look it up.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
