Solax data
hnogueira
Solax data
Post by hnogueira »
Hi all:
some users have been looking (as myself) for a way to get Solax data into Domoticz. there's some plugins, but also a easy way via Dzvents.
bellow code I use.
Helder Nogueira
hnogueira
Re: Solax data
Post by hnogueira »
-- Script to retrieve real-time data from a Solax solar inverter and update a Domoticz device
-- Define triggers for the script
timer = { 'every 2 minutes' },
httpResponses = { 'trigger' }
-- Configure logging settings
logging = {
level = domoticz.LOG_INFO,
marker = 'solar-inverter'
-- Define the main function of the script
-- Handle the timer trigger
if item.isTimer then
domoticz.openURL({
url = 'https://www.solaxcloud.com/proxyApp/pro ... xdfgdstgzg',
method = 'GET',
callback = 'trigger'
-- Handle the HTTP response trigger
if item.isHTTPResponse then
-- Check if the response was successful
if item.ok then
-- Check if the response is in JSON format
if item.isJSON then
-- Extract the relevant data from the response
local inverterData = item.json.result
if inverterData == nil then
-- Log a message indicating failure
domoticz.log('Problemas de comunicação')
domoticz.log(item)
-- Update the Domoticz device with the retrieved data
local device = domoticz.devices('Uso Baterias')
device.updateEnergy(inverterData.batPower)
local device = domoticz.devices('Carga baterias')
device.updateText(inverterData.soc.." %")
local device = domoticz.devices('Consumo Casa')
device.updateElectricity(inverterData.acpower)
-- Log a message indicating success
domoticz.log('Data updated successfully', domoticz.LOG_INFO)
Re: Solax data
Thanks, but please edit your post and put your script in code brackets. That makes it much more readable and easier to copy.
masselb
Domoticz version: 4.10717
Re: Solax data
Post by masselb »
Hey hnogueira,
Thanks for that, I am looking to get solax data in domoticz as well without any exotic stuff which needs config and hours... Question is, when I copy the script I have one device from one Inverter correct? Would it be possible to adjust the script to pull let's say 5 or 6 values from 2 or 3 Inverters? Also, I think the Cloud does not deliver values every 2 mins, one would need to read the data from LAN?
thx,
Bert
Re: Solax data
Did you check the solax plugin viewtopic.php?t=33872
hnogueira
Re: Solax data
Post by hnogueira »
{-- Script to retrieve real-time data from a Solax solar inverter and update a Domoticz device
logging = {
domoticz.openURL({
method = 'GET',
if item.ok then
if item.isJSON then
domoticz.log(item)
hnogueira
Re: Solax data
Post by hnogueira »
@waltervl, I did and could manage to make it work
hnogueira
Re: Solax data
Post by hnogueira »
waltervl wrote: Tuesday 14 March 2023 16:53 Did you check the solax plugin viewtopic.php?t=33872
yes, could make it to work
