Reading values sent to Tasmota via MQTT
ulfh2018
Post by ulfh2018 »
I am working on a project where I use an ESP 12-F chip running Tasmota, to read analog values from a capasitive moisture sensor. These values are sent to a MQTT server, and I pull the information into Node Red, which seems to work as expected. I have used Domoticz before on another project, but then I was using virtual switches, and as far as I understand, this is not possible in this case.
The values I get from MQTT are numbers, but are sent in the following format:
tele/Vann1/SENSOR = {"Time":"2023-03-04T17:03:23","ANALOG":{"Range":85}}
and I need the value of Range to calculate the humidity in the soil.
How can this be done in Domoticz and how can I display the information?
Best regards
Ulf H.
Domoticz version: 2024.7
Re: Reading values sent to Tasmota via MQTT
There is a special Node Red sub-forum viewforum.php?f=81
Or check the tasmota docs on domoticz integration https://tasmota.github.io/docs/Domoticz/
ulfh2018
Post by ulfh2018 »
Node-Red is not a problem. That works as a dream, but I cannot find a way to get the analog values from my sensor to Domoticz. As far as I can see, there are no virtual sensors I can use to pull this kind of info, so maybe I'll stick to Node-Red and se if I can find a way to make a nive display
You can use custom sensor for this, can have anything
https://www.domoticz.com/wiki/Dummy_for ... tom_Sensor
FireWizard
Post by FireWizard »
Hi @ulfh2018,
As I read your first post I understand that you want to send the value of a moisture sensor to Domoticz.
You can use a virtual sensor and configure it as a moisture sensor (value expressed in cb, centiBar).
You receive the input as a JSON object and that can be converted to Domoticz format.
This is not too difficult.
I would also do the calculation in Node Red.
And if it is moisture you can use soil moisture or humidity virtual device. With humidity device you have to add a humidity scale. See the wiki.
