Like many others, I'm using sincze's growatt script to read my solar panel data from the growatt server.
Now I've added a 2nd setup, and registered its datalogger in the growatt portal, under my account.
However, I'm not sure how I can have that data imported in Domoticz.
For now, I can see that the Growatt Inverter-device only shows the information of my first plant.
Any thoughts?
Growatt: 2nd plant/data logger
- Rolandet
- Domoticz version: 2021.1
Custodes Septentrionum
mvanrijnbach
Re: Growatt: 2nd plant/data logger
Hi Rolandet,
I'm not a php expert, but I assumed it must be somewhere in the lines of the script where the URL for the data is setup:
$curl = curl_init();
$url='http://server-api.growatt.com/newPlantA ... EnertyData';
curl_setopt($curl, CURLOPT_URL, $url);
curl_setopt($curl, CURLOPT_COOKIEJAR, COOKIE_FILE);
curl_setopt($curl, CURLOPT_COOKIEFILE, COOKIE_FILE);
curl_setopt($curl, CURLOPT_USERAGENT, USER_AGENT);
curl_setopt($curl, CURLOPT_POSTFIELDS, "language=1" );
curl_setopt($curl, CURLOPT_HTTPHEADER, HEADER);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, 1);
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, 2);
curl_setopt ($curl, CURLOPT_SSLVERSION, 1);
$result = curl_exec($curl);
I guess somebody with PHP experience can answer this question.
Best regards, Michiel.
- Rolandet
mvanrijnbach
Hi Rolandet,
as you can see I also posted an issue with the Growatt script. Do you also have issues that the script doesn't read the power continuously? Are you using the latest version from github?
- Rolandet
The interval is 5 minutes, so indeed it doesn't read the output continuouslymvanrijnbach wrote: Saturday 11 March 2023 9:04 Hi Rolandet,
mvanrijnbach
It is supposed to read it every 5 minutes and it used to do that, but now the data looks like this:
I guess the data doesn't come through every 5 minutes anymore.
I guess I'll try to reset the whole thing and see if it makes any difference.
- Rolandet
Oh right. Well, there's been a lot of chatter about the poor data servers of growatt
