Support for the Lidl (Silvercrest) SMSZ 1 B2 smart motion sensor
lostodos
Post by lostodos »
Is there any lead on when the Lidld/Silvercrest smart motion sensor (model SMSZ 1 B2) will be supported through my Pizigate+?
I had it running on the Pizigate V1 (was recognised and working properly) but under Pizigate+ V2 (firmware 0322) and plugin version 6.3.011 it doesnt seem to get recognised.
Kind Regards,
Mark
pipiche
Re: Support for the Lidl (Silvercrest) SMSZ 1 B2 smart motion sensor
Post by pipiche »
I'm not aware, but please follow this link which give you some information on how to report the needed infos to investigate.
lostodos
Post by lostodos »
Hi Pipiche,
What link are you referring to?
Regards,
Mark
pipiche
Post by pipiche »
lostodos
Post by lostodos »
no worries:)
I get the following information after trying to pair the motion sensor:
Version: "3"
ZDeviceName: ""
Status: "UNKNOW"
SQN: "00"
Ep:
Heartbeat: "4"
RIA: "6"
LQI: 4
Battery:
Model: ""
ForceAckCommands:
MacCapa: "80"
IEEE: "cc86ecfffea414c2"
Type:
ProfileID:
ZDeviceID:
App Version: ""
Attributes List:
DeviceType: "RFD"
HW Version: ""
Last Cmds:
0:
0: 76
1: "02"
2: "10c9"
3: "0110"
4: "0101050000000000010010F000158d00095202e1"
LogicalType: "End Device"
Manufacturer: ""
Manufacturer Name: ""
NbEp: ""
PowerSource: ""
ReadAttributes:
ReceiveOnIdle: ""
Stack Version: ""
Stamp:
time: 1677825611.2251823
Time: "2023-03-03 07:40:11"
MsgType: "8011"
LastSeen: "03/03/2023 07:40:11"
ZCL Version: ""
Health: "Live"
Capability:
0: "Reduced-Function Device"
1: "Standard security"
2: "NwkAddr should be allocated"
ZDPSQN: "02"
PairingInProgress: true
RollingLQI:
0: 106
1: 4
ConsistencyCheck: "Bad Pairing"
NwkID: "10c9"
Doesn't say much to me other then that pairing doesn't seem to go well... do you see any specific things in there that might point to a cause?
lostodos
Post by lostodos »
Got it to work already. The manual say hold the pin in the small hole on the side for 5 seconds but after 2 seconds the green led start blinking fast and that is the point that the pin needs to be released, not at 5 seconds as it seems to break of the pairing at that point.
Got it paired now and see it in Domoticz to.
Thanks for the help!
