P1 Gas data not stored in Managed Counter
JustDude
Domoticz version: Latest
Post by JustDude »
This is the flow to add P1 data from Node-red to Domoticz
However the Managed Counter (tyoe Gas for this try out) is not updated in Domoticz
What am I doing wrong?
Warning: Newbie on Node-Red and Domoticz :!:
Screenshot 2023-03-01 at 21-54-35 Node-RED 192.168.2.7.png (36.14 KiB) Viewed 7556 times
Measuring is knowing
FireWizard
Re: P1 Gas data not stored in Managed Counter
Post by FireWizard »
Hi @JustDude,
1. Can you publish your flow?
2. Can you connect a Debug node to the MQTT input node, called Read dsmr Gas?
Please publish the results of that Debug node.
JustDude
Post by JustDude »
Thanks for taking the time to looking onto this:
        "id": "76a5d1b7.ed381",
        "type": "tab",
        "label": "P1monitor Data Import",
        "disabled": false,
        "info": ""
        "id": "8df1efad74bf4ddc",
        "type": "mqtt out",
        "z": "76a5d1b7.ed381",
        "name": "Send MQTT to Domonticz",
        "topic": "domoticz/In",
        "qos": "2",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "f9f13036.e28b58",
        "x": 790,
        "y": 220,
        "wires": []
        "id": "910303dcec5d5d55",
        "type": "function",
        "name": "Store IDX Power",
        "func": "//if mpayload.P1_consumed \nmsg.payload = { \"command\": \"udevice\", \"idx\": 129, \"usage\": msg.payload.P1_consumed + \";0\", \"return\": msg.payload.P1_generated + \";0\" }\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 570,
        "y": 260,
        "wires": [
        "id": "0f45f1515688ccc7",
        "type": "mqtt in",
        "name": "Read dsmr EL",
        "topic": "test_dsmr/el",
        "qos": "2",
        "datatype": "auto-detect",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 110,
        "y": 80,
        "wires": [
        "id": "04cfacc53718b421",
        "type": "comment",
        "name": "Test DSMR for now",
        "info": "",
        "x": 110,
        "y": 220,
        "wires": []
        "id": "4efba523b05ff7c6",
        "type": "switch",
        "name": "Filter",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "gas_consumed",
                "vt": "str"
                "t": "eq",
                "v": "P1_consumed",
                "vt": "str"
                "t": "eq",
                "v": "P1_generated",
                "vt": "str"
        "checkall": "false",
        "repair": true,
        "outputs": 3,
        "x": 390,
        "y": 260,
        "wires": [
                "88737b2f75bb95ed"
                "910303dcec5d5d55"
        "id": "a5f675ed14c7b626",
        "type": "split",
        "name": "",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "arraySpltType": "len",
        "stream": false,
        "addname": "topic",
        "x": 270,
        "y": 260,
        "wires": [
                "4efba523b05ff7c6"
        "id": "b34696bab8933e0b",
        "type": "mqtt in",
        "name": "Read dsmr Gas",
        "topic": "test_dsmr/gas",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 120,
        "y": 260,
        "wires": [
                "a5f675ed14c7b626",
                "5ee7cd5893fdc546"
        "id": "88737b2f75bb95ed",
        "type": "function",
        "name": "Store IDX Gas",
        "func": "//if (msg.topic == \"p1monitor/smartmeter/consumption_gas_m3\") {\n//    msg.payload = { \"idx\": 10, \"svalue\": msg.payload.toString() };\n//    return msg;\n//}\n\n// {\"command\":\"udevice\", \"idx\":1234, \"svalue\":\"3.45\", \"parse\": false}\nmsg.payload = { \"command\": \"udevice\", \"idx\": 135, \"svalue\": msg.payload, \"parse\": false};\nreturn msg;\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 560,
        "y": 200,
        "wires": [
                "8316c64589c8cfa5",
                "8df1efad74bf4ddc"
        "id": "8316c64589c8cfa5",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 740,
        "y": 140,
        "wires": []
        "id": "5ee7cd5893fdc546",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 300,
        "y": 160,
        "wires": []
        "id": "f9f13036.e28b58",
        "type": "mqtt-broker",
        "name": "Domoticz 192.168.2.7",
        "broker": "192.168.2.7",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "5",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
Screenshot 2023-03-02 at 16-50-25 MK.png (31.85 KiB) Viewed 7532 times
Screenshot 2023-03-02 at 16-54-25 Node-RED 192.168.2.7.png (26.13 KiB) Viewed 7532 times
FireWizard
Hi @JustDude,
I checked your flow and discovered a few things.
1. I believe the data from the dsmr reader is not complete, unless you receive the Electricity data and Gas data in different topics.
It looks that, that is the case as the topic from the MQTT node is test_dsmr/gas.
2. I do not understand the functionality of the "Split" node. So this one I have removed from the flow.
3 The "Switch" node filters on topic. So, as the topic is "test_dsmr/gas", I filter on contains "test_dsmr/gas".
No reason to filter on "gas_consumed" as this is not part of the topic but it is part of the payload.
4.You are interested is the value of "gas_consumed" (and not in the "serial" or "timestamp")
5.Your msg.payload from the "Function" node has to be changed a little.
It will become:
msg.payload = { "command": "udevice", "idx": 135, "svalue": msg.payload.gas_consumed.toString(), "parse": false};
return msg;
You will send an object to the MQTT output node (See between {})
- "command": "udevice". This is the default and may be omitted.
- "idx": 135. That is ok and should be a number. It is.
- "svalue" represent always a String, so the value should be a String.
If you hoover with your mouse over the text "gas_consumed" in "Debug 3", you will see at the right some extra buttons.
The first one represents the path of gas_consumed, the second one the value and the third (last) pins the selected element.
See: https://nodered.org/docs/user-guide/messages
In this case the value of "svalue" has to be: msg.payload.gas_consumed instead of only msg.payload.
As it should be a String and the value of gas_consumed is a number (blue) we have to add the toString() function.
"parse": false is optional
See the flow below. Test it and let me know.
        "type": "mqtt out",
        "qos": "2",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1240,
        "y": 160,
        "wires": []
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1150,
        "y": 240,
        "wires": [
        "type": "comment",
        "info": "",
        "x": 530,
        "y": 100,
        "wires": []
        "type": "switch",
        "name": "Filter",
        "rules": [
                "t": "cont",
                "v": "test_dsmr/gas",
                "vt": "str"
                "t": "eq",
                "v": "P1_consumed",
                "vt": "str"
                "t": "eq",
                "vt": "str"
        "repair": true,
        "outputs": 3,
        "x": 730,
        "y": 180,
        "wires": [
                "88737b2f75bb95ed"
                "910303dcec5d5d55"
        "type": "mqtt in",
        "d": true,
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 540,
        "y": 140,
        "wires": [
                "5ee7cd5893fdc546"
        "type": "function",
        "func": "//if (msg.topic == \"p1monitor/smartmeter/consumption_gas_m3\") {\n//    msg.payload = { \"idx\": 10, \"svalue\": msg.payload.toString() };\n//    return msg;\n//}\n\n// {\"command\":\"udevice\", \"idx\":1234, \"svalue\":\"3.45\", \"parse\": false}\nmsg.payload = { \"command\": \"udevice\", \"idx\": 135, \"svalue\": msg.payload.gas_consumed.toString(), \"parse\": false};\nreturn msg;\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 960,
        "y": 160,
        "wires": [
                "8316c64589c8cfa5",
                "8df1efad74bf4ddc"
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1180,
        "y": 120,
        "wires": []
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 740,
        "y": 120,
        "wires": []
        "id": "932850c4abfecca5",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "test_dsmr/gas.",
        "payload": "{\"gas_consumed\":10142194,\"serial\":\"33313137\",\"timestamp\":1677772436}",
        "payloadType": "json",
        "x": 550,
        "y": 180,
        "wires": [
                "5ee7cd5893fdc546",
                "4efba523b05ff7c6"
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
JustDude
Post by JustDude »
OK, that clarifies a lot of my mistakes.
Thanks for the elaborate explanation. Kudos
I changed the topic subscription to gas and electricity using a #
the filter on topic solves the message formatting
The MQTT explorer view:
Screenshot from 2023-03-03 07-41-20.png (18.04 KiB) Viewed 7518 times
I see now that the counter date / time is updated when a message comes in, but no data is stored or a graph is visible.
So one step ahead thanks to your help :D
After work I will recreate the counter and start fresh.
I let you know the results.
FireWizard
Hello @JustDude.
Some more hints.
If you look to the data presented in MQTT Explorer, you see that the following "sub" topics are presented under test_dsmr.
So, if you take as topic in the MQTT Input node "test_dsmr/#", you wil get:
- system
- el
- gas
- status
- sw-version
I do not think you are interested in system and sw-version. Perhaps you want to monitor the status.
After the MQTT input node you have 2 options.
Option 1.
Connect a "Function" node to the MQTT Input node and with an "If....Then" statement you can split the correct topics.
Option 2.
Connect a "Swith" node as you did before, but 2 outputs are sufficient (unlesss you want to use "Status").
See below:
I configured "Checking all rules", because I wanted to process both gas and el in parallel.
I switched also "recreate message sequences" off. You do not need that. It is not important which data arrives first in Domoticz, because they are independent of each other.
For electricity I can only see:
- P1_consumed
- P1_generated
- P2_consumed
- P2_generated
I assume that you want to use a P1 Smartmeter device in Domoticz.
This device needs 6 values.
Beside the 4 mentioned above, it needs also actual consumption and actual production.
See: https://piandmore.wordpress.com/2019/02 ... -domoticz/
P1 Smart meter
The P1 Smart meter sensor allows you to show you power consumption, low and high usage, low and high return, actual consumption and actual return.
{"command":"udevice", "idx":1234, "svalue":"lu;hu;lr;hr;ac;ar"}
where lu is low tariff usage (in Wh so 1000 is 1 kWh), hu is high tariff usage (in Wh), lr is low tariff return (in Wh), hr is high tariff return (in Wh), ac is actual consumption (in W) and ar is current usage (in W).
Note: current usage is wrong. Should be: actual production,
If you follow the same approach as with the Gas. you will get a very long line after "msg.payload". You can make the whole line vissible with a horizontal scrollbar, but it is easier to use 6 variables instead.
See the following example in the "Function" node:
let us1 = msg.payload.P1_consumed.toString();
let us2 = msg.payload.P2_consumed.toString();
let ret1 = msg.payload.P1_generated.toString();
let ret2 = msg.payload.P2_generated.toString();
let cons = msg.payload.xxxxxxxx.toString();
let prod = msg.payload.yyyyyyyy.toString();
msg.payload = {"command": "udevice", "idx": 129, "svalue": us1 + ";" + us2 + ";" + ret1 + ";" + ret2 + ";" + cons + ";" + prod};
return msg;
You have to fill in xxxxxxxx and yyyyyyyy yourself.
So you see, you have an easier overview instead of using the full message path, such as "msg.payload.P1_consumed.toString()".
See the flow below:
        "type": "mqtt out",
        "qos": "2",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1240,
        "y": 180,
        "wires": []
        "type": "function",
        "func": "let us1 = msg.payload.P1_consumed.toString();\nlet us2 = msg.payload.P2_consumed.toString();\nlet ret1 = msg.payload.P1_generated.toString();\nlet ret2 = msg.payload.P2_generated.toString();\nlet cons = msg.payload.xxxxxxxx.toString();\nlet prod = msg.payload.yyyyyyyy.toString();\n\nmsg.payload = {\"command\": \"udevice\", \"idx\": 129, \"svalue\": us1 + \";\" + us2 + \";\" + ret1 + \";\" + ret2 + \";\" + cons + \";\" + prod, \"parse\": false};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 950,
        "y": 200,
        "wires": [
                "8df1efad74bf4ddc"
        "type": "comment",
        "info": "",
        "x": 530,
        "y": 100,
        "wires": []
        "type": "switch",
        "name": "Filter",
        "rules": [
                "t": "cont",
                "vt": "str"
                "t": "cont",
                "v": "test_dsmr/el",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 730,
        "y": 180,
        "wires": [
                "88737b2f75bb95ed"
                "910303dcec5d5d55"
        "type": "mqtt in",
        "d": true,
        "name": "Read DSMR",
        "topic": "test_dsmr/#",
        "qos": "0",
        "nl": false,
        "rap": false,
        "rh": 0,
        "inputs": 0,
        "x": 530,
        "y": 140,
        "wires": [
                "5ee7cd5893fdc546"
        "type": "function",
        "func": "msg.payload = { \"command\": \"udevice\", \"idx\": 135, \"svalue\": msg.payload.gas_consumed.toString(), \"parse\": false};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 940,
        "y": 160,
        "wires": [
                "8316c64589c8cfa5",
                "8df1efad74bf4ddc"
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1180,
        "y": 140,
        "wires": []
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 740,
        "y": 120,
        "wires": []
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 550,
        "y": 180,
        "wires": [
                "5ee7cd5893fdc546",
                "4efba523b05ff7c6"
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
JustDude
Post by JustDude »
Thanks again, that is what I just did: subscribe to the test_dsmr/# topic and filter the messages.
it seems the Managed Counter does not work as intended (my mistake or??).
The normal Gas and electricity incremental/P1 counters work, although I need to add the actual usage etc as you mentioned.
Screenshot 2023-03-03 at 16-38-19 MK.png (9.72 KiB) Viewed 7503 times
This is the complete Electrcity message from the python program:
{"P1_consumed":677.0,"P1_generated":0.0,"P2_consumed":56.0,"P2_generated":0.0,"P3_consumed":132.0,"P3_generated":0.0,"V1":231.0,"V1_sags":5,"V1_swells":0,"V2":234.0,"V2_sags":5,"V2_swells":0,"V3":233.0,"V3_sags":4,"V3_swells":0,"el_consumed":23679674.0,"el_returned":21097674.0,"long_power_failures":12,"p_consumed":866.0,"p_generated":0.0,"power_failures":1373,"serial":"33363137","timestamp":1677857885}
As it seems the code https://github.com/hansij66/dsmr2mqtt/ can be adapted easily to publish more or less topics.
No clue if that is from a user on this forum...
P_consumed and P_generated is already a total.
Huge learning curve but I learned a lot thanks to the help and insight.
I Continue learning ;)
Cannot comment on your issue but are you sure you want to use the managed counter instead of the normal counter as you have to calculate the daily history yourself while normal counter does that for you every night.
JustDude
Post by JustDude »
waltervl wrote: Friday 03 March 2023 18:30 while normal counter does that for you every night.
Ok, good to know, I was already planning to use the normal counter, still testing it.
Thanks for the tip
