Page 1 of 2
Zwave JS- UI install how. Help please!
Posted: Wednesday 01 March 2023 12:18
by Dave47
Hi.
Do i need all these commands to install docker on raspberry pi
# Using volumes as persistence
docker run --rm -it -p 8091:8091 -p 3000:3000 --device=/dev/serial/by-id/insert_stick_reference_here:/dev/zwave \
--mount source=zwave-js-ui,target=/usr/src/app/store zwavejs/zwave-js-ui:latest
# Using a local folder as persistence
mkdir store
-v $(pwd)/store:/usr/src/app/store zwavejs/zwave-js-ui:latest
# As a service
wget https://raw.githubusercontent.com/zwave-js/zwave-js-ui/master/docker/docker-compose.yml
docker-compose up
Also this:
I have open zwave at the moment. In open zwave it works fine accept one Qubino module.
i'm a little nervous about installing this.
Can i go back if its going wrong.
What is the first step. We have MQTT. Which install code.
Do i need all i write in the beginning?
Re: Zwave JS- UI install how. Help please!
Posted: Friday 03 March 2023 14:11
by gizmocuz
No and please use docker-compose
by gizmocuz
sudo apt-get update && sudo apt-get upgrade
curl -fsSL test.docker.com -o get-docker.sh && sh get-docker.sh
sudo usermod -aG docker ${USER}
sudo systemctl enable docker
sudo reboot
Posted: Wednesday 15 March 2023 10:38
by Dave47
I dont understand.
Can i use this: wget https://raw.githubusercontent.com/zwave ... ompose.yml
docker-compose up
Or how can i do/typ?
sudo reboot
Can i use it how you write it here?
Posted: Wednesday 15 March 2023 10:51
by Dave47
I read domoticz wiki how yo install docker. Which command is the best to use and run docker.
I typ in ssh only
sudo reboot
In wiki is different explenation.
Posted: Wednesday 15 March 2023 14:16
by waltervl
Dave47 wrote: Wednesday 15 March 2023 10:51 I read domoticz wiki how yo install docker. Which command is the best to use and run docker.
I typ in ssh only
sudo reboot
This is an instruction to install docker. After that you have to configure the [edit] zwavejsui docker with docker compose.
Posted: Wednesday 15 March 2023 15:55
by Dave47
with http://localip:8091/control-panel can we see the interface but no devices from zwave?
We did the setup as
version: "3.7"
services:
  zwave-js-ui:
    container_name: zwave-js-ui
    image: zwavejs/zwave-js-ui:latest
    restart: always
    tty: true
    stop_signal: SIGINT
    environment:
      - SESSION_SECRET=mysupersecretkey
      - ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
      # Uncomment if you want log times and dates to match your timezone instead of UTC
      # Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
      #- TZ=America/New_York
    networks:
      - zwave
    devices:
      # Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
      # Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
  - "/dev/serial/by-id/usb-0658_0200-if00
    volumes:
      - zwave-config:/usr/src/app/store
   # Or by using local folder
   # - ./store:/usr/src/app/store
    ports:
      - "8091:8091" # port for web interface
      - "3000:3000" # port for Z-Wave JS websocket server
networks:
  zwave:
volumes:
  zwave-config:
Posted: Tuesday 21 March 2023 11:41
by thomasbaetge
so...please go to the directory, where you have the docker-compose.yaml for Z-vase JS Ui and run
docker compose down there
Posted: Tuesday 21 March 2023 12:37
by Dave47
Ok. I did this in docker/zwjs
pi@raspberrypi:~/docker/zwjs $ docker
compose down
[+] Running 1/1
⠿ Network zwjs_zwave Removed 0.8s
docker compose ls
Gives
compose ls
NAME STATUS
CONFIG FILES
domoticz running(1)
/opt/domoticz/docker-compose.yml
But there is no file anymore
Posted: Tuesday 21 March 2023 12:52
by thomasbaetge
domoticz is a different container.
What do you mean by 'no file anymore'?
anyway, you should now be able to start your new ZWJS container
Posted: Tuesday 21 March 2023 13:00
by Dave47
In the beginning i install docker like this:
sudo reboot
And then:mkdir /opt/domoticz
cd /opt/domoticz
In that folder i create docker-compose.yml with;
version: '3.3'
services:
domoticz:
image: domoticz/domoticz:stable
container_name: domoticz
restart: unless-stopped
# Pass devices to container
# devices:
# - "/dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyACM0"
ports:
- "8080:8080"
volumes:
- ./config:/opt/domoticz/userdata
environment:
- TZ=Europe/Amsterdam
#- LOG_PATH=/opt/domoticz/userdata/domoticz.log
I removed this docker-compose.yml file out of domoticz folder.
Posted: Tuesday 21 March 2023 13:01
by Dave47
sudo reboot
cd /opt/domoticz
version: '3.3'
services:
domoticz:
# devices:
ports:
- "8080:8080"
volumes:
environment:
what is the best way to do that?
This is the same container as we did with docker compose down
Posted: Tuesday 21 March 2023 13:26
by Dave47
The problem is comming from opt/domoticz/docker-compose.yml
But i cant remove zwavejs there?
Posted: Tuesday 21 March 2023 13:32
by thomasbaetge
why did you remove your docker-compose.yaml for domoticz?
that was running already, so no need to touch it.
the docker-compose.yaml for ZWJS needs to go into a different folder and has to be started from there
Posted: Tuesday 21 March 2023 13:36
by Dave47
Because the file did not work:
version: '3.3'
services:
domoticz:
devices:
ports:
- "8080:8080"
volumes:
environment:
I have a problem i think. Can i remove docker and start from the beginning?
How can i do that?
Posted: Tuesday 21 March 2023 13:41
by Dave47
I make a clean install from Rasberry first en then istall zwave-js-ui first?
Or install dockers with the file docker-compose.yml in
Opt/domoticz?
But /dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyACM0
did not work.
Posted: Tuesday 21 March 2023 13:44
by thomasbaetge
I don't think you need to remove docker.
there is an error in your file above:
Should probably read:
- "/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0"
I think we had that before, Walter pointed this out in the other thread.
Posted: Tuesday 21 March 2023 13:52
by thomasbaetge
there is no need for a fresh install and I assume, your docker installation is fine.
Please see my folder structure vor the various docker containers that I am running below. It's not a Raspberry, but a NUC, but the process is the same.
there is always one folder for each image, inside is the respective docker-compose.yaml and required subfolders for persistant data storage.
This is REALLY simple.
Bildschirmfoto vom 2023-03-21 13-47-14.png (25.64 KiB) Viewed 4066 times
Posted: Tuesday 21 March 2023 14:05
by Dave47
ok but these docker-compose.yml file version 3.3 is not there.
Ok but /zwjs docker compose up Is not possible because its running another zwave with that name.
Its not possible for me i think so.
Posted: Tuesday 21 March 2023 14:09
by thomasbaetge
I don't understand.
if you have a zwjs container up and running, what is the problem then?
