Dear friends,
Found in the logfile.
2023-02-18 23:30:20.544 Status: Domoticz V2023.1 (c)2012-2023 GizMoCuz
2023-02-18 23:30:20.544 Status: Build Hash: f9b9ac774, Date: 2023-02-14 15:06:40
2023-02-18 23:30:20.544 Status: Startup Path: /home/domoticz/domoticz/
2023-02-18 23:30:20.601 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2023-02-18 23:30:20.618 Status: WebServer(HTTP) started on address: :: with port 8080
2023-02-18 23:30:20.637 Status: WebServer(SSL) started on address: :: with port 443
2023-02-18 23:30:20.666 Status: TCPServer: shared server started...
2023-02-18 23:30:20.667 Status: RxQueue: queue worker started...
2023-02-18 23:30:22.667 Status: P1: Using serial port: /dev/ttyUSB0
2023-02-18 23:30:22.703 Status: P1: Using serial port: /dev/ttyUSB0
2023-02-18 23:30:22.703 Status: P1: Worker started...
2023-02-18 23:30:22.727 Status: P1: Worker started...
2023-02-18 23:30:22.727 Status: NotificationSystem: thread started...
2023-02-18 23:30:22.728 Status: EventSystem: reset all events...
2023-02-18 23:30:22.733 Status: EventSystem: reset all device statuses...
2023-02-18 23:30:22.798 Status: EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2023-02-18 23:30:22.799 Status: EventSystem: Started
2023-02-18 23:30:22.799 Status: EventSystem: Queue thread started...
2023-02-18 23:30:23.464 Status: P1: Meter reports as ESMR 5.0
2023-02-18 23:30:23.512 Status: P1: Found gas meter on M-Bus channel 1
2023-02-18 23:30:24.423 Status: P1: Meter reports as ESMR 5.0
2023-02-18 23:30:24.509 Status: P1: Found gas meter on M-Bus channel 1
Tried to solve earlier stops in reading the P1 and having to restart by powering down and restart the domoticz software
thanks in advance
Ger
P1 monitoring with OrangePi log file read out
Re: P1 monitoring with OrangePi log file read out
in fact the question is : how to install the latest libpython3.x library
- Domoticz version: 2025.1
What Os is on your system?
Did you check the wiki page using python plugins? https://www.domoticz.com/wiki/Using_Python_plugins
If it is not there then use (where 'x' is the version from above: e,g libpython3.4 or libpython3.5 etc):
sudo apt install libpython3.x
