A few changes on puplipice Dashticz
Posted: Sunday 19 February 2023 19:38
by Daro1003
Hello
1. I wanted to make some changes to the dashticz desktop.
The first is at the bottom I have large dots pressing a given dot I enter the screen assigned to this dot but the problem is that the dots are close to each other how to spread them apart?
2. At the top on the main bar next to the name and before the date and time or after the date and time I would like to add the temperature from Domoticz is it possible?
Re: A few changes on puplipice Dashticz
Posted: Thursday 09 March 2023 15:14
by NilsNijenhuis
1 : yes indeed, the dots are a little too close together, you can also use the swipe function to swipe to the next screen.
but adjusting de dot distance or the size of the dots would be usefull
2 : i don't use the top main bar, i use time, date and temp as blocks in the rest of the dashboard. i dont think its very usefull to use it in the top because you can't style that tekstform
Posted: Friday 31 March 2023 8:19
by Daro1003
And you see valuable information to replace the bar with blocks. I also see that you have reduced the spacing between the blocks and there are practically no them at all, which also gives you more space.
Where are these gaps reduced?
Posted: Saturday 01 April 2023 15:41
by HansieNL
To reduce the space between the blocks you can use the following code in custom.css
.transbg[class*="col-xs"] {
    border-width: 1px !important;
