Hello all,
Sinds a few days i am noticing following error in my Zigate logs (and in Domoticz logs):
Error: Zigate: NXP_Extended_Error_Code - Extended Error Code: [87] No free entries in the extended address table (resource error) - this table is configured in the ZPS Configuration Editor
What does this error mean exactly and how can i fix this? Not sure if this is causing any issues with my Zigbee devices and/or Zigate?
Kind regards,
Mark
Romain2022
Re: Zigate: NXP_Extended_Error_Code
Hello everyone,
I have the same problem since few days.
I am on Domoticz Beta (build 15013), plugin Z4D and I use a Zigate USB key v1 (with the 3.21 firmware).
I have only 20 Devices connected to the Zigate (14 devices and 6 repeater).
This is an error coming from the Zigate itself. We are reporting this error since a recent version.
This can predict some issues when pairing new objects. (PDM corruption). You can contact the Zigate vendor for troubleshooting that
On the other side, if you feel the plugin+zigate behave correctly you can simply disable this log via the WebUI > Tools > Debug (advanced ) and disable NXPExtendedErrorCode
Romain2022
I create a topic in the Zigate forum about this problem : https://zigate.fr/forum/topic/zigate-nx ... ostid-2995
