json api no longer working in latest Beta
stephanvdplas
Domoticz version: 2023.1
Post by stephanvdplas »
I tried to change a setting via the json api, but since a couple of days it doesn't work on my beta environment.
I suspect it having to do with the latest changes of the authentication. But I am unable to troubleshoot at this moment.
When I run
https://user:password@serverDNSname/json.htm?&type=command&param=udevice&idx=1919&nvalue=0&svalue=test
I receive
"status" : "ERR"
A wireshark serverside does show me a valid SSL handshake and some TLS 1.3 data, but it doesn''t help me in troubleshooting.
Can someone help me in troubleshooting this?
Regards,
Stephan van der Plas
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
kiddigital
Post by kiddigital »
If you run that from the browser (ie Chrome) than it does not work a the browser strips the u/p from the request (look at your Wireshark output the see the URL going out).
Try to run the command with curl for example. (Or ‘Invoke-WebRequest’ on Windows Powershell).
Run Domoticz with the debug flags ‘auth,webserver,received’ to see what info Domoticz receives and what the Auth check do.
