Govee support
- galadril
- Domoticz version: latest
Govee support
Is there someone with Govee lights that knows if there is already a Govee Domoticz Python plugin?
They have multiple connection options:
1) There is a public api (you can request api key from the Govee app)
https://govee-public.s3.amazonaws.com/d ... erence.pdf
But this has some tights limits on numbers of calls.
2) Govee also has an Local API within your network:
https://app-h5.govee.com/user-manual/wlan-guide
There are already some Home Assistant plugins available, so others are already exploring the options:
https://github.com/wez/govee-lan-hass
https://community.home-assistant.io/t/g ... api/460757
What do you think??
EDIT: Created a first version of a python plugin
https://github.com/galadril/Domoticz-Govee-Plugin
What do you think??
Re: Govee support
Interesting, I didn't know about option 2.
I've been using option 1, the public API. I just have domoticz send HTTP web curl commands to turn on/off/change color/light intensity of my govee light. Its a cheap light I got for less than $10 on amazon so haven't relied on it too much. Just use it as a status indicator of my house systems.
- galadril
Re: Govee support
Yeah they added support for local UTP api lately i guess..
- galadril
Re: Govee support
Looking at the data, it work be cool to combine the api and local udp api.
You can get the device name etc via the http api, and do the rest of the stuff locally via UDP discovery
curl --location --request GET 'https://developer-api.govee.com/v1/devices' \
--header 'Govee-API-Key: *****'
Would result in:
Here you can get the deviceNamd and match the device key (***) with the values you get from the UDP local api
Would result in:
"data": {
"devices": [
"device": "***",
"model": "H6062",
"deviceName": "Office Light 1",
"controllable": true,
"retrievable": true,
"supportCmds": [
"turn",
"brightness",
"color",
"colorTem"
"properties": {
"colorTem": {
"range": {
"min": 2000,
"max": 9000
"message": "Success",
"code": 200
- galadril
Re: Govee support
Some more curl commands
1_ get state of device
curl --location --request GET 'https://developer-api.govee.com/v1/devi ... del=%model%' \
--header 'Govee-API-Key: %ApiKey%'
2_ turning device on/off
curl --location --request PUT 'https://developer-api.govee.com/v1/devices/control' \
--header 'Govee-API-Key: %ApiKey%' \
--header 'Content-Type: application/json' \
--data-raw '{
"device": "%device_id%",
"model": "%model%",
"cmd": {
"name": "turn",
"value": "on"
2_ turning device brightness
--data-raw '{
"model": "%model%",
"cmd": {
"name": "brightness",
"value": 50
"data": {
"device": "***",
"model": "***",
"properties": [
"online": true
"powerState": "on"
"brightness": 50
"color": {
"r": 255,
"b": 0,
"g": 127
"code": 200
--data-raw '{
"model": "%model%",
"cmd": {
"name": "turn",
"value": "on"
"code": 200,
"data": {}
--data-raw '{
"model": "%model%",
"cmd": {
"value": 50
"code": 200,
"data": {}
- breizhcat
Re: Govee support
Hello
Thanks for the information.
I put in place a virtual switch that I managed thanks to MQTT and Node-Red.
And it works fine
Maybe I will dig a bit further the documentation to use RGB values etc.
And it works fine
- galadril
Re: Govee support
Thanks for that, maybe share your red-node export somewhere if possible?
But it would be cool if we could fix a nice python plugin for Domoticz with Govee
- Domoticz version: 2024.7
Re: Govee support
There also seems to be Govee MQTT gateways available so perhaps they are compatible with Domoticz MQTT Autodiscover (HA Protocol).
- galadril
Re: Govee support
Tx!breizhcat wrote: ↑Friday 17 February 2023 8:32 Hi @galadril
Here the export of my NodeRed : https://pastebin.com/VgPbxM7K
- galadril
Re: Govee support
That sounds interesting.. !
- galadril
Re: Govee support
Ive created a Domoticz python plugin.. it can currently set govee lights on / off and brightness and also color
Re: Govee support
Thanks, I added this to the wiki Plugin list https://www.domoticz.com/wiki/Plugins#P ... ugins_List
- galadril
Re: Govee support
Ok tx, i was also adding it to the plugin manager / pp manager repo's
Re: Govee support
I've been using the govee plugin, thanks for writing it! I had a power failure and had to reset my govee permanent outdoor light controller, I had to re-add them to the app. Now the plugin seems to see them but they don't work, no errors in the debug logs. I've set the lights for local api access. Any idea what could be wrong?
Re: Govee support
I think I found the issue. My govee lights got a new IP and it stopped working after that. I had to delete the device from Domoticz and add it again to get it working. I still have random issues where the log says the device index does not exist when used in a script.
- galadril
Re: Govee support
mm interesting!. dont really know yet how to test this scenariopeatmoss wrote: ↑Wednesday 26 June 2024 7:29 I think I found the issue. My govee lights got a new IP and it stopped working after that. I had to delete the device from Domoticz and add it again to get it working. I still have random issues where the log says the device index does not exist when used in a script.
Re: Govee support
thanks for the plugin !
I've an error msg "2024-09-14 21:18:15.476 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly" every 14 seconds,but the light works properly.
If you have a solution, thanks a lot !
Domoticz version is 2024.7 build 16187
This is my debug info
2024-09-14 21:14:25.463 Govee Discover: Worker thread started.
2024-09-14 21:14:25.463 Status: Govee Discover: Started.
2024-09-14 21:14:25.463 Status: Govee Discover: Entering work loop.
2024-09-14 21:14:25.654 Status: Govee Discover: Initialized version 0.0.2, author 'Mark Heinis'
2024-09-14 21:14:25.656 Govee Discover: onStart called
2024-09-14 21:14:25.656 Govee Discover: Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE
2024-09-14 21:14:25.656 Govee Discover: 'HardwareID':'31'
2024-09-14 21:14:25.657 Govee Discover: 'HomeFolder':'/home/pi/domoticz/plugins/Domoticz-Govee-Plugin/'
2024-09-14 21:14:25.657 Govee Discover: 'StartupFolder':'/home/pi/domoticz/'
2024-09-14 21:14:25.657 Govee Discover: 'UserDataFolder':'/home/pi/domoticz/'
2024-09-14 21:14:25.657 Govee Discover: 'Database':'/home/pi/domoticz/domoticz.db'
2024-09-14 21:14:25.657 Govee Discover: 'Language':'fr'
2024-09-14 21:14:25.657 Govee Discover: 'Version':'0.0.2'
2024-09-14 21:14:25.657 Govee Discover: 'Author':'Mark Heinis'
2024-09-14 21:14:25.657 Govee Discover: 'Name':'Govee Discover'
2024-09-14 21:14:25.657 Govee Discover: 'Port':'0'
2024-09-14 21:14:25.657 Govee Discover: 'Key':'GoveeDiscovery'
2024-09-14 21:14:25.657 Govee Discover: 'Mode1':'10000'
2024-09-14 21:14:25.657 Govee Discover: 'Mode6':'-1'
2024-09-14 21:14:25.657 Govee Discover: 'DomoticzVersion':'2024.7 (build 16187)'
2024-09-14 21:14:25.657 Govee Discover: 'DomoticzHash':'6b9cbb21c'
2024-09-14 21:14:25.657 Govee Discover: 'DomoticzBuildTime':'2024-08-22 08:08:34'
2024-09-14 21:14:25.657 Govee Discover: Device count: 1
2024-09-14 21:14:25.657 Govee Discover: Device: 1 - ID: 1725, Name: 'govee_SAM', nValue: 0, sValue: '100'
2024-09-14 21:14:25.657 Govee Discover: Device ID: '1725'
2024-09-14 21:14:25.657 Govee Discover: Device Name: 'govee_SAM'
2024-09-14 21:14:25.657 Govee Discover: Device nValue: 0
2024-09-14 21:14:25.657 Govee Discover: Device sValue: '100'
2024-09-14 21:14:25.657 Govee Discover: Device LastLevel: 100
2024-09-14 21:14:25.657 Govee Discover: Pushing 'PollIntervalDirective' on to queue
2024-09-14 21:14:25.657 Govee Discover: Acquiring GIL for 'onStartCallback'
2024-09-14 21:14:25.657 Govee Discover: Processing 'PollIntervalDirective' message
2024-09-14 21:14:25.657 Govee Discover: Acquiring GIL for 'PollIntervalDirective'
2024-09-14 21:14:25.657 Govee Discover: Heartbeat interval set to: 10000.
2024-09-14 21:15:27.290 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:15:41.293 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:15:55.296 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:16:09.300 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:16:23.303 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:16:37.309 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:16:51.313 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:17:05.328 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
2024-09-14 21:17:19.357 Error: Govee Discover hardware (31) thread seems to have ended unexpectedly
