ESP Easy: Failed HTTP code: 401 after upgrade to beta Topic is solved
PieterS
Domoticz version: 2024.7
Post by PieterS »
Since yesterday I upgraded from last stable 2022.2 to beta 15006. Everything works fine except communication from ESP-devices to Domoticz.
As long as I configure the controller for Domoticz MQTT it works fine.
Devices which use Protocol Domoticz HTTP give the error HTTP : C001 192.168.1.18 GET... failed HTTP code: 401
Firmware on the ESP8266 is version mega-20220809_57b0c0c
I know that security is changed/improved but it should be nice to know how to configure ESP Easy.
So every hint is welcome.
Synology with Domoticz build (V2024.7) in Docker
Herman-H
Re: ESP Easy: Failed HTTP code: 401 after upgrade to beta
Post by Herman-H »
Did you enter at the Controller tab , Credentials, your controller user and controller password?
PieterS
Post by PieterS »
Thnx for reply.
Enabled Extended Credentials, checked username and password. Gave the device a reboot and checked the log of the ESP again. Still the same error.. :evil:
No Authentication-error in the log of Domoticz..
Herman-H
Post by Herman-H »
I can't help you with this problem. But go to letscontrolit.com and ask TD-er or Ath for help
Domoticz version: 2025.1
If they are on the same network, did you add the IP adress of the ESP to trusted network? And if you use http and not https did you set
"Allow Basic Authentication over plain HTTP". Both options are in the security tab of Domoticz menu Setup -> Settings.
See wiki: https://www.domoticz.com/wiki/Security
PieterS
Post by PieterS »
I use the suggested Trusted Networks for years. Didn't change that. It's filled in as noted in the GUI.
@waltervl: Tried API protection before. Didn't mention that. Sorry.
But: I tried it again this morning. And YES!! Your hint works too!
So I thought at the reply of Herman.. I disabled Extended Credentials as API Protection is ON. And there is the error again: HTTP 401...
My lesson is: Both hints were usefull!
Use Extended Credentials and API Protection both Enabled
Thanks gentlemen :D
@waltervl: create a example about this case in the Wiki of Domoticz? That document is rather difficult to read for me/noobs.
This is ESPeasy specific so someone should note this in the esp easy wiki. Beside that this is Domoticz beta behavior and not Domoticz stable.
simat
Domoticz version: 2023.1
Post by simat »
I've only just had to use "Use Extended Credentials and API Protection both Enabled" after upgrading from 2023.1 to 2023.2 Stable.
Trusted networks had localhost and wildcard for local subnet.
127.0.0.1;10.0.32.*
ESPEasy was - ESP_Easy_mega_20230623_normal_ESP32_4M316k Jun 23 2023
Raspberry Pi4, Sunny Boy 4000TL, Victron Multiplus II 10kw ESS, 44kWh LiFEPO4, Batrium BMS, NodeRED on Cerbo GX
