Problem with PPM indicator
Posted: Wednesday 18 January 2023 13:11
by BartSr
I hooked up a Sensair airquality sensor to espeasy.
In espeasy I see correct PPM value
Than I created in Domoticz dummy device airquality
I sent datya from esp easy with command
SendToHTTP,<192.168.2.100>,<8080>,/json.htm?param=udevice&type=command&idx=910&nvalue=401.00
But nothing arrives in Domoticz
Any suggestion?
If I hook the value using MQTT I see in the device list also nothing but if I use instead dummy device "GAS" I see the value as 0.401
-Bart
Re: Problem with PPM indicator
Posted: Wednesday 18 January 2023 14:23
by waltervl
Posted: Wednesday 18 January 2023 17:16
by BartSr
Any moderator who can delete this double post?
