Problem with PPM indicator
BartSr
Domoticz version: V2024.7
Post by BartSr »
I hooked up a Sensair airquality sensor to espeasy.
In espeasy I see correct PPM value
Than I created in Domoticz dummy device airquality
I sent datya from esp easy with command
SendToHTTP,<192.168.2.100>,<8080>,/json.htm?param=udevice&type=command&idx=910&nvalue=401.00
But nothing arrives in Domoticz
Any suggestion?
If I hook the value using MQTT I see in the device list also nothing but if I use instead dummy device "GAS" I see the value as 0.401
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Re: Problem with PPM indicator
BartSr
Post by BartSr »
Any moderator who can delete this double post?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
