USR-TCP232-T2 values in log but no devices
Posted: Thursday 29 December 2022 17:18
by Vreak77
Hi guys,
Just a question you might help me with.
I am trying to get the readouts of the nodoshop opentherm gateway (using the fixed LAN interface).
But i am struggling to get the readouts. I do see a nice valuestring in the log, but in the devives i only see 4 devives an named GIOAPulkledToGround/GIOBPulkledToGround/GIOAStatusIsHigh/GIOBStatusIsHigh. Why are all the other devices not inserted?
To my knowledge:
- I allow devices in the domoticz setting.
- there is communication as i do see the log values
I installed Domoticz on a Synology DS212...
Anby idea?
Thanx in advance!
Vreak77
Re: USR-TCP232-T2 values in log but no devices
Posted: Thursday 29 December 2022 19:43
No idea what is happening here but there was at least 1 person with the same issue: viewtopic.php?t=28097
Posted: Thursday 29 December 2022 19:59
by Vreak77
I will ask him if he found a solution.. But his log shows erros. I do see values...
Thanks for the tip!
If he has found something which will help me I
will report it here...
Posted: Thursday 29 December 2022 20:54
by Vreak77
Mayby also to consider an upgrade... seems my domoticz version is kinda old... :(
But also the DS212 cannot be upgraded to DSM7.x and will not get any security updates after Q2 2023... :cry:
Posted: Thursday 29 December 2022 22:37
Perhaps you can use docker on your synology. Then you can use latest stable 2022.2
https://www.domoticz.com/wiki/Synology
Posted: Friday 30 December 2022 11:09
by Vreak77
I will have a look. But i understood/read somewhere that when using Docker some additional internal memory is required... and DS212 is not expandable.
Also like to keep a little-bit in the default installions because my knowledge is not on a experience level....(yet.. ;) )
Maby to try to find a latest jadahl version...
