Shift setpoint up and down Heatpump
Derik
Post by Derik »
I have a Panasonic heatpump with a heishamon so i can switch with mqtt.
I will make a simple dz vents script so i can switch my heatcruve up and down. [ on different variable setpoints ]
I do have:
And try a simple script to start:
		timer = {'every 1 minutes' },
	execute = function(domoticz)
        local setPoint = 12956 -- wp warm shift
        local roomTemperatureId = "TV Woonkamer.rawData[1]"-- Woonkamer TV 14844
        local Time = require('Time')
        local currentTime = Time()
        if currentTime.matchesRule("between 6:05 and 15:35") and roomTemperatureId <= 22 then
            updateSetPoint(-1)
            domoticz.notify("tester aan", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , "")
            domoticz.log('1 WP shiften if -1 !')
        elseif currentTime.matchesRule("between 6:05 and 15:35") and roomTemperatureId > 22.0 then
            updateSetPoint(2)
            domoticz.notify("Tester uit", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , "")
            domoticz.log('1 WP shiften if 2 !')
Log says:
2022-12-26 13:37:00.384 Status: dzVents: Info: ------ Start internal script: 1 WP Shiften:, trigger: "every 1 minutes"
Only no change @ all
I think Setpoint is the problem? Only when i read the wiki i cannot find a other option to switch or set a other setpoint.
Where do i go wrong?
Re: Shift setpoint up and down Heatpump
To get a current temperature value of a temperature device use something. Like
local currentTemp = domoticz.devices(IDX).temperature
To set a setpoint to -1 use something like
 domoticz.devices(IDX).setSetpoint(-1)
Derik
Post by Derik »
Thanks...
Make some changes..:-0:
        local currentTemp = domoticz.devices(14844).temperature
        if currentTime.matchesRule("between 6:05 and 15:35") and currentTemp <= 22 then
            domoticz.devices(12956).setSetpoint(1)
        elseif currentTime.matchesRule("between 6:05 and 15:35") and currentTemp > 22.0 then
            domoticz.devices(12956).setSetpoint(-1)
Not switching anything, lag says the same .
Try to remove the currenttime.matchrule to debug if temp is working.
Derik
Post by Derik »
mmm also not working:
        --if currentTime.matchesRule("between 6:05 and 22:35") and currentTemp <= 22 then
                    if debug("between 6:05 and 22:35") and currentTemp <= 22 then
        --elseif currentTime.matchesRule("between 6:05 and 22:35") and currentTemp > 22.0 then
                    elseif debug("between 6:05 and 22:35") and currentTemp > 22.0 then
Please do not take me to literally :-)
Just remove the matchrule stuff to end up with something something like.
if currentTemp <= 22 then
